Tezave pri flashanju biosa
igi001 ::
Pozdravljeni
Spet se oglasam zaradi tezav z flashanjem vse potrebno sem potegnil iz epoxove strani pa vseeno ne gre, zato prilagam navodila in prosim ce kdo obvlada stvar naj enostavno napise pot, Ne vem kaj pride za AWDFLASH nek bin file, vendar je potrebno vnesti tudi nekaj na koncu celega ukaza jaz pa imam na razpolago samo ta bin file,poleg teka pa ce sem pravilno razumel hoce vse na zagonski disketi za DOS, vendar ne vem kako narediti zagonsko za dos (namrec tega res ne delam vsak dan) zato se za vse odgovore zahvaljujem.
osnovna epox bx3
The Boot Disk Method
1. Create a bootable floppy disk in accordance with the instructions laid out in the manual of your particular operating system. This bootable floppy needs to be able to boot to a DOS console capable of executing normal MS-DOS batch and executable files.
2. Download the required BIOS image file from the EPoX website.
3. Ensure the mainboard is set at LOAD OPTIMIZED DEFAULTS and is not overclocked in any way.
4. Copy to this floppy disk a copy of AWDFLASH.EXE and also a copy of the BIOS binary image file called xxxxxxxx.bin
5. Insert the diskette into drive A, reboot your system and boot from the diskette.
6. When booting is finished, type awdflash *.bin /sn/py/cc/ (dependant of the name of the BIOS image file) and
7. then press return to run BIOS upgrade program.
The BIOS will automatically flash and reboot the machine.
8. After this, press DEL to enter the BIOS setup and select to "LOAD OPTIMIZED DEFAULTS". After doing this select to "SAVE & EXIT"
9. Please note that this does not create a backup of the BIOS binary file.
10. For Command line help on Award Flash utility, type AWDFLASH/? at the command prompt and press return.
BIOS Image Files
Here you will find downloads of EPoX Europe own recommended BIOS binaries, each recommended for optimum performance, stability and compatibility with each particular mainboard. These BIOS images are all fully supported by EPoX Europe, however may not be supported by other branch offices.
Socket A Slot A Slot 1
boštjan ::
Zagonsko disketo lahko narediš tako da ,vstaviš disketo v disketnik in z desno klikneš na njo. Izbereš FORMAT, pod format options označiš CREATE an MS-DOS STARTUP DISK in klikneš OK. Počakaš da se stvar uredi. pol skopiraš na to disketo program za flešanje AWDFLASH in XXX.bin datoteko(tvoj noviBIOS). Disketo pustiš v disketniku in reebotaš. Greš v BIOS,kjer označiš da je flopy first boot device in se ravnaš še po teh navodilih-(točka 3).Shraniš in počakaš da se zboota iz diskete.Ko konča,pa za flešanje BIOSA vtipkaš:
awdflash xxxxx.bin in to bo flešalo tvoj bios.
Nadalje pa slediš kot je opisano v točki 8
Piskanje kompa in ta se ne prizge!
171908 (1761) Morph3us
Narobe flashan bios na Asus CUSL2-C Black Pearl
222543 (2218) SkIDiver
Bios 8rda+
Oddelek: Navijanje
71340 (1238) kuglvinkl
QDI Kudoz 7x KT400 napačen bios
61854 (1787) kihc
Katero od teh dveh EPOX plat? (strani: 1 2 )
536916 (6280) krucymucy
