Forum » Pomoč in nasveti » Najboljši monitor za oči!
Pr1m3 ::
Kupujem nov monitor pa me zanima kateri je najprimernejši pogoj je predvsem to da je čimboljši za oči pa da ima HDMI izhod vse ostalo mi niti ni tako pomembno sama uporaba ne bo nič zahtevnega.
Budget tam do 200Eur.
ST-777 ::
Anti-Blue Light LED-LCD Monitor Philips 247E6BDAD 24" bi morda prišel v poštev. Lahko pa preizkusiš tudi free programček f.lux, ki avtomatično nastavlja barvo monitorja - hladno barvo podnevi, bolj toplo takrat, ko sonce zaide.
Philips 247E6BDAD 24": http://www.amazon.com/Philips-247E6BDAD...
f.lux: "f.lux makes your computer screen look like the room you're in, all the time. When the sun sets, it makes your computer look like your indoor lights. In the morning, it makes things look like sunlight again. Tell f.lux what kind of lighting you have, and where you live. Then forget about it. f.lux will do the rest, automatically." https://justgetflux.com/
ST-777 ::
Nekaj o tem piše na: http://www.asus.com/Microsite/2015/disp...
"How does blue light damage your eyes?
The cornea, situated at the front of the eye, is a transparent cover that protects your iris, pupil, and anterior chamber. Light passes through the cornea and pupil before the crystalline lens focuses it on the retina.
High-energy blue-violet light in the narrow 415-455nm band is particularly damaging to eyes, in particular the lens and retina. The blue band of the light spectrum yields more energy and can pass straight through your eye – resulting in myopia and macular degeneration. Blue light from monitors may cause eye damage, strains, headaches, and sleep disorders."
ST-777 ::
Pr1m3 ::
Zanima me še v čem je boljši IPS če je sploh? :)
Glede na predloge sem malo naredil izbor na mimovrste ker imam še nek popust pa me zanima kateri od teh bi bi najbolši?
Philipse sem odstranil ker imajo vsi 1 leto manj garancije.
https://www.mimovrste.com/monitorji/ben...
https://www.mimovrste.com/monitorji/asu...
https://www.mimovrste.com/monitorji/lg-...
Mogoče še kdo ve za kak pameten predlog na mimovrstah?
Pr1m3 ::
Kje se pa v sloveniji sploh da dobiti tega Benq-a ker se mi zdi še posebej zanimiv :) ?
bMozart ::
Če je možno kupi monitor z IPS matriko. IPS (očičajno eIPS pri poceni monitorjih) ti prikazuje veliko lepše barve kot običajna TN matrika. Daj monitor z IPS in običajno TN matriko enega ob drugega, ter isto sliko za primerjavo in boš presenečen koliko borje prikazuje barve IPS monitor.
Drugače pa za oči je najbolje, če boš gledal da bo monitor bele oz, sivo-bele barve. Lahko ga pa tudi sam kasneje preštrihaš na belo oz, "oblečeš v belo" da ti ostane garancija (to sem naredil jaz). Razlika je očitna, ko ne vidiš okvirja ko pogledaš stran od monitorja. Če si 8+ ur na dan za računalnikom, se to zelo pozna.
Če monitor uporabljaš še za kaj drugega kot za filme, ti svetujem da kupiš 16:10 razmerje (1920x1200).
Drugače ti pa svetujem da vsake toliko pogledaš skozi okno, ko si za računalnikom, bo dobro dalo tvojim očem. Pa svetilnost si zvečer zmanjšaj in zjutraj nazaj povečaj, to bo tudi dalo dobro tvojemu zdravju.
I NEED The Point of View Gun effectible on girls too! And then...
| » | najmanj škodljiv monitor (strani: 1 2 )Oddelek: Zvok in slika | 10017 (6945) | Gagatronix |
| » | Nakup monitorja (strani: 1 2 )Oddelek: Kaj kupiti | 17680 (7038) | Han |
| » | osvetlitev monitorja in očiOddelek: Zvok in slika | 3837 (3019) | 2dark |
| » | Novi monitor težavaOddelek: Pomoč in nasveti | 1348 (1215) | Machete |
| » | Življenska doba monitorja (strani: 1 2 )Oddelek: Pomoč in nasveti | 10454 (8436) | dela |
