AMD Navi - GPU
AMD Navi - GPU
Briga njih. Bo pač slabša v surovi sili od 9070 in kake 100€ dražja, vendar bo imela super duper boljši DLSS4 in 4x fake frames. Komot bodo prodajal za 750€. Če se bo pa slabo prodajala, sploh ni važno, v vsakem primeru se na dobičku ne bo poznalo iz tega segmenta.
scipascapa ::
To 4070S, ki se jo je še dobilo za 620EUR, ASUS Dual EVO, je šrot, jaz jo trenutno prodajam.
kje za kok?
GrimReaper3 ::
https://videocardz.com/newz/microcenter...
Če bo to res, bodo na Mindfactory:
ASRock Challenger 9070 - $649 = 780€
ASRock Steel Legend 9070 XT - $699 = 840€
S takimi cenami bosta obe DOA. Jaz sem sicer že včeraj začel gledat 5070 Ti, ko sem videl cene 1100€. AMD me premami edino s 750€ za 9070 XT.
Pri takih cenah tudi ostanejo RX 7000 še naprej najboljši price/performance, 7700 XT, 7800 XT, 7900 GRE in 7900 XT.
No saj to je to na kar se me je že opozarjalo nekaj časa, jaz sem polagal preveč upanja v AMD.
scipascapa ::
Pri nas potem še 10-20% več LMAO.
A vzamem potem rabljeno 7900GRE za 500€? Kok W porabi, se jo spravi na 200-220w max?
Seveda se jo spravi, vprašanje je le koliko performance izgubi za to.
GrimReaper3 ::
Some benchmark numbers for you... 9070 (both XT and non XT)
Cyberpunk 2077 (custom scene, 4K, no RT)
9070XT = 63FPS avg, 9070 = 52FPS avg (5070Ti scored 60FPS, 5080 scored 69FPS)
Alan Wake 2 (4K, no RT, custom scene)
9070XT = 59FPS, 9070 = 48FPS (5070Ti scored 55 FPS, 5080 scored 63FPS)
And now for RT... Cyberpunk 2077 RT Ultra in 4K (custom scene)
9070XT gets 28FPS (no upscaling!) and 9070 gets 21FPS (5080 scored 33 FPS, 5070TI scored 29FPS)
PATH TRACING in 4K the 9070XT got 10FPS and the 9070 got 8 FPS (5080 scored 15FPS and 5070Ti got 12FPS)
Here you go, some numbers from a review sample ;) OCing takes it to 5080 levels, but you can also overclock the 5080, that's true :)
Overall, with final data I gathered... 9070XT is a replacement to the XTX in raster, much better RT, losing some VRAM, but it didn't matter in testing for now... You get FSR4 and RT is just leagues ahead, it's a tier ahead of the XTX
No vsaj končno so naredili dobri kartici, tudi če cene ne bodo OK. Sicer pa tudi če bo XT 900EUR in ne 800EUR, še vedno precej bolje kot 5070 Ti za 1100-1400EUR.
Glede na te FPS številke za RT sicer ne vem kje je sploh fora, verjetno za manj zahtevne igre in 1440p. Pač vseeno bolje 90 kot pa 60 FPS, če ne drugega imaš 33% nižjo porabo, če igraš na 60 FPS. To je potem že 200W proti 300W.
scipascapa je izjavil:
A vzamem potem rabljeno 7900GRE za 500EUR? Kok W porabi, se jo spravi na 200-220w max?
7800 XT ni izgubila nič na 225W z OC-jem, se pravi tudi 7900 GRE ne more več kot 5%.
Jaz bi še malo počakal, čeprav 9070 ni šans da boš dobil za 500EUR.
DamijanD ::
yayo ::
opa! Andrej Zdravkovic is senior vice president of GPU Technologies and Engineering (G&E) Software and Chief Software Officer, managing the global G&E Software team and driving AMD's software development strategy and processes.
With more than 30 years of industry experience and deep software expertise, Zdravkovic rejoined AMD in November 2015 as corporate vice president of Global Software Development. Since then, Andrej has delivered a clear software vision that drives differentiated features and supports critical customer programs as well as improved end-user ratings and performance of AMD Radeon software.
Prior to AMD, Zdravkovic was senior vice president at Giesecke & Devrient, leading worldwide Software Solutions from 2009-2015. Before Giesecke & Devrient, Andrej was senior director of software for graphics and multimedia, product integration, customer engineering and customer project management at AMD, which he joined in 1998, then known as ATI.
Zdravkovic holds a Bachelor and Master of Science in electrical engineering from Belgrade University, as well as a professional engineer designation with the Professional Engineers of Ontario and Senior Member status with IEEE.
a gde su slovenci, bre?
