Forum » Omrežja in internet » KKS > Triera > UPC > Telemach
EdoK ::
kronik ::
Khm.. traceroute to google.com ... zelo blizu :)
# ADDRESS LOSS SENT LAST AVG BEST
1 86.58.76.1 0% 33 0.9ms 1.1 0.9
2 213.161.2.3 0% 33 1.3ms 0.8 0.7
3 213.161.2.194 0% 33 2.7ms 4 2.6
4 194.152.31.216 0% 33 2.5ms 2.8 2.5
Spc ::
Meni resolva v drug IP naslov:
traceroute to www.google.com (172.217.16.100), 30 hops max, 38 byte packets 1 Server (192.168.0.1) 0.011 ms 0.016 ms 0.018 ms 2 10.147.0.1 (10.147.0.1) 4.309 ms 5.074 ms 4.482 ms 3 ve-3.ruby.ip.triera.net (213.161.2.81) 6.332 ms 5.775 ms 4.726 ms 4 cartman-ve-1.ip.triera.net (213.161.2.3) 6.185 ms 5.781 ms 4.427 ms 5 185.66.148.197.ipv4.telemach.net (185.66.148.197) 6.981 ms 7.629 ms 5.934 ms 6 185.66.148.131.ipv4.telemach.net (185.66.148.131) 5.530 ms 5.674 ms 4.027 ms 7 peer-AS31042.sbb.rs (82.117.193.217) 5.378 ms 5.376 ms 8.027 ms 8 de-cix10.net.google.com (80.81.192.108) 11.508 ms 11.754 ms 15.709 ms 9 216.239.46.94 (216.239.46.94) 30.199 ms 216.239.57.113 (216.239.57.113) 30.643 ms 30.141 ms 10 216.239.56.168 (216.239.56.168) 25.054 ms 216.239.56.12 (216.239.56.12) 23.903 ms 25.051 ms 11 209.85.246.95 (209.85.246.95) 24.404 ms 23.952 ms 23.955 ms 12 prg02s12-in-f4.1e100.net (172.217.16.100) 23.257 ms 24.200 ms 24.354 ms
NoName ::
194.152.31.216 je videti kot Google Global Cache (GGC) node pri Telemachu... tale 172.217.16.100 pa je pravi googlov IP malo več korakov stran. @Spc - verjetno imaš lastne DNS strežnike ali pa uporabljaš kak OpenDNS ipd...
I can see dumb people...They're all around us... Look, they're even on this forum!
Spc ::
Ja, imam lasten dns strežnik.
rini ::
Telemach je tak nateg. Čakaš dolgo da priklopijo, naslednji dan se pa že sesuje. Po klicu na center dobiš odgovor: "za odpravo napake imamo 3 dni časa". Naj se j...
BorutK-73 ::
Yeah right
Pač si naletel na problem.
Moje izkušnje z telemachom so super, tudi z help desk-om imam dobre izkušnje.
Bakunin ::
Tole ti vrne google PointOfPresence/GGC
Malcolm_Y ::
Po moje so si samo pripravili teren, za takrat, ko bo to treba. Ni da bi zdaj spreminjali IP-je samo zato, ker lahko.
Spc ::
http://telemach.si/a14469/Pomoc/Novosti...
Naj rajši dodajo Sky paket:
http://www.sky.com
http://tv.sky.com/tv-guide/
Ne pa neke bedarije, katere noben ne bo gledal.
- spremenil: Spc ()
BorutK-73 ::
WTF.
HD FASTBOYZ
Ekskluzivna gej vsebina za odrasle.
Razširjena shema in paket BOX
- spremenil: BorutK-73 ()
Gremio ::
http://www.sky.com
Se strinjam,bravo..
Orias ::
WTF.
HD FASTBOYZ
Kaj pa je to kaj čudnega. Spet bodo imeli kaj druga za delat, ko omrežje nadgrajevat ali pa delat, da nam ponudijo višje upload hitrosti
Sem pa na APEK strani zasledil, da bi se naj marsikje nadgrajevalo omrežje: http://www.akos-rs.si/pozivi-investitor...
Pa še bivši naročniki bomo lahko spremljali po 18.4 spremljali nove programe. Sam kaj kot človek, ne moreš hkrati pozorno gledati recimo na eni TV tekme, pol še imaš pa zraven en TV pa na njem gledaš kak film :D. Vsaj meni to ne uspe, mogoče pa sam jaz tega nisem sposoben.
Spc ::
WTF.
HD FASTBOYZ
andy2k13 ::
spyker123 ::
Pozdravljeni, imam telemach digitalno kabelsko, conax modul..zanima me, kako izklopim starševsko zaščito oz pin kodo, ki jo zahteva ob vsakokratnem preklapljanju programov za odrasle? :) to vnašanje pin kode je zelo nadležno še posebej, če želiš programe samo preleteti..
jusv ::
Tudi meni vse dela. Če ne gre, ugasni napravo in znova poskusi. Če še vedno ne dela pokliči na pomoč uporabnikom.
Pametne smo podnevi z lučjo iskali!
harvey ::
Je samo pri meni, ali se ne na D3GO ne da več za nazaj gledat?
Da se, samo niso vsi programi podprti.
Malcolm_Y ::
Sem ugotovil, da mi doma še dela, v službi pa noben program, niti RTVSLO recimo. A je po novem kaka omejitev, da samo iz Telemachovega omrežja lahko to gledaš, preko recimo Telekoma pa ne? Včasih mi je namreč delalo povsod.
mujek ::
Še povzetek mojega tečnarjenja telemachu glede statičnega IP naslova.
Po treh tednih sem končno dobil uradni odogovor:
Ostali maili so bili nekonsistentni med seboj (statični ip se plača; brezplačen je), ter nič kaj pametnega niso rekli.
