Forum » Omrežja in internet » KKS > Triera > UPC > Telemach
KuntaKinte ::
sam sem imel m+ plus hd( po novem 45+ 6),meni se splača,ceneje + hitrejši net + 6 mesecev pol cene + rabil sem še en sprejemnik,se moraš pa vezat za 2 leti,pogodbena kazen je okrog 270 eur
JK007 ::
Od danes v shemi nova TV programa ( Cinestar ). Več info na kabelska.net
....... www.kabelska.net .........
Maš še kdo švoh signal na elektro turšek ?
Received Signal Strength: -17.1 dBmV
Power Level: 46.2 dBmV
SNR: 31.6 dB
Zaenkrat mam takle in zadeva rada nagaja ...
SNR: 31.6 dB
Spc ::
Cinestar trenutno ni kodiran, in je na:
626MHz, QAM 256
- spremenil: Spc ()
No zdej mam pa poleg svoh signala ^^ še zjebane pinge v tujino (kar je v slo je ok)...
Al mam sam jest te probleme na turnšku al je dejansko neki pr njih ?
techfreak :) ::
iloveboobz je izjavil:
Nisi edini.
Očitno routajo preko gblx, pred tem pa so preko interoute.
1 <1 ms 1 ms 1 ms 192.168.1.1 2 * * * Request timed out. 3 8 ms 5 ms 18 ms cpe-77.38.11.125.cable.t-1.si [77.38.11.125] 4 16 ms 11 ms 14 ms ce3.t-1.si [77.38.11.3] 5 87 ms 84 ms 100 ms 188.64.105.5 6 139 ms 87 ms 86 ms 208.178.62.1 7 184 ms 184 ms 197 ms eth1-2.csr2.DCA3.gblx.net [67.16.145.9] 8 187 ms 202 ms 189 ms FACEBOOK-INC.ethernet12-1.csr1.DCA3.gblx.net [64 .215.81.234] 9 186 ms 188 ms 187 ms ae1.bb02.iad1.tfbnw.net [74.119.78.60] 10 206 ms 201 ms 193 ms ae1.dr01.ash4.tfbnw.net [74.119.78.144] 11 190 ms 183 ms 188 ms po510.csw01b.ash4.tfbnw.net [74.119.78.251] 12 201 ms 192 ms 190 ms www-12-01-ash4.facebook.com [66.220.158.25]
Tilen ::
--- www.facebook.com ping statistics ---
24 packets transmitted, 24 packets received, 0% packet loss
round-trip min/avg/max = 114.135/117.318/138.352 ms
New York (ZDA) - 117ms. Tole je odličen odzivni čas, ne le dober. :)
traceroute to ipax.ipax.at (93.189.24.42), 30 hops max, 38 byte packets
1 * * *
2 cartman-ve-1.ip.triera.net (213.161.2.3) 5.652 ms 6.575 ms 6.297 ms
3 10ge-e1-1.vie.ip.triera.net (213.161.2.218) 15.305 ms 11.148 ms 10.086 ms
4 vix.as24953.net (193.203.0.104) 18.009 ms 9.886 ms 13.328 ms
5 0101.ge-0.0.0.vix.core1.as24953.net.netplanet.at (195.95.163.190) 11.058 ms
10.749 ms 9.590 ms
6 fc01a.vie.ipax.at (89.185.120.2) 12.760 ms 10.758 ms 9.552 ms
7 ipax.at (93.189.24.42) 17.166 ms 10.368 ms 11.302 ms
Zgleda vse normalno.
1 * * *
10.749 ms 9.590 ms
- spremenil: Tilen ()
Evo še moj trace
Tole je še pa ping
Še za primerjavo ping na Tušmobil Brezmejnem netu
Žalost ...
C:\Users\Administrator>tracert www.facebook.com Tracing route to www.facebook.com [69.171.242.14] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.1.1 2 * * * Request timed out. 3 13 ms 20 ms 9 ms ce252.t-1.si [77.38.12.169] 4 10 ms 22 ms 9 ms ce3.t-1.si [77.38.11.3] 5 104 ms 102 ms 116 ms 188.64.105.5 6 134 ms 102 ms 102 ms 208.178.62.1 7 204 ms 203 ms 201 ms eth1-2.csr2.DCA3.gblx.net [67.16.145.9] 8 224 ms 204 ms 204 ms FACEBOOK-INC.ethernet12-1.csr1.DCA3.gblx.net [64 .215.81.234] 9 204 ms 205 ms 238 ms ae1.bb02.iad1.tfbnw.net [74.119.78.60] 10 203 ms 201 ms 199 ms ae1.dr02.ash3.tfbnw.net [74.119.79.129] 11 205 ms 198 ms 201 ms po1022.csw02a.ash3.tfbnw.net [74.119.79.179] 12 232 ms 201 ms 201 ms www-13-02-ash3.facebook.com [69.171.242.14] Trace complete.
