AMD R9 300 series
AMD R9 300 series
2
Kaj ::
Glede na to, da se je zaklenila tema AMD R3xx series in ker se mi zdi, da je taka tema pač potrebna, če ne drugega za primerjavo ali protiutež temi Nvidia GTX 900 series.
Pa dajmo no, naj se pogovor tu res tiče o tej seriji in ne o tem, "kako je nvidia najboljša."
  • zaklenil: bluefish ()
Napajalc ::
Furiji se odklepajo po ustaljeni praksi: r9 fury to r9 fury x , kar zanimiva zadevca.
http://wccftech.com/amd-r9-fury-unlocke...
011011100111010101100010
GenZNPC ::
Opozorilo, preden kdo začne s tem experimentirati in misli, da je ustaljena praksa:
Surprisingly, 'all' actually boots, it shows corruptions under 3Dmark firestrike ultra immediately.
Alright, looks like mine is not suitable for unlock. I get artifacts with _all and either 57 or 59 CU with _high and _low.
Has anyone done a hard shutdown after modding the bios, my pc keeps hanging on boot, something about PCH initialization errors with the card powered up.
Not sure if it's from that or not, I did a shut down and it hung at boot up. Switched to safe bios and got same thing but I didn't quit switching between bios's and just kept trying, probably 5th retry and it booted on modded bios. So be aware all and take caution.
Well mine is dead, did a couple more shut downs and thought all was ok so I tried one more bios flash. Hasn't came back, oh well, who knows why then.
NOTICE THAT EVEN REFLASHING THE STOCK BIOS STILL FAILED WITH x21 ERROR
now im very confused apparently the software say they cores are locked but if i go to mantle on aida they are enable and if i play thief on Mantle i get the same fps as a r9 280x
Večina....
skibidi
Napajalc ::
AMD ima dual bios po večini, panika odveč. Tisti ki nima dual bios rabi pa za vsak slučaj procesor ki ima IGP not (xnon ni dobr), ali dodatno grafično. V nobenmu primiru ne moreš poškodovat grafične kartice.
Mol
A si že kdaj fleshal kako kartico ali samo nadaljuješ rage proti AMD?
Večina se jih da odklenit:
http://www.overclock.net/t/1567179/acti...
  • spremenilo: Napajalc ()
GenZNPC ::
Od mx2 sem flashal skor vsako...
Jaja sej ravno tu, so izrezki, niti več kot pol ne rabiš pogledat
Nisem rekel, da se ne da odklenit !!!
skibidi
  • spremenil: GenZNPC ()
GenZNPC ::
Uporabnik ma pravico izvedeti oboje mar nismo zato tukaj?
skibidi
Napajalc ::
Kratek povzetek fleshanja r9 fury:
Original:
R9 Fury X Stream Processors 4096
R9 Fury Stream Processors 3584
R9 Fury Y Stream Processors 3840 delno odklenjen fury
Z namenskim software dobimo podatke ki so v spodnji tabeli.
Gleda se navpične vrste "X", tisti zamaknjen "X" pomeni da naj bi bil nedelujoč CUs (nekaterim vseeno deluje), odklepajo se po štirje, se pravi v tem primiru se bo odklenilo polovico razlike med fury in fury x. Na razpolago sta dva biosa za tak primer z namenom da odklene prave delujoče štiri CUs.
Najpogosteje se odklepa "polovička", nekaterim celota, smisel ima sprobat tudi "komplet" z "pokvarjenim" CUs.
Fiji-class chip with 16 compute units per Shader Engine
SE1 hw/sw: 00030000 / 00000000 [..............xx]
SE2 hw/sw: 40010000 / 00000000 [.x.............x]
SE3 hw/sw: 00030000 / 00000000 [..............xx]
SE4 hw/sw: 00030000 / 00000000 [..............xx]
56 of 64 CUs are active. HW locks: 8 (R/W) / SW locks: 0 (R/W).
8 CU's are disabled by HW lock, override is possible at your own risk.
Glede na to da morš odklenat vse CUje, se nemorš pogovarjat o napačne CUju. Odklenat morš vse, če hočeš met FURY X.
GenZNPC ::
Eno je odklepanje, drugo pa delovanje.... Vidim, da ima najmanj pol ljudi nedelujoče s težavami, pa še vsaj nekaj jih je brez kakršnega koli boosta, razen v 3D mark.
