Forum » Pomoč in nasveti » Spam
Spam
tomzzi ::
Zadnje dni se v mojem nabiralniku nabira velika količina spama...
Problem je, ker v viru niso naslovi isti. Kako se tega rešit?
Še vir enega maila kot primer:
From - Wed Aug 03 11:04:00 2016 <blockquote>X-Account-Key: account1 X-UIDL: 45023.++mAOYuwVwp0MWfHcsTCpgEQ9es= X-Mozilla-Status: 0000 X-Mozilla-Status2: 00000000 X-Mozilla-Keys: Return-Path: glenda_perez@eyeglassesnow.com Received: from psrvmta03.zcs-production.pri (LHLO mailhub.siol.net) (172.28.167.33) by psrvmbs06.zcs-production.pri with LMTP; Wed, 3 Aug 2016 09:48:40 +0200 (CEST) Received: from localhost (localhost [127.0.0.1]) by mailhub.siol.net (Postfix) with ESMTP id F148C520F84 for <15281581@users.siol.net>; Wed, 3 Aug 2016 09:48:39 +0200 (CEST) X-Virus-Scanned: amavisd-new at psrvmta03.zcs-production.pri X-Spam-Flag: NO X-Spam-Score: 3.702 X-Spam-Level: *** X-Spam-Status: No, score=3.702 tagged_above=-10 required=6.6 tests=[BAYES_99=3.5, BAYES_999=0.2, HTML_MESSAGE=0.001, URIBL_BLOCKED=0.001] autolearn=disabled Received: from mailhub.siol.net ([127.0.0.1]) by localhost (psrvmta03.zcs-production.pri [127.0.0.1]) (amavisd-new, port 10032) with ESMTP id BZYV5BXg0K4c for <15281581@users.siol.net>; Wed, 3 Aug 2016 09:48:39 +0200 (CEST) Received: from mailhub.siol.net (localhost [127.0.0.1]) by mailhub.siol.net (Postfix) with ESMTPS id 8F16C520F7C for <15281581@users.siol.net>; Wed, 3 Aug 2016 09:48:39 +0200 (CEST) Received-SPF: none (eyeglassesnow.com: No applicable sender policy available) receiver=psrvmta03.zcs-production.pri; identity=mailfrom; envelope-from="glenda_perez@eyeglassesnow.com"; helo=tor-srv1.isprime.com; client-ip=68.169.81.77 Received: from tor-srv1.isprime.com (tor-srv1.isprime.com [68.169.81.77]) by mailhub.siol.net (Postfix) with ESMTP id 3E299520F84 for <tomvovk@siol.net>; Wed, 3 Aug 2016 09:48:38 +0200 (CEST) Received: by tor-srv1.isprime.com (Postfix, from userid 33) id A30F3295D63; Wed, 3 Aug 2016 03:48:37 -0400 (EDT) To: tomvovk@siol.net Subject: Panties stripped and hot cunt fingered X-PHP-Originating-Script: 33:sql.php(1944) : eval()'d code Date: Wed, 3 Aug 2016 03:48:37 -0400 From: Glenda Perez <glenda_perez@eyeglassesnow.com> Message-ID: <57a79b78225a980f969a6ccab5300862@eyeglassesnow.com> X-Priority: 3 MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="b1_57a79b78225a980f969a6ccab5300862" Content-Transfer-Encoding: 7bit X-Antivirus: avast! (VPS 160802-1, 02/08/2016), Inbound message X-Antivirus-Status: Clean --b1_57a79b78225a980f969a6ccab5300862 Content-Type: text/plain; charset=us-ascii Busty Blonde MILF Brandi Love Gets Banged Hard In a POV Porn Video [ http://www.binaryapp.net/session.php?e=99&3ryAyaVfjnmHY8=tKf21nt&CSo=2b1&4LBik=Q ] Look here. --b1_57a79b78225a980f969a6ccab5300862 Content-Type: text/html; charset=us-ascii <html> <body> <div style="font-family:Arial,sans-serif;color:#000000;font-size:14px;"> Busty Blonde MILF Brandi Love Gets Banged Hard In a POV Porn Video <a href="http://www.binaryapp.net/session.php?e=99&3ryAyaVfjnmHY8=tKf21nt&CSo=2b1&4LBik=Q">Look here.</a> </div> </body> </html> --b1_57a79b78225a980f969a6ccab5300862--</blockquote>
tomzzi ::
A se res ne da nič naredit? Nadležno je, ker Thunderbird mi lepo pomeče v koš. Problem je, ker na mobitelu pa tega ne morem naredit in je nadležno ko dobivam po 10 ali več mailov na dan spama.