Tole je še pa ping
C:\Users\Administrator>ping www.google.si
Pinging www.l.google.com [74.125.39.104] with 32 bytes of data:
Reply from 74.125.39.104: bytes=32 time=118ms TTL=54
Reply from 74.125.39.104: bytes=32 time=115ms TTL=54
Reply from 74.125.39.104: bytes=32 time=116ms TTL=54
Reply from 74.125.39.104: bytes=32 time=117ms TTL=54
Ping statistics for 74.125.39.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 115ms, Maximum = 118ms, Average = 116msŠe za primerjavo ping na Tušmobil Brezmejnem netu
Pinging www.l.google.com [74.125.230.83] with 32 bytes of data:
Reply from 74.125.230.83: bytes=32 time=86ms TTL=50
Reply from 74.125.230.83: bytes=32 time=85ms TTL=50
Reply from 74.125.230.83: bytes=32 time=94ms TTL=50
Reply from 74.125.230.83: bytes=32 time=93ms TTL=50
Ping statistics for 74.125.230.83:
Minimum = 85ms, Maximum = 94ms, Average = 89msŽalost ...
Tilen ::
Žalost je očitno nekje pri tebi.
--- www.google.si ping statistics ---
25 packets transmitted, 25 packets received, 0% packet loss
round-trip min/avg/max = 23.919/25.632/28.065 ms
--- 74.125.39.104 ping statistics ---
22 packets transmitted, 22 packets received, 0% packet loss
round-trip min/avg/max = 29.201/31.987/57.569 ms
Težko, ker jst nimam nobenga vpliva, kak se pretaka net preko tujine
Slo
Tujina
Slo
C:\Users\Administrator>ping 77.38.38.38
Pinging 77.38.38.38 with 32 bytes of data:
Reply from 77.38.38.38: bytes=32 time=11ms TTL=60
Reply from 77.38.38.38: bytes=32 time=10ms TTL=60
Reply from 77.38.38.38: bytes=32 time=8ms TTL=60
Reply from 77.38.38.38: bytes=32 time=7ms TTL=60
Ping statistics for 77.38.38.38:
Minimum = 7ms, Maximum = 11ms, Average = 9msTujina
Pinging www.l.google.com [74.125.39.99] with 32 bytes of data:
Reply from 74.125.39.99: bytes=32 time=158ms TTL=54
Reply from 74.125.39.99: bytes=32 time=130ms TTL=54
Reply from 74.125.39.99: bytes=32 time=156ms TTL=54
Reply from 74.125.39.99: bytes=32 time=125ms TTL=54
Ping statistics for 74.125.39.99:
Minimum = 125ms, Maximum = 158ms, Average = 142ms smoki
techfreak :) ::
Očitno so popravili, vendar smo še vedno preko gblx routani.
Minimum = 31ms, Maximum = 34ms, Average = 32ms
PPing statistics for 74.125.39.104:
Minimum = 32ms, Maximum = 43ms, Average = 36ms
Tracing route to www-11-03-ash2.facebook.com [66.220.153.15] over a maximum of 30 hops: 1 <1 ms 1 ms <1 ms 192.168.1.1 2 * * * Request timed out. 3 8 ms 23 ms 12 ms cpe-77.38.11.125.cable.t-1.si [77.38.11.125] 4 6 ms 34 ms 15 ms ce3.t-1.si [77.38.11.3] 5 17 ms 16 ms 26 ms 188.64.105.5 6 27 ms 17 ms 15 ms 208.178.62.1 7 115 ms 134 ms 115 ms eth1-2.csr2.DCA3.gblx.net [67.16.145.9] 8 131 ms 134 ms 127 ms FACEBOOK-INC.ethernet12-1.csr1.DCA3.gblx.net [64.215.81.234] 9 120 ms 129 ms 127 ms ae11.bb01.iad1.tfbnw.net [74.119.78.68] 10 115 ms 119 ms 199 ms ae1.dr04.ash2.tfbnw.net [74.119.76.186] 11 117 ms 130 ms 116 ms po1016.csw03a.ash2.tfbnw.net [74.119.77.79] 12 120 ms 120 ms 122 ms www-11-03-ash2.facebook.com [66.220.153.15]
Spc ::
hmm jaz pa danes nisem opazil višjih pingov:
http://xi-networks.net:8005/cgi-bin/smo...