Vidiš, Reaper... MSRP sem skoraj povsem zadel. 599$ in 549$.. Kar je malo sumljivo in namiguje, da se tudi pri zmogljivosti nisem tako veliko zmotil.
Namreč, zakaj bi AMD ponujal 7900XTX zmogljivost za 599$ (~700€ v Nemčiji), sicer 8gb manj rama, ampak boljši RT+FSR, učinkovitost, itd? Prepoceni za trenutno stanje, a ne?
Bo prej držalo, da so uradne številke pristransko cherrypickane in je v resnici kartica v raster na nivoju 7900XT, mogoče +5%.
yayo je izjavil:
Pri Nvidii :))
yayo ::
good one. 8-)
V čem je fora, da AMD izdaja dve grafični s le 50$ razlike?!? To bo zdaj 9070xt 700EUR+, 9070 pa 650EUR+. Spet druga 100% DOA. zaradi zgrešitve marketa. Večina ljudi ne kupuje grafične v rangu 700EUR... Sej verjetno tudi niso v štartu mišljene za mass market, zaradi 4nm čipa, kjer so verjetno omejene kapacitete. Zdaj lahko samo upamo, da imajo v planu 9060xt na 5nm in s ceno 400$. Seveda vse pod pogojem, da je FSR4 konkretno boljši od FSR3 in je primerljiv DLSS4, ali vsaj boljši od DLSS3.
  • spremenil: Magic1 ()
Magic1 je izjavil:
Ker so yieldi zelo dobri in nimajo veliko "odpadnih" primerkov.. Previsoka ceno lepo reši ta "problem".
AMD sanja da bo 9070 veliko boljša od RTX5070, da si upajo dat isto MSRP.
DJ MartiNi ::
Ni veliko za pričakovat od te generacije. Isto velja za ostale proizvajalce, oziroma oni že dokazujejo, da je temu tako.
Ryzen 7 7800X3D/MSI B850 Edge Ti Wifi/2x16GB G.Skill Ripjaws S5 6000/RX 7900 XT
Ryzen 7 5700X/ASRock B550 PG Velocita/2x16GB G.Skill Ripjaws V 3600/RX 5700 XT
AMD FX-8350/ASRock 970 Extreme4/2x4GB Kingston HyperX Beast 2400/R9 270X
DamijanD ::
No glede na LTT bo vsaj zaloga (oz. Linus verjame, da bo)
Jarvice ::
AMD RDNA 4 and Radeon RX 9070 Series Unveiled: $549 & $599
https://www.techpowerup.com/333301/amd-...
AMD Radeon RX 9070 Series Technical Deep Dive
https://www.techpowerup.com/review/amd-...
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
Mam sam eno vprašanje - bo ta reč delala v supermicro H12SSL plati v uefi mode? Ker 7900xtx v uefi ni delal, samo v legacy.
Ijus ::
folk. glede teh novih 9000 graf od amdja. kateri dve bosta najjači iz te serije?
na uradni strani od amd so že objavili dve kartici iz te serije 9000.
neki mi ni jasno: piše za RX 9070 XT... max 16GB of VRAM.
a sta ti dve najjači, ki sta atm objavljeni. al pridejo še jače ven?
sorry k ne vem. nisem tolk na tekočem.
trenutno imam rtx 4070 super 12gb pa me nekako zaradi aija zanima nakup boljše grafe z much več ai tops powerja. pa tudi več vrama.
hotel sem povedat da sem presenečen v negativnem smislu da imata ti dve ki sta atm objavljene samo 16gb vrama. nekam mal no.
tko da ne vem al sta ti dve najjači al bodo izdal še jače.
pa 100x sem rekel jače :))
udri jače manijače haha
WamPIRe- ::
Ijus je izjavil:
AMD se ne gre High-enda. Ti pa kupi 5090, pa je.
Zimonem ::
Zaenkrat še ne sekiraj itak ob izidu ne bo podprt ROCm.
Če bi se šel doma Edge glej raje Strix helo in 128gb rama. Ali tisto nvidijino čudo digits ko jo izdajo.
Doma se praktično ne izplača laufat ai modelov v vramu.
  • spremenilo: Zimonem ()
AMD Radeon RX 9060 serija izide v drugi polovici leta.
Dobra cena.
AMD FSR 4.0 will be exclusive to the RDNA 4 GPUs
Buggy ::
Po prikazanem je tole kar konkreten uplift in generacijski gain za AMD. Prav tako je MSRP postavljen posteno. Zal pa bodo spet trgovci s svojimi marzami zjebali shock terapijo, ki jo AMD lepo postavil za Ngreedijo, ker bojo nabili ceno 5070Ti -100/150€
Zaloge naj bi bile, SW je dodelan in slabse kot je zdej z driverji pri zelenih skoraj ne more bit. Ce FSR 4 prinese res tako dober upscaling kot je DLSS pa sploh ni kej za razmisljat.
