720p videopogovor (webcam) na 1080p FullHD zaslonu
slitkx ::
Verjetno je kdo že imel izkušnjo s tem. Je gibanje (oz. slika) na FullHD zaslonu videti zrnato, morda zamegljeno?
Morda kakšna stran s simulacijo?
popster ::
720p preko videopogovara je verjetno itak tko skompresiran da se razlika v resoluciji sploh ne pozna..
slitkx ::
S strani TopTenReviews:
https://secure.logitech.com/en-us/produ...
Pros
The audio and video quality is quite good and this web camera is easy to use.
Cons
This product lacks portability, video effects and desired stills resolution.
Pros
The video effects are so much fun to use and offer a nice way to personalize your communications.
Cons
This camera offers many visual effects but no audio effects, and it lacks wide-screen capture.
http://www.creative.com/mylivecam/produ...
PROS / The webcam includes a noise-reducing microphone.
CONS / The maximum resolution is 720p, which doesn't look as good on full 1080p HD monitors.
https://secure.logitech.com/en-hk/produ...
PROS / The C920 records in full 1080p at 30 frames per second.
CONS / The only way to utilize the full 1080p during video chat sessions is to use Skype
PROS / It is portable and easy to adjust, thanks to its fold-and-go design.
CONS / When recording video, the only way to get a smooth 30 frames per second is to lower the resolution to standard definition.
CONS katere od teh se ti/vam zdi najmanjši pogrešek? In pa mnenje o Creative napram Logitechu?
  • spremenil: slitkx ()
Nikonja ::
Jaz imam Microsoftovo lifecam HD5000 in slika ni slaba ampak ne sanjat o tem da bo kot v filmih, ko gledaš perfektno čisto HD sliko, ker je daleč od tega. 720p bo čist dovolj ampak veliko je faktorjev pri temu kakšna slika bo dejansko poslana po mreži ker se kvaliteta skozi prilagaja stanju na mreži pri tebi in temu na drugi strani.
slitkx ::
Naletel sem še na eno zanimivo - http://store.hp.com/us/en/pdp/hp-hd-431.... 69,99$, v € torej nekaj manj, na Amazonu in eBayu še manj.
Nisem pa ziher glede leče, saj na TopTenReviews piše, da naj bi bil minus te spletne kamere plastična leča.
Ja, jasno mi je, da povsem perfect slika ne more biti. Ampak ravno grainy pa tudi ne bi rad imel.
Moja linija je sicer optičnih 100.
slitkx ::
Nikonja je izjavil:
Sem pogledal novejšo verzijo tvoje, 5001. Je videti kar ok. http://webcam-review.toptenreviews.com/...
Kako se pa kaj obnese v slabših svetlobnih razmerah? Je svetloba belega Skype-ovega okna dovoljo, da se vidi obraz? (Tudi, če je okoli obraza tema.)
Nisem zasledil - ima mikrofon zmožnost zmanjševanja šuma?
slitkx ::
Ni Logitechova, temveč Trustova. Nanjo naletel na strani slovenskega Conrada.
http://www.trust.com/en/product/17676-e... - na Amazonu prevladujejo pozitivna mnenja. Edini downside je, da nima avtomatičnega fokusa, a naj bi se le-tega dalo preprosto ročno nastaviti.
Solidno je videti tudi http://www.trust.com/en/product/18679-t..., le-ta ima avtomatični fokus.
Na Mimovrste 27,40 EUR + poštnina.
Še kdo, ki lahko objektivno primerja vse v tem topicu navedene kamere?
barocco ::
slitkx je izjavil:
si lastim eLight Full HD 1080p Webcam ,že kar nekaj časa,pa sem z njo zadovoljen uporabljam za Skype.Lepo sede na monitor oz. se vpne.
max resolucija je 3840x2160,ni pa neka opazna razlikia med 720p in 1080p.Meni je pomembno edino to da je slika ok ni lagga oz .zamika in pa da lahko snemam..
Zraven uporabljam program WebCam Companion 3.
še sliki z nastavitvami
RangerVIII|6700k|Corsair16GB|
Msi1070|pm961|BX5001TB|RM650x|H100iv2|
  • spremenil: barocco ()
Kamera bistveno manj vpliva kot stopnja kompresije, ki se je pogosto ne da nastavljati, ter pasovna širina, ki je na voljo.
slitkx ::
Pa pri eLight res ni avtomatičnega izostrovanja?
barocco ::
slitkx je izjavil:
Nima klasičnega auto focusa.. se pa slika-ostrina prilagaja glede na svetlobo..
evo ni poslikano z kamero, ampak Prtscr + paint, pa kamera v roki,ki ni mirna :|
Ja ima Reduce Noise..
slitkx ::
Hvala za objavljeno.
WebCam - Ima kdo Logitech C270 ali C310
81750 (1434) Oldi
MP4 video file
121393 (1200) konspirator
Webcam nabija CPU na 100%
174064 (3752) Jablan_Jr
katero spletno kamero
94061 (3771) spirit
Spletna kamera
182905 (2393) imagodei