Meni BGP izbere telio, kar je naslabši transit provider.
1 Server (192.168.0.1) 0.040 ms 0.066 ms 0.053 ms
2 10.147.0.1 (10.147.0.1) 4.991 ms 4.026 ms 5.468 ms
3 10ge.core.ip.triera.net (213.161.2.81) 5.345 ms 4.333 ms 6.609 ms
4 cartman-ve-1.ip.triera.net (213.161.2.3) 6.000 ms 7.649 ms 5.955 ms
5 10ge-e1-1.vie.ip.triera.net (213.161.2.218) 7.005 ms 8.060 ms 5.674 ms
6 win-b4-link.telia.net (213.248.75.109) 8.968 ms 9.811 ms 7.712 ms
7 prag-bb1-link.telia.net (80.91.245.232) 57.749 ms 19.942 ms 16.263 ms
8 ffm-bb1-link.telia.net (80.91.246.138) 37.130 ms 33.622 ms 48.460 ms
9 ffm-b6-link.telia.net (80.91.251.149) 62.189 ms ffm-b6-link.telia.net (80.91.251.153) 29.630 ms 38.569 ms
10 facebook-ic-137171-ffm-b6.c.telia.net (213.248.104.30) 55.100 ms 48.998 ms 44.919 ms
11 xe-2-2-0.bb02.iad2.tfbnw.net (204.15.20.221) 129.175 ms 123.290 ms 128.776 ms
MPLS Label=447039 CoS=5 TTL=1 S=0
12 www-11-03-ash2.facebook.com (66.220.153.15) 131.211 ms 133.120 ms 130.152 ms
- spremenil: Spc ()
Očitno so zdej popravl
C:\Users\Administrator>tracert www.google.si Tracing route to www.l.google.com [74.125.39.104] over a maximum of 30 hops: 1 2 ms <1 ms <1 ms 192.168.1.1 2 * * * Request timed out. 3 9 ms 8 ms 14 ms ce252.t-1.si [77.38.12.169] 4 11 ms 12 ms 12 ms ce3.t-1.si [77.38.11.3] 5 31 ms 28 ms 40 ms 188.64.105.5 6 48 ms 48 ms 43 ms de-cix20.net.google.com [80.81.193.108] 7 60 ms 49 ms 44 ms 209.85.255.178 8 44 ms 43 ms 49 ms 209.85.254.112 9 48 ms 46 ms 54 ms 209.85.254.126 10 45 ms 43 ms 44 ms fx-in-f104.1e100.net [74.125.39.104] Trace complete.
C:\Users\Administrator>tracert www.facebook.com Tracing route to www.facebook.com [69.63.190.18] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.1.1 2 * * * Request timed out. 3 11 ms 18 ms 13 ms ce252.t-1.si [77.38.12.169] 4 8 ms 25 ms 9 ms ce3.t-1.si [77.38.11.3] 5 48 ms 28 ms 31 ms 188.64.105.5 6 36 ms 28 ms 28 ms 208.178.62.1 7 146 ms 140 ms 157 ms e4-3-20G.csr2.DCA3.gblx.net [67.16.143.105] 8 140 ms 139 ms 140 ms FACEBOOK-INC.ethernet12-1.csr1.DCA3.gblx.net [64 .215.81.234] 9 156 ms 145 ms 147 ms ae1.bb02.iad1.tfbnw.net [74.119.78.60] 10 141 ms 172 ms 140 ms ae11.dr02.ash2.tfbnw.net [74.119.78.152] 11 142 ms 143 ms 140 ms po1017.csw02b.ash2.tfbnw.net [74.119.76.205] 12 135 ms 134 ms 134 ms www-12-02-ash2.facebook.com [69.63.190.18] Trace complete.
Veron ::
Zanimivo pogledat, da prvo opišem stanje:
1. slika (CMD) je moj internet
2. slika (CMD) je sosedov internet
Isti PC (samo drug WL omrežje)
oboje je Lastovka Krim.
Ampak mi ni jasno, zakaj prihaja do razlik? Sploh pa mi ni jasno, kako to, da glih pri six.siol.net? Zakaj (če že) ne prej?
DNSji so pr obeh enakih (telesmehovi).
Moj ruter je WRT54GL, sosedov pa pač TP-Link, ki so ga dobili zraven.