Prosim za zaklep oziroma izbris teme!
- spremenil: tomzzi ()
zee ::
Preusmeri posto na Gmail, ki ima super zmogljive spam filtre. Dela™
zee
jukoz ::
Tudi sfiltrira vsebino in ti kaže relevantne oglase ter ima seveda vpogled v tvoje življenje. Res odličen predlog...
Kaj pa uporabljaš? IMAP ali POP3?
Kateri klient imaš na telefonu?
tomzzi ::
Zakaj ne morem urejat prvega posta?
POP3 uporabljam.
Na telefonu uporabljam mail.ru. Sprva sem imel original aplikacijo za mail od Sonya (imam z3c). Sedaj imam drug rom gor in je brez original aplikacije.
Sedaj grem na BlueMail.
POP3 uporabljam.
Niso neki advanced spam maili, spodoben antispam na strežniku s kakimi RBL ipd. checki bi to z lahko detektiral.
klekej ::
Na službenem mailu imam hude probleme s spam sporočili, na dan jih prejmem tudi 15. Večina je slovenskih oglaševalskih. Gostovanje je na Neo-servu, kjer imajo MailScanner, ki pa kaj prida ne pomaga. Low scoring spam imam nastavljen na 5, High pa na 11, polno imam tudi Blackmail listo, ampak se vedno pojavijo novi in novi. Email je seveda objavljen na spletni strani in še kje, ker mora biti zaradi strank. Po kakšnih ukrepih še lahko posežem? Thunderbird sicer označi spam emaile, jih pa ne pobriše in je vse skupaj zelo nepregledno. Odjemalec je IMAP. Hvala.
juroz ::
pri enih sem videl da imajo email "napisan" na spletni strani kot sliko. torej da kakšni crawlerji ne morejo vzet.
harvey ::
1. email kot sliko ali [at]
2. striktno odjavljanje oglaševalskih mailov - vir jim predstavlja PIRS ali ostali imeniki
3. za najbolj trdovratne prijava na APEK
4. nastavitev usreznega filtra, ki spam tudi pobriše in ne samo da v junk, samo vedi, da vse kar je tako označeno bo zbrisano!
klekej ::
Pri ponudniku pravijo, da naj se od teh neželenih sporočilo odjavljam ročno-unsubscribe. Nekje sem bral, da spamerji želijo ravno to-da jih klikneš in se odjavljaš, s tem pa pridejo novi? Bral sem tudi o preusmeritvi na Gmail, bi to pomagalo? Kako se to izvede?
cekr ::
Kot prvo: v PIRS-u zamenjaj email. Po možnosti vpiši nek gmail itd. naslov, da se bo tam nabiralo.
Zadeva bi morala delovati takoj po vnosu emaila.
Pazi pa da se ne odjavljaš direktno s svojim mailom. Potem bo šele veselje.
knesz ::
To bo za gratis:
postfix main.cf
edit: ker forum reže vrstico, vse za = je v eni vrsti
postfix main.cf
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_sasl_authenticated, permit_mynetworks, check_helo_access regexp:/etc/postfix/helo_access, reject_invalid_hostname, reject_non_fqdn_hostname, reject_unknown_helo_hostname, reject_invalid_helo_hostname, check_helo_access regexp:/etc/postfix/blacklist_helo
strict_rfc821_envelopes = yes
smtpd_data_restrictions = reject_unauth_pipelining
smtpd_delay_reject = yes
- spremenil: knesz ()
klekej ::
To bo za gratis:
postfix main.cf
Lahko prosim po domače? :D Kot razumem mi ponujaš rešitev, samo ne vem kam naj z njo in kako. :)
Kako pa naj se odjavim z drugim email naslovom, če je na PIRSU samo ta? Sem lahko na PIRSU celo brez emaila potem?
- spremenil: klekej ()
knesz ::
To bo za gratis:
postfix main.cf
To je rešitev za tvojega ponudnika elektronske pošte. Lahko mu pošlješ.
klekej ::
Dvomim, da bodo "zagrabili", lahko pa jim ti predlagaš, jaz jim ne znam obrazložit kaj naj naredijo s tem. :D info@neoserv.si
Ta postfix rules ne bodo nič kaj koristili, večina ponudnikov uporablja cPanel/DA, tam pa je smtp server Exim. Problem je v spam rules, ki so pisana večinoma za angleško govoreče trge.
klekej ::
Zamenjal email na PIRSu z enim x, naredil odjavo z X mailom. Stane? Še huje kot prej. Nič jasno..
cekr ::
Ta PIRS so ena velika čreva. Ne dovolijo ti, da bi se izpisal.