Dobra družba bi bila še RX 9060(XT). Navadno so imele tovrstne kartice serije 6000 in 7000 2048 SP-jev, RX 5600XT pa npr. 2560.
Če bi dodali tistih dobrih 20% senčilnih enot, potem v tem ne vidim škode.
Težava bi lahko bila zgolj v tem, da bi jih morali prodajati okoli 350€, sicer bi kupci raje kupovali od nVidie, tudi Intela.
GrimReaper3 ::
Pri enako CU-jih, kar je 60, je RDNA 4 43% hitrejši od 7800 XT.
Se pravi bo pri 32 CU kot je bil do sedaj običaj pri 60 XT karticah, samo 7700 XT performans.
7800 XT je 18% hitrejša od 7700 XT. Se pravi bi morala imeti 9060 XT nekje okoli 40 CU, da izenači s 7800 XT.
MSRP pa nujno $350, ker je trenutno 7800 XT preračunano iz Evrov nekje $440.
Ampak da dobijo 7800 XT performanse 100% ne more biti 128-bit 16GB, tako da 192-bit 12GB.
7800 XT bo tako ostala naprej najboljša 500EUR kartica. Čeprav je sam AMD rekel, da bo 9070 vplivala na prodajo 7800 XT. S temi $550 oz. 650EUR sigurno ne, edino 7900 GRE bodo lahko počasi ukinili.
Drugače pa za 700EUR 9070 XT proti 1100EUR 5070 Ti (pa že za ta denar jo je težko dobiti) sam raje kupim 9070 XT. Bomo videli naslednji četrtek. Za 850EUR naj jih pa kar imajo.
Buggy ::
700EUR 9070XT v EU ne bos videl, najprej zaradi davka in dodatnih marz pogoltnih trgovcev. Ce se bo prodajala za cca. 800EUR je zame nobrainer...za jurja pa naj se jebeni trgovci kar na druge naivneze obrnejo.
Skoda ker nima AMD svojega sales kanala like founders edition po svetu direkt od njih. Kot recimo FANATEC za volane, kjer lahko HW dobis samo od njih direktno brez vsakega posrednika.
  • spremenil: Buggy ()
yayo ::
Jarvice ::
Realno...
9070XT od 900€
9070 od 800€
V SLO še dražje seveda.
  • spremenil: Jarvice ()
scipascapa ::
Še +100€ pri nam LOL
Imamo tujino (Amazon.de, computeruniverse.net). :))
scipascapa ::
ne delaš in plačujemo zate ostali, a ni to fino.
Meizu ::
A ne bi bil čas tako kot je to včasih bilo z namenskimi karticami za Physx, eno namensko frame gen čipovje, vtakneš tja v prosto PCI režo in ne rabiš tega glupega generation dedicationa, sunce jim!
Epialt ::
Mlacom ma listane.
No idea sicer ali so cene real ali placeholder, so pa insane.
ACER Nitro Radeon RX 9070 OC 16G, - 882€
ACER Predator BiFrost Radeon RX 9070 OC 16G GDDR6 - 938€
ACER Nitro Radeon RX 9070 XT OC 16G - 1049€
ACER Predator BiFrost Radeon RX 9070 XT OC 16G GDDR6 - 1014€
GrimReaper3 ::
To bo potem v DE 900€. Toliko ne bo noben dal, jaz raje počakam še kak mesec in prišparam še 200€ za 5070 Ti.
Buggy ::
GrimReaper3 je izjavil:
To bo potem v DE 900EUR. Toliko ne bo noben dal, jaz raje počakam še kak mesec in prišparam še 200EUR za 5070 Ti.
itaq...pa vzemi jo spet iz tujine, sfukaj s svojimi extremi in pol posiljaj nazaj in spet jokaj po forumu kako grdi nemci jebejo slovence :(
zakaj bi bila v DE drazja kot pri nas pa tud sam ti ves...GG
BTW: ti nisi AMD material ostani pri zelenih..si ne zasluzis biti na pravi strani zgodovine...LEL
Underdogi so za prave moske..in your face!
Skyman ::
mtosev je izjavil:
A finska je samo za nvidio?:))
GrimReaper3 ::
Buggy je izjavil:
Saj če znižaš power limit šparaš kartico, ne pa sfukaš kot ti praviš. Eno 5070 Ti itak da daš na 250W pa imaš praktično enako hitro. Potem pa ker je tako hitra, omejiš porabo dodatno še v igri s 60 ali 75 FPS in imaš razen v najbolj zahtevnih igrah samo 150-200W.