- spremenil: Veron ()
No očitno le niso popravl
C:\Users\Administrator>tracert www.google.si Tracing route to www.l.google.com [74.125.39.147] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.1.1 2 * * * Request timed out. 3 9 ms 18 ms 9 ms ce252.t-1.si [77.38.12.169] 4 9 ms 9 ms 9 ms ce3.t-1.si [77.38.11.3] 5 114 ms 111 ms 111 ms 188.64.105.5 6 157 ms 127 ms 130 ms de-cix20.net.google.com [80.81.193.108] 7 133 ms 160 ms 141 ms 209.85.255.176 8 123 ms 125 ms 126 ms 209.85.254.116 9 143 ms 125 ms * 209.85.249.166 10 140 ms 143 ms 128 ms fx-in-f147.1e100.net [74.125.39.147] Trace complete.
Tracing route to www.facebook.com [66.220.158.11] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.1.1 2 * * * Request timed out. 3 8 ms 18 ms 25 ms ce252.t-1.si [77.38.12.169] 4 25 ms 41 ms * ce3.t-1.si [77.38.11.3] 5 111 ms 126 ms 111 ms 188.64.105.5 6 128 ms 127 ms 111 ms 208.178.62.1 7 216 ms 222 ms 226 ms eth1-2.csr2.DCA3.gblx.net [67.16.145.9] 8 213 ms 231 ms 212 ms FACEBOOK-INC.ethernet12-1.csr1.DCA3.gblx.net [64 .215.81.234] 9 232 ms 226 ms 216 ms ae1.bb02.iad1.tfbnw.net [74.119.78.60] 10 208 ms 226 ms 208 ms ae1.dr01.ash4.tfbnw.net [74.119.78.144] 11 210 ms 210 ms 210 ms po510.csw01a.ash4.tfbnw.net [74.119.78.247] 12 224 ms 215 ms 209 ms www-10-01-ash4.facebook.com [66.220.158.11] Trace complete.
gpavlo ::
Lahko tisti, ki imate Lastovko Trojček pogledate na modemu koliko imate razmerje signal/šum (SNR)? Jaz imam okoli 29 dB. IP modema je 192.168.100.1
Real Madrid CF
Veron ::
Downstream
Freq/Power: 378.000 MHz 5 dBmV
Signal to Noise Ratio: 29 dB
Modulation: QAM64
Upstream
Freq/Power: 44.000 MHz 35 dBmV
Channel Type: DOCSIS 2.0 (ATDMA)
Symbol Rate: 5120 kSym/sec
Modulation: QAM16
V-i-p ::
Lastovka dela tudi na 24 in še celo manj, nič bat.
Tilen ::
Naročniki "JACKPOT" paketa preverite svoje položnice. Meni so zaračunali 3x nikoli naročeni HBO Premium ter vsak dodatni TV sprejemnik posebej. Skupaj več kot 15 EUR preveč. Še dobro, da nimam trajnika, ker sploh ne bi opazil.
KuntaKinte ::
meni so poslali ok položnico,mi je pa zablokiralo kartico in že 2 dni gledam temo,oni pa " se kao trudijo",poln kufer jih imam
KuntaKinte ::
tretji dan teme,ker je model zaklenil napačno kartico in cela firma zgleda ne premore modela, ki bi znal to kartico spet nazaj odkodirat,smešno res
JK007 ::
Spc, mi tu jamramo za slabši ping - mi je pa danes na firmi mrknil komplet AMIS-ov internet, telefon, ..
Od 12. ure dalje smo odrezani od sveta ( hvala bogu, da imam doma TM, da lahko vsaj tukaj nekaj naredim ).
Tilen ::
JK007, izpad je bil cca 15 min. Če ti še vedno ne deluje, ti predlagam, da kontaktiraš tehnično pomoč.
Tilen ::
Žal ne drži. Sem z MB in sem v tem času normalno koristil njihove storitve na optiki. Je pa res, da je bil izpad vseh storitev za cca 15 min in da je to tema o Telemachu ;).
Pesimist ::
Zdaj ko telemah kodira kanale. Je kaksna varianta jih spraviti na Pc z DVBC karto? Ali se dobijo kodirne karte za te naprave?
Tilen ::
Te karte imajo v teoriji CI slot v katerega vstavis kartico z modulom enako kot na TV.
- zavaroval slike: Tilen ()
Pesimist ::
pa ponudnik ti mora biti pripravlen prodati karto I guess. Ali celo narocnino racuna zato?
PrimozR ::
A je slučajno prišlo do podražitve? Ker mi smo dobili za 3.0 XL paket položnico za 93 € (~88 za samo naročnino), namesto običajnih 63 :D
Tilen ::
PIPI, zmotili so se in nekaterim zaračunali vsako storitev posebej. Tudi meni.
