Zunanji trdi disk ne deluje
Eva4 ::
Pozdravljeni,
imam zunanji trdi disk, ki mi na Macbook pro-ju normalno deluje, ko pa ga želim priklopiti na windows računalnik, ga ta ne prepozna. Ali mogoče kdo ve kaj lahko naredim, da bo tudi windows računalnik normalno prepoznal trdi disk?
Hvala za odgovore.
dukedl ::
windowsi ne znajo prebrati file systema od osxa:
  • If you are sharing a drive between computers and don't need to use big files, FAT32 works almost everywhere but doesn't support files bigger than 4GB. This is the default for flash drives since it works everywhere.
  • If you do need to use files bigger than 4GB, exFAT works on Windows, Linux (with FUSE), and OS X. This is probably the best choice for a shared hard drive that will only be plugged into a computer.
  • If you are only adding files from Windows and you need to use big files, NTFS works almost everywhere, although is read-only on OS X and doesn't work on some media players.
lp dukedl
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820347 (17187) arrigo
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187286 (7145) ManDriver
CATALYST 3.6
Oddelek: Programska oprema
169019 (8504) freejack
Iščem alternativo vuduju
122451 (2215) Arthur
Program za web server?
92872 (2731) Hojne