Kako dražja? Če bo v SLO 1050-1100EUR kot namigujejo Mlacom cene, normalno da tudi v DE ne bo 800EUR, ampak prej 900EUR. V SLO pa normalno da ne bo noben kupoval, če bodo že v DE predrage. XT je vredna 700EUR.
Zdaj brezveze še imeti neko pripadnost, ker so problemi z Nvidia, AMD in Intel.
Buggy ::
Mlacom ima jasno napisano da je to placeholder in da bojo cene nizje...kartice pridejo sele 6.3. Kdaj pa je bila V sloveniji cena HW-ja nizja kot v DE...razen za dolocene izjeme ki jih ne bom sheral (ce boste pridni) >:D
Ni kle nobene pripadnosti...gre se za to ali imas stvari v rokah ti ali pa drugi tebe furajo, ter kako se s tem sprijaznis.
Vracal si GPU ker si jo drkal, default je delala kewl ko si jo ti "underwoltal" pa si imel tezave...WTF u real?
GrimReaper3 ::
Z nobeno nisem imel problemov, ker sem jo undervoltal, to je bedarija. Kartico lahko uničijo extreme overclockerji, ker povišujejo voltažo do ekstremov. To je kot bi rekel, da uničuješ motor pri avtu, če ga voziš pri 2000 rpm.
6900 XT mi ni delala stabilno po vsej verjetnosti, ker sem zgrešil slot, ko sem jo dajal noter. To je problem zdaj pri velikih karticah, ta je bila pa moja prva tako velika. Od takrat naprej raje 5x preverim, šele nato tlačim noter. Manj verjetno, da je prišla iz tovarne nestabilna, lahko pa tudi, ker te so bile navite do amena.
Pa tudi malo opraskan PCIe konektor, to verjetno ali dela ali pa ne, ne pa nekaj na pol.
To je pa v bistvu vse kar sem jaz vračal. Razen še dve Gigabyte 3070, ker sta imeli res moteč coil whine, kdo bo pa to poslušal.
Buggy ::
ki niso bile dafault! UNdervolta se moras znat lotit, slider potegnit ni vse. Glede na tvoje tweekanje subtimngov na Samsung DIe-B bi rekel, da si prevec agresiven in ne znas najti proper balance. V zivljenju je magic ravno balance med vsemi stvarmi...ti pushas limite prevec, kar po svoje sicer odobravam, ne pa da na podlagi fail testov delas zakljucke.
Konsistenca manjka...Bad tester uzivaj v overpriced overhyped Ngreediji >:D
tko kot ne znas vozit 1.6 turbine v oplu, ce bi bil pravi tester in intuziast bi chipal...rofl
GrimReaper3 ::
Rame navijat je potrata časa. Trenutno ne vidim, da bi me še kdaj prijelo kaj takega delat. Na koncu je bilo pa itak vse nestabilno in sem moral dati na stock.
Če ni bil ravno pri 6900 XT to problem, ker sem pred kratkim bral, da (pri AMD) RAM OC povzroča driver timeoute. In bi moral dat na 3200-3600 namesto na XMP 4000.
Undervolt ni neka znanost. Undervolt + OC moraš pa pač najti stabilnost. Pri trenutni kartici sem rabil 20 poizkusov, od takrat ni bilo enega crasha.
Drugače pa lol, kaj si ti danes vse pil ali se drogiral, malo se strezni najprej. Meni drugače ni za taka prerekanja, jaz chillam.
Buggy ::
no vidis kle je tvoja napaka...pushas stvari too far.....kot sem rekel manjka ti malo izkusenj, drugac si cist fajn decko. Tvoji zakljucki pa so bolj meh.
In....je kdo kupil 5070Ti in zadel manj ROPs, kot je po specifikaciji?
Jst jih imam 8 več.
Moji manjka 112 ROPS-ov. Kaj naj naredim? :'(
DarwiN je izjavil:
Prodaj eBay
Buggy je izjavil:
Npr. RDNA 3 kartice so zelo "trotlziher" za undervolt. Daš slider na recimo 92% in to je to. 20% manjša peak poraba, pri zmogljivosti se skoraj ne pozna. Interni management glede stabilnosti je napredoval.
Undervolt + OC je že druga zadeva, ampak je zadeva preprosto izvedljiva, sicer kak tutorial ne škodi.
Max. poraba lahko gre tam +15% z drsnikom in to bo to.
Sicer je nevarnost okvare kartice pri normalni uporabi primarno zaradi višanja voltaže, OC spomina, tudi temperatur.
Če se zgolj niža voltaža in se s tem pretirava glede na primerek bo nestabilnost, kartic to ne bo skurilo.
GrimReaper3 ::
Sem napraskal skupaj 820€, bomo videli v četrtek če bo dovolj.
178 / 187