"I get better 3D mark score, but fps stay exactly the same"
Zato pa piše lepo na koncu: override is possible at your own risk. 90% ljudi sploh neve kaj je to flašanje in kaj narediti, ko več ne dobiš slike bo bootu. Z kakim fxom, ko pa nimaš igp pa si še tolko bolj v dreku.
Potem pa uporabnik pošlje to v garancijo, tam pa bodo vidli neuraden bios na kartici... Žal pa nevem kako je z uveljavljanjem, saj jaz laikom ne priporočam igranja s takimi zadevami.
skibidi
Napajalc ::
Tudi z Fury Y so ljudje zadovoljni, nekaterim se je celo komplet oklenilo. Še enkrat, vsi se odklepajo, se pravi je samo še sreča koliko se odklene in ne "se ali se ne odklene".
Senitel ::
Napajalc je izjavil:
Kako bi po tvoje sploh zgledalo, da se "ne odklene"? Da ti flash biosa faila? >:D
Napajalc ::
GenZNPC je izjavil:
Nevem zakaj ti misliš da se bo flešanja lotil nekdo ki ne razume navodil?
Drugače so tam napisana ljudska navodila za smrtnike.
GenZNPC ::
Recimo, ker nekdo vehementno izjavalja, zagovarja, to ni nobeno tveganje, vse se odklenejo, garancija ostane, vse dela bp ipd. V resnic pa ni tako....
Za tebe je, mene, pa še koga je, to že vemo.
@hojnik
On jo bo kupil, po pascalu 2017, ko bo 300$
skibidi
freesty ::
Mene ne gane vojna AMD - nvidia. Sem bil nahypan, ko sem prebral, da se amdjeve kartice spet odklepajo(je ze kar stalna praksa). Ampak tvojih zadnjih par postov je pomensko identicnih. Nekdo ti da proti argument in ti mu argumentiras z zacetnim postom, to ponavljas dokler folk ne obupa.
Torej, velik procent kartic SE odklene, vendar od teh, ki se odklenejo jih ima tudi dosti probleme oz. nimajo pravega boosta, kar naredi odklep malo nekoristen kajne?
EDIT: Prav pa imas, da ce si ze lastis kartico, da jo probas odklenit, ce se vsaj malo spoznas, ker nimas kaj izgubit. Ceprav je nekdo omenil, da se je tudi po resetu na stock BIOS pojavljal error.
Tako, da nebi ravno kupil kartice z namenom, da jo bom odklenil.
http://www.youtube.com/watch?v=5hfYJsQAhl0
  • spremenil: freesty ()
Epialt ::
Rad bi videl, da se kak heroj najde, ki ima doma 390ko in se malo razpiše kako je iz prve roke kartica.
Kako je z driverji, če igre res vsake toliko crashnejo, če je soba res savna in če imaš doma res delovišče, poleg elekrarne. Hehe.
Prebral sem okoli 100 reviewev, primerjalnih testov z 970 in benchmarkov in je toliko različnih mnenj na internetu, da iskreno ne vem za katero kartico bi se odločil.
Kaj sem zasledil od AMD privržencev:
+ hitrejša od 970
+ future proof.
+ 8gb rama ( future proof )
+ dx12 bo Marija za kartico ( future ... )
+ Malenkost glasnejša ( 1db )
+ Malenkost bolj topla ( 1-5C )
+ Cenejša
+ Boljši p/p
+ coilwhine je pri 970 je bolj pogost
Privrženci Nvidia-e:
- Pri večini iger počasnejša od 970
- Zanič driverji za dx11
- HDMI 1.4
- Precej bolj glasna od 970
- Precej bolj vroča od 970
- Crasha vsake toliko
- AMD ima probleme
- Rebrand
- Useless 8gb rama - ko bo 4k mainstream bodo middle range grafične povozle 390ko.
- 970ka se bolje navija, že samo z sliderji v control centru.
Naj poudarim sledeče: NISEM FAN BOY, ampak trenutno izredno neodločen potrošnik.
Kaj ::
Imam powercolorjevo 390. Dela krasno. Niti enga problema s špili. Gonilnike naložil in pozabil na njih. Vroča ni. Glasna ni. V msi afterburner si nastimas krivuljo, ce ti rpmji ne pasejo. Sam sem dal da pride v igrah do 73stopinj in je ob tem skor neslisna.
