Forum » Omrežja in internet » KKS > Triera > UPC > Telemach
Tilen ::
No, to pomeni, da imaš timeout na portu 25 ali pa nimaš nastavljenega pravega porta, kar je malo verjetno. Preveri, kot je zgoraj napisal Cosmo.
SmeskoSnezak ::
Kaj je to? Samo povejte mi, katere nastavitve morm v MS Outlooku spremenit da bo pošiljanje spet mogoče, prosim.
Jaz imam triero, ne telemach. Torej,kaj storiti?
@ Pusti soncu v srce... @
- spremenilo: SmeskoSnezak ()
SmeskoSnezak ::
Kakšne so torej nastavitve za outlook, prosim? Ali bi moral kakšen port odpreti za firewall? Program sn že dodal med izjeme.
BorutK-73 ::
Tole so moji podatki iz Thunderbirda, brez mojih podatkov seveda:
ime računa: pop3.triera.net
ime strežnika: pop3.triera.net
vrata: 110
uporabniško ime: "tvoje ime"
strežnik SMTP
opis: Triera
ime strežnika: smtp.triera.net
vrata: 25
vrata: 110
strežnik SMTP
opis: Triera
vrata: 25
SmeskoSnezak ::
Vse je tak kot treba. Ne kapiram, v čem je problem naenkrat.
kronik ::
Verjetno imaš blokiran outgoing port 25 zaradi spamanja iz tvojega IPja. Počisti mašino in pokliči na podporo za deblokado.
Spc ::
Cvetke ja.
Spet je internet padel za 2 minuti.
Pinging 213.161.0.10 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 213.161.0.10:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Spc ::
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 213.161.0.10: bytes=32 time=7ms TTL=60
Request timed out.
Reply from 213.161.0.10: bytes=32 time=15ms TTL=60
Request timed out.
Request timed out.
Request timed out.
Reply from 213.161.0.10: bytes=32 time=6ms TTL=60
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Nekje 92% packet loss-a na taboru.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
seminal ::
Telemach dal nove pakete. A mislite da se splača it iz navadnega mix L na košarkašega mix L, je samo 1€ razlike pa dobiš 2x večji download? Al bojo še kere druge pakete spremenili?
BorutK-73 ::
seminal ::
Ja sedaj imam Mix L 25/2 pa bi šel na tega ker ej samo 1€ razlike pa je 50 downloada. Mislite da bojo kake spremembe v paketih še po septembru al naj vzamem kar to?
barocco ::
Upload je res porazen pri vseh paketih.
Se popolnoma strinjam.
Raje bi imel 15/5 kot pa sedaj 24/2-(Telemach).
RangerVIII|6700k|Corsair16GB|
Msi1070|pm961|BX5001TB|RM650x|H100iv2|
hojnikb ::
glede na to, da eurodocsis podpira do 108Mbit uploada (čez več kanalov), nwm zakaj nimajo v ponudbi več kot 10Mbit ... gnili ISPji, ni kej..
#brezpodpisa
jernejl ::
gensi ::
Do pred nedavnim so se pri Telemachu izgovarjali na tehnične zmožnosti, a v nekaterih paketih so imeli razmerje med nalaganjem in oddajanjem boljše od 1/10, sedaj pa so razmerje poslabšali na 1/25.
Morda bi imelo kaj učinka, če bi se več uporabnikov pisno obrnilo s prošnjo po izboljšanju hitrosti oddajanja.
kljukec87 ::
Nekaj mi povejte... Kolk vidim v paketih mix piše hitrosti DO. to je pol ista finta ko pri telekomu ipd ko niha kak jim je al vam dela konstantno z nekaj % izgubo?
barocco ::
mam MIX L od lanskega poletja in linije so take kot so opisane Internet do 25/2 Mbps.ko vlečem dol ne niha ampak na polno vleče ,sevedA če ma uploader,hitro linijo seveda.
kronik ::
Spc ::
SmeskoSnezak je izjavil:
Zanimivo, nič nisn spreminjal, pa Outlook spet deluje. :)
Verjetno so te blokirali na telemachu.
gensi ::
Morda kdo ve kakšno razmerje je med UPC in Telemach-om?
Pri nas akcija v imenu EP, pa je vse skupaj precej dražje kot imajo npr. Čehi.
http://www.upc.cz/balicek-sluzeb/
Tečajnica BS: http://www.bsi.si/podatki/tec-bs.asp
In Češka je Slovenijo menda že prehitela po BDP-ju...
Alexius Heristalski ::
UPC nima zveze s Telemachom.
zadetek ::
Premišljujem o prestopu k telemachu, košarka l paket, predvsem zaradi športnih programov, zanima me če ste trenutno zadovoljni s kvaliteto storitev v osrednji slo.? sem iz Zasavja, v stanovanju imamo kabelski priključek, vendar ker imam trenutno t-2 je izklopljen. Je pa samo en šteker za kabelsko, kako bodo priklopili modem, tv, telefon nanj, je potreben kakšen razdelilec ?