Je pa res - da sem novi naročnik, in sem dopis o prehodu na dinamični IP naslov bil obveščen na prvi položnici za storitve.
Je pa podpora katastrofalna. Ni druge besede. Upam, da čimprej potegnejo optiko, da bom lahko šel kam drugam.
Obveščamo vas, da smo se odločili, da vam zaradi dobre uporabniške izkušnje do nadaljnjega ne bomo obračunavali statični IP.
Orias ::
Seveda ne bodo obračunavali dinamičnega IPja, če je le ta statični. No vsaj pri meni je še tako.
domenc ::
Pri meni je sedaj tudi še statičen IP (takrat (2 meseca nazaj) poslal email, da smo šli na novi paket in da je pisalo da nam dodelijo statičen IP; nato dobil email da so mi vrnili stari IP (po cca 10 dneh) in da se mi ne bo več spreminjal); obvestilo glede spremembe statičnega v dinamičnega pri položnici ni bilo (vidim pa da imam v profilu mojega telemacha možnot vklopa statičnega IP-ja - ampak zaenkrat ne bom diral :) )
Keth Selhan ::
Meni so odgovorili na Telemachu, da za zdaj še ne moremo preko Moj Telemach dobiti vpogled v račune. Ampak samo znesek in če je plačano.
Pa da sem dobila od Telemachovega mail predala link je tudi trajalo, ker na spletni strani ga ni.
Krasno.
Krasno.
Han ::
Ima kdo podatek o (SD) kvaliteti FOX Movies kanala?
Včeraj sem slučajno preklopil nanj, ko so predvajali Vonj po ženski, ko je Al Pacino ravno končal svoj oskarjevski nagovor. SD slika vseh FOX kanalov je itak že od nekdaj totalni kockast zmazek, včeraj je bil pa še zvok takšen podn, da to res ni bilo za gledat. Ploskanje v dvorani se je slišalo kot da bi bilo skompresirano na 10 kbps.
- spremenil: Han ()
Keth Selhan ::
Jaz sem gledala King Konga na Fox Movies 5. aprila in je zmazek od slike in zvoka.
Prej mi 1h ni delal ne net ne TV 72 ur ne telefon. Great.
Spc ::
Včeraj sem slučajno preklopil nanj, ko so predvajali Vonj po ženski, ko je Al Pacino ravno končal svoj oskarjevski nagovor. SD slika vseh FOX kanalov je itak že od nekdaj totalni kockast zmazek, včeraj je bil pa še zvok takšen podn, da to res ni bilo za gledat. Ploskanje v dvorani se je slišalo kot da bi bilo skompresirano na 10 kbps.![]()
Ja FOX SD je
1. Video: VBR MPEG-2 4:2:0 720x576 0.3Mbit/s - 2.0Mbit/s
2. Audio: MPEG1 Layer2 48kHz Stereo 16bit 192kbit/s
Še slikica:
Torej še youtube SD 480p je več Mbit/s.
Spc ::
FOX MOVIES SD je
1. Video: VBR MPEG-2 4:2:0 720x576 1.6Mbit/s - 4.2Mbit/s
2. Audio: MPEG1 Layer2 48kHz Stereo 16bit 256kbit/s
Še slikica:
Še slikica:
- spremenil: Spc ()
Sade ::
V Celju bound-anih že 12 downstreamov, so morda na vidiku novi paketi z še višjimi download-i??
Downstream Bonded Channels
Channel Lock Status Modulation Frequency Power SNR Symbol Rate
1 Locked QAM256 362000000 Hz 10.6 dBmV 45.1 dB 6952 Ksym/sec
2 Locked QAM256 354000000 Hz 10.6 dBmV 45.1 dB 6952 Ksym/sec
3 Locked QAM256 370000000 Hz 10.6 dBmV 45.0 dB 6952 Ksym/sec
4 Locked QAM256 378000000 Hz 10.8 dBmV 45.1 dB 6952 Ksym/sec
5 Locked QAM256 386000000 Hz 10.6 dBmV 45.0 dB 6952 Ksym/sec
6 Locked QAM256 394000000 Hz 10.6 dBmV 44.9 dB 6952 Ksym/sec
7 Locked QAM256 402000000 Hz 10.3 dBmV 44.2 dB 6952 Ksym/sec
8 Locked QAM256 410000000 Hz 10.5 dBmV 44.8 dB 6952 Ksym/sec
9 Locked QAM256 642000000 Hz 6.6 dBmV 40.5 dB 6952 Ksym/sec
10 Locked QAM256 650000000 Hz 6.3 dBmV 40.3 dB 6952 Ksym/sec
11 Locked QAM256 658000000 Hz 5.5 dBmV 40.0 dB 6952 Ksym/sec
12 Locked QAM256 666000000 Hz 5.5 dBmV 40.0 dB 6952 Ksym/sec
andy2k13 ::
Ker modem mas to? Vecina Ciscotov v obtoku podpira samo 8x4.
Orias ::
Mislim, da ima Ubee modem.
Končno jim je potegnilo, da so ugotovili kaj je bonding kanalov. Sam to še nič ne pomeni, če je politika podjetja zgrešena in zaradi 10% uporabnikov nimamo višjih hitrosti.
Kar se pa tiče teh kanalov, jaz imam paket 120/6 pa imam 2 DS in 1 US kanal, pa imam tako hitrost kot jo imam naročeno ( vsaj nekaj dobrega).
Spc ::
Ubee podpira do 24 bound-anih downstreamov in pa do 8 upstreamov sicer !
Kateri chipset je to ?
69charger ::
iloveboobz je izjavil:
naj rajs upload pojacajo.
+100000000000 Paket z 120Mbps downloada in pol mam 4Mbps UP -.-