Kaj ::
Ps. Če si pogledal toliko testov in si še vedno neodločen, lahko to pomeni le, da sta si kartici tako blizu. Kar sta res si. Očitno (obeh še nisem imel).
Zato pač pretehtaj. Verjamem da z nobeno od teh dveh ne boš sfalil.
če je v igri 390, prihrani denar in vzami 290.
flashas 390 bios pa mas ...
GenZNPC ::
9xx smo lepo potestirali iz prve roke na forumu v različnih temah, lahko se malo razgledaš. 390 slo-reviewe še čakamo.
Kaj je izjavil:
Tak splošen opis velja itak za vsako kartico.
skibidi
markic222 ::
Glede driverjov sem že v prejšni temi povedal ta GTA V crasha na dx 11, pri drugih igrah nisem imel težav. Vsaj meni in še veliko uporabnikov 390-ke imajo ta problem, ki pa bo odpravljen (verjetno) z novimi driverji. Poleg tega so driverji ok.
390-ka ni precej bolj glasna, sicer je pa to odvisno od katerega proizvajalca vzameš (sapphire, powercolor, msi, asus...) vsi imajo drugačne ventilatorje zato so stopinje in glasnost razlikuje. Glasnost je minimalno višja pri 390 v primerjavi z 970. Ne rabiš se obremenjevati da je 8 GB useless, bolje preveč kot premalo :). Sicer boš pa pri vramu res težko šel čez 4GB ker ti bodo že ostale specifikacije kartice ozko grlo.
To da ti bo sobo ogrelo za ne vem koliko stopinj več kot 970-ka pa vzami z kančkom dvoma. Dvomim da bi moja soba imela 2 stopinje manj če bi imel 970-ko, je pa res da nimam nekega jakega znanja fizike. Govorim iz prakse in sam ne opazim razlike v toploti sobe kadar uporabljam laptop ali desktop, kaj šele razlima med dvema desktop grafičnima. Glede dx 12 pustimo času čas, je še prezgodaj za karkoli. Mogoče je iz stališča porabe in toplote za 1080p gaming 970 celo boljši nakup, ker porabi manj elektrike in je malenkost hladnejša za praktično identični performance v 1080p. In ja OC je boljši na 970-ki, ampak navita 390-ka je še vedno na istem oziroma na boljšem.
Itak me bodo zdej vsi spluval zarad tega kar bom reku ampak je 8GB vrama meni nekako pretehtalo (poleg LiquidVR), ker 3,5 GB za triple monitor setup in 1440p gaming po mojem ne bi bil dovolj za dolgo. Ali pač, bomo videli. Odloči se tako kot ti najbolj ustreza in skušaj ignorirat mnenja raznih fanboyov. Malo glej tudi na ceno. Srečno pri nakupu.
  • spremenilo: markic222 ()
GenZNPC ::
Mene zanima, če imaš že LiquidVR, ker gameworks VR driver je že en teden na voljo, da ti je to pretehtalo...
Ko pa primerjaš subjektivno lastnost ala glasnost, me zanima če si imel tudi možnost poslušati kako MSI, Palit 9xx, da primerjaš?
390 je super za 1440p, priporočam
skibidi
Kaj ::
GenZNPC je izjavil:
Kaj je izjavil:
To je točno res. Tako za 970 kot 390. Zelooo dvomim, da če bi mel zdle v kišti 970 namest 390, da bi v praksi opazi/slišal/začutil kakšno razliko. GTA V igram zadnje dni na dnevni ravni po uro in niti enkrat še ni ven vrglo ali kar koli ponagajalo.
Povedati hočem, da razlike ne boš opazil ne z eno ne drugo, pa čeprav nekateri kažejo da so razlike nevenkakšne. Mogoče na papirju. Ko ti bo v nekem trenutku pred nakupom nekaj pretehtalo, se za to odloči, plačaj, sestavi in pozabi.
Par dni pred nakupom sem si tut sam lase pulil in primerjave delal. In vedno bolj dojel, da je oboje isto ok. Zato je pretehtala nižja cena 390ke in problem rešen.
Če si frik glede konstantnega merjenja temperatur komponent in naslajanja ob dejstvu da ima tvoj kartica stopinjo do tri nižjo temp kot konkurenčna, kupi 970, če nisi, prišparaj desetaka do tri in kupi 390.