Ljudje hodijo okoli popusovat ob najbolj nemogočih urah.
Je treba že takrat pazit, da jim daš nek fake email, če njihove storitve ne potrebuješ.
Posebno moraš tudi pazit, da ti slučajno ne vsilijo kakšne plačljive zadeve.
Če bi rad vpis kaj po svoje, moraš plačat.
- spremenilo: cekr ()
Mare2 ::
Itak nihče storitve ne išče po Pirsu. Njihovo bazo pa v glavnem uporabljajo oglaševlci, ki te potem pospamajo tako s telefonskimi klici, kjer ponujajo razne jogije, kvazi zdravstvene preglde itd.
Email pa itak.
SeMiNeSanja ::
Hudič še vedno od nekje jemlje moj mail, ker dobivam nov in nov spam.
Pa si zrihtaj kakšen spodoben antispam. Od jamranja spama zagotovo ne bo manj.
Ne razumem, kako si lahko misliš, da boš malo zamenjal mail naslov v neki internetni bazi, pa da potem ne boš več dobival spam maila. Spammerji imajo svoje baze. Ko tvoj naslov enkrat pristane notri, zlepa ne gre več ven. Govorim o PRAVIH spammerjih.
Pri lokalnih "reklamarjih" pa se večinoma kar lepo da odjaviti od neželenih sporočil. Samo malo vztrajen moraš biti, pa kakšen filter si ustrezno nastaviti.
Če uporabljaš gmail, ti že on večino spama spuca.
Potem pa rabiš sam še kak filter, pa ti spuca še ostalo...
klekej ::
Ne bi jambral, če bi vedel kje najti in aktivirati sposoben antispam, filter itd. Uporabil sem vse kar omogoče gostovanje Neo-serv, kot laik več ne znam, zato pa sprašujem tukaj za pomoč.
SeMiNeSanja ::
Naloži si Mailwasher. Če free verzija ne bo zalegla, imajo še Pro verzijo.
V bistvu je to programček, ki pogleda kaj imaš v mailboxu, presortira zadeve na je/ni spam (ga tudi naučiš, če nekaj nočeš, da ti označi kot spam), potem pa samo še klikneš na 'briši' gumb. Kar ostane pa potem preneseš dol z Outlook-om ali kar že uporabljaš kot svoj mail program.
klekej ::
Hvala, bom probal.
Danes je začel veljati GDPR, na mailu sem takoj opazil izboljšanje. Zdaj bi se bilo fino na hitro zavarovati pred novimi spammerji. Zdaj z GDPR-jem ne smejo več črpati maila iz baz ali bo hmalu spet vse po starem in sem se znebil samo starih?
SeMiNeSanja ::
Hvala, bom probal.
Če si prejemnik pošte pod aliasi info@____, prodaja@____, podpora@____ ali karkoli podobnega, če si svoj mail janez@podjetje objavil na strani podjetja, itd., potem ti GDPR nič ne koristi. GDPR se tiče VAROVANJA OSEBNIH PODATKOV. Aliasi (info@ ipd.) niso osebni podatek, če si pa svoj naslov sam objavil, pa si s tem tudi dal privolitev (dobesedno prosil), da se ti pošilja maile (zakaj bi sicer objavljal naslov?).
[D]emon ::
Ce sem kupil nov avto in ga parkiral na dvoriscu svoje hise sem s tem dal privolitev (dobesedno prosil), da se mi ga ukrade ? (zakaj bi sicer kupoval nov avto?)
Bitch plz.
Bitch plz.
SeMiNeSanja ::
Bitch plz.
Za keri kiki pa si potem objavljal svoj mail, če ne zato, da se ti piše? Ker je tako lep? Da se pobahaš, da imaš tudi ti mail?
Resno - kako lahko to primerjaš z avtom?
Telefonsko tudi ne objaviš v imeniku, če nočeš, da se te kliče, mar ne? Ali boš odslej vsakega, ki te pokliče vprašal, če ima tvojo izrecno privolitev, da te lahko kliče?
Reci kar hočeš - nekje so tukaj stvari ušle ven iz vseh razumnih sorazmerij.
[D]emon ::
Mail na kontaktni strani podjetja ne pomeni avtomatsko "PLZ2SEND SPAM KTHXBAI"
SeMiNeSanja ::
Kar je za nekoga 'koristna informacija' je za drugega lahko navaden spam.
