AMD Navi - GPU
AMD Navi - GPU
@D3m:
Rumored AMD Navi Radeon RX GPU "66AF:F1" Benchmarks Leak Out - Faster in Graphics Throughput, Slightly Behind in Compute Workloadsž
https://wccftech.com/amd-navi-gpu-radeo...
Dobra novica. Če bodo tega deležne konzole, potem bo lep perf. boost napram recimo PS4 Pro s polarisom.
Splača se v nulo potrudit pri dizajnu, saj potem "glupi" stroj naštanca čip ne glede na to, kako posrečen je. :))
Aja, pa upam, da bo GDDR6 memory za desktop in ne drag HBM2.
There lives a zipacna in zugrarna...
FlyingBee ::
Mirakul.
AMD Navi 20 GPU Allegedly Supports Ray Tracing and Enhanced GCN Graphics Architecture - May End Up Being Much Faster Than RTX 2080 Ti
https://wccftech.com/amd-navi-20-radeon...
|HP ProBook|R5 3500U|
|Lenovo A10|Mediatek MT8121|
DamijanD ::
sicer bi rad videl, da bi bilo to res, ampak ah dej no...
Ahim ::
DamijanD je izjavil:
1: Avtor: Hassan Mujtaba (najbolj nekriticen od vseh tistih pakijev - samo da se objavlja clickbaite).
2: Do prvega aprila je samo se par dni.
3: Ze Vega podpira ray tracing (DXR), tako da res ni nikakrsen cudez, ce ga bo njen naslednik (no, manjsa iteracija).
4: "May" in samo "Raytracing performance equivalent", ne kar neko splosno racunanje, vec FPS v igricah, boljsi perf/watt ali karkoli drugega. May being the operative word here 'cause Hassan Mujtaba (tip na veliko razlaga kako bo bodoca Intelova Gen11 graficna s 64 EU hitrejsa od stiri leta stare s 24 EU - "celo za faktor 2.5x", pravi Hassan).
Bomo videli. Da ne bo spet brut force grafična, ki jo igre ne bodo izkoristile.
FlyingBee ::
Zakaj pa ne bi bila hitrejša od 2080ti? 7nm, izboljšan gcn, ... vse možnosti ima.
A ni AMD rekel, da z navi ne ciljajo v high end?
At the same time, while the Navi 10 chips are expected to be looking at GTX 1080 / RTX 2070 level gaming performance, these upgraded Navi 20 GPUs are suggested to be aiming more at the RTX 2080 or RTX 2080 Ti level. That's mighty ambitious...
https://www.pcgamesn.com/amd/navi-10-na...
Sicer mi je pri RTX seriji bolj kot RT všeč DLSS in to zaradi 1440p zaslona z visokim osveževanjem.
Tko da če bo Navi 10 + RT delivral 40FPS pri omenjeni ločljivosti, bo to pogojno uporabno.
tikitoki je izjavil:
Nič niso rekli. To smo mi gruntali.
Verjetno so spet krozile napacne "novice". Upam, da kamlu lansirajo.
m0LN4r ::
D3m je izjavil:
May...be :) tako kot vedno so tile rumorsi zadnjih par let pravi sci-fi
D3m je izjavil:
Po tolkih poskusih ala Fury pa Vegi, bi jim ze lahko potegnilo.
IN AMD RTG WE BELIEVE
Sooner or later TM
  • spremenil: m0LN4r ()
klinker ::
D3m je izjavil:
Ne nabijaj. Je blo dosti clankov na to temo.
M-Power ::
Why AMD's Navi GPUs Won't Impress Gamers or Enthusiasts Alike
https://www.techquila.co.in/amd-next-ge...
FlyingBee ::
Verjetno premalo tehnično za formalnega FireSnake-a, pa vendar: The GCN 5 microarchitecture hasn't got much room left for major chip-level modifications. That will only be possible with GCN's successor, the so-called Arcturus microarchitecture.
  • predlagalo izbris: camx ()
FlyingBee ::
Kaj pa če bo Navi 20 2x Navi 10, torej 2 gpuja v enem in da bodo enega le za rt, drugi pa za ostalo.
M-Power je izjavil:
Če bo navi naslednik polarisa, potem bo lahko zeh in meh.
V primeru, da so nadaljevali vega arhitekturo, pa bi znalo bolje kazat.
Po linku ni podal nič razen špekulacije.
m0LN4r ::
AMD je spekulacija ;)
Sooner or later TM
Alien123 ::
jap.. pr Nvidii vsaj veš, da pridejo boljše grafične od prejšne generacije.. Pr amdju pa se ne ve al bo high end al bo polaris refresh al bodo sploh ven prišle to leto itd..
i7 8700| NOCTUA NH-D14| gigabyte Z390 GAMING X| GIGABYTE GAMING OC 2080|
NZXT H440| 16GB DDR4 3600| SSD 970 evo+ 500gb| GSX 1200 pro
Razer Lancehead, Blackwidow elite| ASUS PG348Q| XBOX one| PS4
AMD Navi Preliminary Support Added To HWINFO As AMD Gears Up For Launch
https://wccftech.com/amd-navi-prelimina...
NAVI naj ne bi bil GCN.
Bomo videli.
  • spremenil: D3m ()
FlyingBee ::
Končno.