Razdelilec, modem ter vse drugo potrebno dobiš od Telemach-a v okviru njihove storitve.
chucki ::
Ima kdo paket košarkar? Kakšne hitrosti so to 50/1 kabel tv oz 50/2 za telemach. No jaz sem šel na košarkar XL 100/4
flisko ::
mam košarkar xl optika 100/50 za 62 €,prej plačeval 64,90 za 30/15,se pravi čista zmaga
mal sem se zmotu 100/100 optika je
- spremenil: flisko ()
SmeskoSnezak ::
Zakaj bi blokirali samo enega izmed email racunov? In se to tistega, ki ga mam edinega nastavlenega v outlooku? Prej bi reko, da je slo za kaksno tehnicno napako.
kljukec87 ::
Eno vprašanje mam če kdo slučajno ve... Koliko downstream spravi od sebe modem Arris TM602B na 2.0 v praksi?
smo doma koncno upgrejdali na 50/2 za katere placujemo isto kot do zdaj pa je bilo 13/1.5 oz celo 1€ manj :)
Bo verjetno treba šaltat na 3.0 modem al?
Dami ::
Nedavno je Telemach kupil vso omrežje KabelTVja tako, da smo zaj njihovi naročniki. Cena digitalne TV se nam je tako zvišala za 2€, ne vem pa kako bo pri dodatnih karticah in modulih za TV. Prej smo morali posebej najeti oboje oz. si lahko svoj conax kupil, kar smo tudi storili. Sedaj pa TM ponuja to možnost samo v kompletu za 2€. Je imel mogoče kdo enako situacijo, ker če se prav spomnim, je TM takrat ko so prvič zaklenli digitalno TV (tudi začetni paket) "talal" po 3 kartice na priključek, module si si pa zrihtal sam/najel. Zdaj me zanima ali mi bojo računali 2€ za dodatno kartico in modul, čeprav imam svojega.
BorutK-73 ::
Sem tudi bil pri KabelTV, zdaj na žalost Telemach. In sem ugotovil včeraj da so mi download povečal na 8Mbps, upload je isti. Če imaš svoj modul ti nimajo kaj kasirat (imam isto 1 svoj modul). Za kartice je pa 2€ za vsako.
PARTyZAN ::
Odvisno od paketa. Pri trojčkih od MIX L naprej sta dva sprejemnika (ali conax modula s pripadajočimi karticami) všteta v ceno.
chucki ::
Zakaj žalost?
TechBeats ::
hm kdaj so pa spremenil L paket na 25/2mbit?
http://www.telemach.si/sl/zasebni-upora...
na ceniku pa 20/2?
Sem glihkar testiral in ja imam še zmeraj zeklenjeno na 20/2,.. bo treba mal poklicat pa rečt da odkelenjo na 25mibt haha :P
na ceniku pa 20/2?
AciD TriP
- spremenilo: TechBeats ()
chucki ::
Moreš bit nor, da nimaš trojčka, ker vse ostalo se ne splača
TechBeats ::
Ne rabim, ker imamo 2 različna paketa v hiši mixS in moj netL.. Tko da nima veze.
Kličem jutri, ma da povečajo
AciD TriP
Spc ::
Smo na backupu ? ali zakaj tako velik packet loss v tujino ?
http://xi-networks.net:8005/cgi-bin/smo...
- spremenil: Spc ()
Spc ::
Ni čudno, sej smo preko srbarije route-ani..
tracert to 87.237.38.200 (87.237.38.200), 30 hops max, 38 byte packets 1 Server (192.168.0.1) 0.017 ms 0.029 ms 0.011 ms 2 10.147.0.1 (10.147.0.1) 6.352 ms 6.617 ms 6.018 ms 3 ve-3.ruby.ip.triera.net (213.161.2.81) 6.114 ms 6.430 ms 8.921 ms 4 cartman-ve-1.ip.triera.net (213.161.2.3) 6.364 ms 6.152 ms 14.706 ms 5 10ge-e1-1.lju.ip.triera.net (213.161.2.190) 15.252 ms 10ge-e5-1.lju.ip.triera.net (213.161.2.198) 14.145 ms 8.299 ms 6 10ge-e6-2.vie.ip.triera.net (213.161.2.142) 16.512 ms 10ge-e5-2.vie.ip.triera.net (213.161.2.110) 18.599 ms 19.994 ms 7 peer-AS31042.sbb.rs (82.117.193.193) 989.360 ms * peer-AS31042.sbb.rs (82.117.193.217) 982.625 ms 8 at-be-r-1-pc2.sbb.rs (89.216.5.82) 915.459 ms * 916.505 ms 9 * * * 10 * * *