Problem je, da se v prvi liniji z vso to hiperregulacijo ubija tiste dejansko koristne informacije, ki jih skušaš nekako spraviti do pravih oseb, ki bi jih zanimale.
Tisti pravi spam bo namreč še vedno prihajal - tisti za raznorazne čudežne tabletke in praške za hujšanje, potenco in kaj vem kaj še. Tega ne bo odpravil noben zakon.
Štos pa je, da se je okoli tega GDPR naredilo tako štalo raznoraznih interpretacij, da že skoraj izpade, da ne smeš nikogar ne poklicat, ne mailat mu, če za to nimaš njegovega izrecnega dovoljenja.
Podobno kot tisti GDPR vic:
"Ali poznaš kakšnega dobrega GDPR svetovalca?"
"Poznam"
"Poveš kdo je?"
"Ne smem....."
St235 ::
SeMiNeSanja je izjavil:
Hvala, bom probal.
Ravno obratno. GDPR eksplicitno prepoveduje domnevo soglasja in določa, da to, da je informacija javno objavljena, tebi ne daje nikakršne pravice, da to informacijo shranjuješ in obdeluješ.
Dodatno je tukaj tudi ZEKOM, ki zahteva eksplicitno soglasje preden ti lahko nekdo pošlje reklamno sporočilo.
"Poznam"
"Poveš kdo je?"
"Ne smem....."
O čem ti to sanjaš? A sploh govoriš o isti uredbi, ali nabijaš v tri dni?
To da pokličem telefonsko številko ne pomeni, da sem ustvaril zbirko osebnih podatkov.
- spremenil: St235 ()
St235 ::
GDPR nima neposredno z spamom kaj dosti skupnega. Soglasje za pošiljanje reklamnih sporočil ureja ZEKOM. GDPR se ukvarja s tem a ti imaš legitimen razlog, da zbiraš ter obdeluješ osebne podatke in imaš za to ustrezna soglasja.
AndrejO ::
Jaz to vidim malo drugače.
GDPR je krovni zakon in za pošiljanje SPAM-a praviloma potrebuješ obdelavo neke zbirke osebnih podatkov (izjema je zbirka, ki dokazljivo ne vsebuje osebnih podatkov - težka bo), torej je ta vrsta obdelave zagotovo podložna GDPR.
Vendar pa 6. čl. GDPR izrecno navaja primere obdelave, kjer predhodno strinjanje ni potrebno, ena izmed možnih izjem je legitimen interes podjetij, pripadajaoč recital pa izrecno omenja, da je tudi neposredno trženje lahko legitimen interes podjetja.
Iz te izjeme pa potem sledi, da ZEKom-1 (v Sloveniji, drugje pa kaj drugega) izrecno ureja kdaj podjetje lahko in na kakšen način lahko izvaja neposredno trženje.
Tako je v smislu GDPR "dvojno dovoljeno", da se v določenem okviru te aktivnosti izvajajo: obstaja zakonska podlaga za obdelavo (ta načeloma negira potrebo za predhodono strinjanje) in obstaja izjema za obdelavo, ki se jo šteje kot "nujno potrebno za uresničevanje legitimnih interesov".
Pri podrobnejšem branju 158. čl. ZEKom-1 tako v splošnem veljata dve stvari:
- Podjetje s katerim ima posameznik sklenjeno pogodbo, lahko uporabi elektronski naslov za neposredno oglaševanje *lastnih* produktov ali storitev, če hkrati ponudi enostaven način odjave.
- Podjetje lahko za namen neposrednega oglaševanja obdeluje naslove, če je *pravna oseba* ta naslov objavila kot svoj kontaktni naslov (ker IMO vključuje tudi in predvsem poslovne imenike).
Torej: GDPR omogoča izjemo od predhodnega strinjanja; ZEKom-1 to izjemo natančneje opredeljuje za okolje Slovenije.
- spremenil: AndrejO ()
| » | Mail strežnik na linuxuOddelek: Omrežja in internet | 2421 (2120) | x.sci |
| » | [Ubuntu server] mail poslan iz serverja zazna kot vsiljeno pošto (strani: 1 2 )Oddelek: Omrežja in internet | 11076 (10046) | shorvat |
| » | Postfix Relay access deniedOddelek: Programska oprema | 2341 (2259) | jype |
| » | Postfix MX lookupOddelek: Omrežja in internet | 2908 (2507) | Bakunin |
| » | Za administratorje serverjevOddelek: Omrežja in internet | 1713 (1439) | Yohan del Sud |