Pesimist ::
in koliko programov lahko gledas istocasno? vsaj 2 bi rabo.
- spremenilo: Pesimist ()
Tero ::
še komu ful šteka youtube? Vsi videji se izredno počasi nalagajo.
JK007 ::
Na eno naročnino lahko uporabljaš 3 kartice ( ki pa niso zastojn ).
Pesimist ::
Mislim koliko kanalov lahko tista DVBC pc kartica prikazuje istocasno?
Drugace pa na 1 narocnino placujes pol 3x 2€ na mesec za kodirne kartice ali kak?
Sej te ze placas za ta kodiran paket, kaj se te hocejo da jim kavico kuhas.
Spc ::
Jaz uporabljam to:
1: http://www.technisat.de/index9c8e.html?...
2: http://www.dipolnet.com/conditional_acc...
3: DVB Viewer PRO
4: TransEdit
5: Windows Server 2003 R2
Deluje vse tako kot mora.
Toliko koliko tunerov ima kartica.
V mojem primeru enega na kartico.
- spremenil: Spc ()
zdravcc ::
Vidim da imamo tu eni na turnsku podobne tezave glede mednarodne povezave, ta mesec je ping na google vecinoma preko 100 ms, medtem ko je v slovensko omrezje (arnes DNS, siol DNS) okoli ali manj kot 10 ms, obcasno se ze razveselim da so popravili, ko je ping na google 30 ms, ampak potem cez par ur spet skoci na >100ms. Sem klical na turnskovo tehnicno pomoc, pa je rekel da imajo neke probleme z mednarodno linijo in sicer z nekim nemskim streznikom, sicer mi je to tako na priblizno povedal, tako da me ne za besedo drzat, sem vprasal kdaj bodo to uredili, pa mi ni znal na tehnicni nic povedat.
Ker potrebujem net z dobro(hitro odzivno) mednarodno povezavo, razmisljam, da bi obdrzal televizije, internet povezavo pa narocil pri kaksnem amisu, ce ne bodo do naslednjega tedna nic uredili.
Ve mogoce kdo kje bi lahko izvedel, kdaj bo zadeva popravljena, kako bi prisel do kaksnega sistemca pri turnsku, ki bi mi znal povedati kako in kaj?
p.s.
pozabil omenit, na tehnicni pomoci je rekel, da delajo na tem.
p.s.
- spremenil: zdravcc ()
Pesimist ::
zdaj?
P:\>ping www.google.si
Preverjanje dosegljivosti www.l.google.com [209.85.148.106] z 32 B podatkov:
Odgovor od 209.85.148.106: bajtov=32 čas = 29ms TTL=53
Odgovor od 209.85.148.106: bajtov=32 čas = 28ms TTL=53
Statistika preverjanja dosegljivosti za 209.85.148.106:
Paketov: Poslanih = 4, Prejetih = 4, Izgubljenih = 0 (0% izguba),
Povprečni čas v milisekundah:
Minimum = 28ms, Maksimum = 29ms, Povprečje = 28ms
zdravcc ::
ne vem kako je trenutno, ker nisem doma, je pa tako, da je obcasno za par ur ali pol dneva lahko vredu, ampak potem je pa spet vec dni zaporedoma visji ping.
vceraj je bil nad 100 ms cel dan.
Spc ::
Jaz včeraj nisem imel težav:
Tisto kaj je malo višji ping je zaradi uploada.
zdravcc ::
kolikor gledam grafe sploh nisi imel te tezave, zanimivo, jaz imam ta mesec konstantno visok ping. si na turnsku?
Pesimist ::
Kaj je to sploh zaen IP? ker google.si ponavadi rotira IPje anyway.
P:\>ping 74.125.43.106
Preverjanje dosegljivosti 74.125.43.106 z 32 B podatkov:
Odgovor od 74.125.43.106: bajtov=32 čas = 38ms TTL=50
Odgovor od 74.125.43.106: bajtov=32 čas = 39ms TTL=50
Statistika preverjanja dosegljivosti za 74.125.43.106:
Minimum = 38ms, Maksimum = 39ms, Povprečje = 38ms
C:\Users\Pesimist>ping 74.125.43.106
Pinging 74.125.43.106 with 32 bytes of data:
Reply from 74.125.43.106: bytes=32 time=39ms TTL=56
Reply from 74.125.43.106: bytes=32 time=38ms TTL=56
Ping statistics for 74.125.43.106:
Minimum = 38ms, Maximum = 39ms, Average = 38ms
zdravcc ::
zdajle testiral, rezultati podobni kot Pesimistovi... zaenkrat, upam da tako tudi ostane.