Ko bo ena ali druga v kišti, boš le še veselo igral. Pri obeh isto lepo. Za 390 garantiram sam, za 970 kažejo testi podobno.
Sem bil lepo diplomatski ne?
markic222 ::
Nope, čakam da bo Oculus Rift CV1 (januar 2016) na voljo za nakup, tako da to takrat mi je praktično vseeno če je na voljo, ker očal nimam. Kolikor sem prej pregledal in prebral naj bi AMD tesno sodeloval z Oculusom in naj bi imel boljšo izkušnjo z omenjenimi očalmi, bomo videli v praksi. Nočem se spustiti v teoretično debato brez dejstev, sej bomo počakali pa videli kako bo, lahko da bo gameworks boljš, we shall see.
Osebno še nisem primerjal hkrati obe kartici, sem pa slišal obe v praksi in nisem zaznal razlike. Tudi na testih trdijo da je minimalna razlika. Si ti obe hkrati poslušal in zaznal razliko?
GenZNPC ::
Ja za take stvari obstajaja čtivo: http://www.tomshardware.com/reviews/amd... slepih testov, če sam neveš
https://translate.google.com/translate?...
Glej, preberi in to je to.
skibidi
markic222 ::
Jaz sem govoril o Liquid VR in ne o FreeSync. Kaj je point tega linka?
GenZNPC ::
markic222 je izjavil:
Najprej preberi ali te ne zanima?
Aja LVR, nevem ne najdem še nič praktičnega na to temo, maš ti kaj? GWVR je pa že tu in lahko najdeš par stvari.
Dobrododošel vsak info iz obeh strani.
skibidi
markic222 ::
Če po pravici povem me FreeSync in G-sync ne zanimata, vsaj ne dokler ne bo zadeva mal bolj mainstream, ker nimam monitorja da bi to podpiral. Malo mi je bedno, ker se moraš potem glede na monitor tudi v prihodnosti odločati katero grafiko boš imel. Rad imam svobodno izbiro :D.
Tole in še nekaj podobnih člankov. Ni pa še nič praktičnega, zato sem tudi rekel da je še prezgodaj da se pogovarjamo kaj bo bolje, ali AMD-jeva ali ali od Nvidie rešitev. V Q1 2016 bomo videli komu je bolj ratalo :)
http://www.tomshardware.com/news/amd-li...
denisbegood ::
A se vsaka 290 flasha v 390? A se potemtakem 290x mogoce v 390x?
S katerim programom se to dela?
Napajalc ::
Epialt je izjavil:
Sprobal 300w porabe v sobi in igral, sprobal 220w porabe in igral, oboje greje zelo podobno, ta razlika je kot bi bil v sobi prisoten še nekdo, se pravi to je pravljica, s tem da gtx 970 kuri do 40w manj. Stvar brezpredmetna.
HDMI 2.0 je brezpredmeten razen če imaš v sobi TV 4k da boš filme gledal, igre tako in tako ni v stanju poganjat ne ena ne druga. Display port je narejen z namenom da zamenja HDMI, se pravi je to trenutna muha ki se jo nVidia ne drži.
To da se AMD driverji sesuvajo je kriv napačen owerclock CPU ali GPU, samo po sebi se ne sesuva, brezpredmetna zadeva.
Owerclock: gledano kot gaming: r9 390 1000mhz stock core, OC 1150mhz gaming oc, ki ne predstavlja extremnih nastavitev = 15%. OC gtx 970 stock ~1200 mhz OC ~1450mhz = 20%, zanemarljiva razlika.
Dejanski minus je lahko samo HDMI 2.0. Poraba: 10 ur na dan igranja, 40w razlike med r9 390 in gtx 970 nanese čez celo leto: ~18e, če igraš 2 uri na dan je to 3.6e, idlate obe dobro. Brezpredmetno
Siguren plus: 8 gb rama, specifikacije ima bolše, to se izraža v precej bljšem computingu, posledica futureprof.
Vzameš r9 390 kot futureprof zadevo.
Epialt ::
But does it clean, iron and wash my dirty socks?
Hehe.
Atm mam nagledano MSI 390 in 970. Pri 390 me rajca še malo njihov backplate. :p
GenZNPC ::
Protiargumenti:
Siguren minus, 3D programi ala maya, 3ds, c4d, acad itn.