AMD Holding Partners Summit On April 23 - 7nm and Navi On The Agenda
https://wccftech.com/amd-partners-summi...
Več konec meseca.
Za Ameriko, a nič ne de. Informacije bodo zunaj.
Hipatij ima tiča in testise. Uživa, ko igra feministko in vas trola.
Dokaze o razgaljenju imate v temi s pritožbami (Matthai se je žrtoval za vas).
Admini blatenje tolerirajo (dajte si duška).
m0LN4r ::
Bo AMDjeva nova karta naslednik za mojo 1080Ti ??
Sooner or later TM
FlyingBee ::
Ne, naslednik za 180eur vredno rx 580.
Bwaze6 ::
FireSnake je izjavil:
Bojda da ne, to gre za interno prireditev za partnerje in izbrane novinarje, vse informacije na teh dogodkih pa so pod močnim NDA.
Potem mi od tega ne bomo imeli nič ;((
Mogoče kake drobtinice, ki bodo "ušle".
Vsak info bo dobrodošel.
Nekje sem zasledil, da je pri AMD-ju trenutna hiba geometry pipeline in naj bi to izboljšali že pri Navi-ju.
Ko gledaš primerjave po osnovnih kategorijah (texture fillrate, pixel fillrate, memory bandwidth, compute power; prednjači AMD) bi to znalo držati.
Wrop ::
Pontencialna hiba je, če je zelo veliko trikotnikov, ki prekrivajo malo pikslov. Efektivnost precej pade.
FlyingBee ::
A niso tile fillrate testi že pase?
FlyingBee je izjavil:
Niti ne, samo ima nVidia boljše optimizacije, višje frekvence itd.
Marsikdo bi porekel, da je kriva GCN zasnova, oziroma se v AMD sponsored naslovih kar obnese.
Obneslo se je npr. tudi pri miningu, ko so bili RX 570 iskana roba, dosti bolj kot 1060 3GB.
m0LN4r ::
Kaj zdaj, nvidija je vklopila DXR za pascale, kaj pa AMD caka?
Ne na novih ne na starih ne mislijo nic pokazat?
Sooner or later TM
Treer ::
DXR na Radeonkah bi pomenil single-digit framerate! ;((
FlyingBee ::
V cryengine vega56 drži 30fps na 4k.
Treer ::
Mja, v tistem demu - jaz bi počakal na kaj, kar se bo dalo neodvisno preverit...
Big Steve Walton je izjavil, da v svojem gaming setupu fura vego56 in da ne pogreša prav dosti. Res pa je, da si je verjetno gor namontiral par ventov več.
Treer ::
Ja, zastonj review sample, verjetno top model. In pa človek verjetno gejma kako uro ali dve na teden. Sicer pa, saj pravim, za dovolj nizko ceno bi se dalo razmislit.
  • spremenil: Treer ()
m0LN4r ::
No pa mi imeli tudi nekaj kaj lahko vsi na lastne roke sprobamo. Kje lahko downloadam?
Treer je izjavil:
Naceloma 3DMark Port Royal, bi moral laufati na DXR graficnih ne glede na to iz katerega tabora so.
Ce na Vegi56 tako super laufa, pa naj vklopijo za 3D mark ali pa cryengine demo dajo v javnost vsem.
Sooner or later TM
AMD Navi Debuting at E3, Launching July 7 With RTX 2080 Class Performance
https://wccftech.com/rumor-amd-navi-deb...
meho7 ::
D3m je izjavil:
A ni to ze Vega 7 :|
mid-range
dolenc ::
Če bi blo res 2080, tud jaz grafo menjam, sam močno dvomim, če bo 2070 bo že velik.
meho7 je izjavil:
D3m je izjavil:
Je. Samo so naredili marketing čisto drugače.
Pro karta z 2080 performance.
Navi je pa samo gaming karta.
Treer ::
D3m je izjavil:
Ahahaha, veš de! :));((
gddr85 ::
next gen arch lejga
..no razen, če bojo "potweakal" vego 7nm =)
  • spremenil: gddr85 ()
D3m je izjavil:
In other news, Christiano Ronaldo menda poleti prestopi k Manchestru, Mbape in Neymar pa k Realu. :)
FlyingBee ::
7nm pa gaming only oriented, zakaj pa ne, samo cena msrp ne bo kot Polaris, razen če si lahko privoščijo isti kot z ryzni, ki jih dirt cheap prodajajo za pridobitev market share. Verjetno bo bolj tam okoli 350, 400 na začetku.
Spock83 ::
Treer je izjavil:
D3m je izjavil:
Čisto mogoče. 1080Ti je že kar nekaj let zunaj pa ima podoben performance kot 2080. Če to ne bi dohiteli, lahko GPU divizijo kar zaprejo.
6 / 58
NVIDIA Ampere (2020) (strani: 1 2 3 411 12 13 14 )
65525382 (34) tikitoki
AMD najavil Radeone RX 5500 (strani: 1 2 )
964277 (1521) Mr.B
AMD najavil Radeona RX 5700 XT (strani: 1 2 3 4 5 6 7 )
33913289 (4726) Mr.B
nakup grafične v letu 2019 (strani: 1 2 3 4 5 6 )
26712709 (5943) Glugy
