MBProbe kaj pomeni AUX1 in AUX2
StDo ::
Zanima me kaj pomeni v programu MBProbe (program za prikazovanje temperature)
AUX1 in AUX2, Kolikšna je normalna temperatura procesorja AMD athlon 1000Mhz
Duhec ::
Ne ljubi se mi prevajat ...
Q: What's the Aux1,2 reading measuring?
A: It depends on the motherboard. Some motherboards provide a 2-pin header to
connect an external thermistor to measure whatever you wish. If left
unconnected, it could show weird readings like -48°C or 125°C. Disable the
warning in that case.
If no 2-pin header is provided and it shows a sensible reading, then it is
probably an extra motherboard temperature reading.
aux in avto
61193 (1023) TheBlueOne
AUX v USB
55002 (4937) Janac
power/aux
91508 (1065) bow11
mene zanima kaj pomeni power/aux temperatura
52117 (1804) huek111
Power / Aux Temperature
141944 (1714) Silence-r