Potem je dx12 tudi
Jst igram ene par nezahtevnih družabnih iger na 4K in gledam posnetke z svp managerjem tudi
Zanemarljiva razlika, velja za 4 od 5 kartic in tale oc pride na zraku z sigurnim minusom
Ker je to zanemarljivo je tudi to.
12_1 feature set, zanemarljivo...
skibidi
Napajalc ::
Zadeva ni zrela za 4k, ker so 4k monitorji malo predragi trenutno, za tiste ki forsirajo 4k resolucijo z TV ji ste na žalost primorani uzeti nvidio. Pač se boš mogle zadovoliti z gtx 960 namesto z r9 280x oz z gtx 970 namesto z r9 390.
GenZNPC ::
Fifa, NBA, MK, F1, vsi mal srarejši špili..... zgledajo fenomenalno na 4K@60 TVju za 550€, potrjeno s strani prijateljev...
Nažalost res, bogi smo
skibidi
gddr85 ::
afaik se trenutno hdmi 2.0 nuca samo za 60hz 4k, kdor ima kej takega, rabi nvidio
gddr85 je izjavil:
Kaj pa display port? Ne vem iz prve roke ampak zadeva naj bi podpirala 4k@60Hz.
markic222 ::
Ja, ampak kateri tv pa ma displayport...
Podpira ja.
GenZNPC ::
Odvisno od verzije, nevem katera je. Lahko si tudi kak fini adapter zrihtaš.
http://www.computeruniverse.net/product...
skibidi
Napajalc ::
Za ta denar se vzame 4k monitor.
GenZNPC ::
Lahko seveda 24-28" fajna stvar za pisalno mizo z malo placa v kombinaciji z ITX kišto.
Na TVju bo žogica sicer mal večja in še kdo drug razen tebe jo bo lahko brcal (livingroom gaming), še iz časov 1995 kr kul.
Mal resnične družbe pa to, pogovori, smeh, party.... Z otroci skupaj, trine 1,2,3 4K
skibidi
Napajalc ::
GenZNPC je izjavil:
Za take stvari se vzame konzolo.
GenZNPC ::
Tudi, če pač budget samo to dopušča. Si probal na konzoli 4K@60 ? Kak to gre?
skibidi
Napajalc ::
Ljudje bojo kupovali 4k monitorje ko bo zrelo, in ne 4k TV. Kaj nimaš denarja za 4k monitor? Šparaš na osnovnih stvareh, baje da se celo z video obdelavo ubadaš? in ti to na 4k Tv, tam se pa kregaš kako nekateri top procesorje navijejo in jih zmerjaš z reveži. OMG in tak profesionalizem.
GenZNPC ::
zato si nabaviš multimonitor setup, pa še eno kišto
skibidi
AapocalypseE ::
Nekateri govorijo, če je zdaj 390 bolj primerna za 1440p od 970, da se splača 390 trenutno tudi bolj za 1080p, ker bojo igre vedno bolj požrešne in se bo tista prednost, ki jo ma zdaj 390 pri 1440p začela kazat tudi na 1080p.
Gre verjet temu?
PredatorX ::
GenZNPC je izjavil:
Kaj ti bo 4K trine 3, če navadna GTX 960 tega ne zmore? Še GTX 970 ima okoli 30-35 FPS-jev.
Že spet moliš GTX v R300 serijo.
Mordecai ::
Nevem kaj sploh debatirate med 970 in 390. Očitno je 390 best buy. Trenutno mam 670.
GenZNPC ::
My bad ja, T3 je edin družaben špil
Ja 390 je best buy, itak a ne vidiš "perfect product" ne smeš nič rečt, čez njega. All hail to 390
skibidi
Epialt ::
AapocalypseE je izjavil:
Gre verjet temu?
Dobro vprašanje. Ima kdo odgovor ?
Edini odgovor je, da se r9 390 ne splača, če imaš indentičen čip z 4GB vrama manj za 35€ manj (gledano najcenejše karte).
Kupiš 290, flashaš 390 bios za boljši občutek in si zmagal.
  • predlagal izbris: Mordecai ()
2
Grafična za 300-400 EUR (strani: 1 2 3 4 )
15736948 (28724) iloveboobz
grafična kartica?katero kupiti (strani: 1 2 3 4 … 8 9 10 11 )
507113211 (42887) PredatorX
Menite da je primeren čas za nakup nove grafične? (strani: 1 2 )
559144 (7716) NightHawk
