Žice za povezave z ohišjem in matično
PrihajaNodi ::
Imam sledeč problem in sicer ta da so žice na ohišju označene:
SPK L
SPK L
M IN
M BIAS
SPK R
SPK R
GROUND
Na plošči ASROCK H81M DGS R2.0 pa:
Front panel audio header
MC 2 L
MC 2 R
OUT 2 R
J SENSE
OUT 2 L
GND
PRESENCE
MC RET
OUT
RET
Prosim za nasvet.
Nodi
boogie_xlr ::
Eno je AC97 header drugo je pa HDaudio header. Poglej v BIOS, če lahko nastaviš na AC97 in v priročnik od matične, kako se poveže.
PrihajaNodi ::
1. High Definition Audio supports Jack Sensing, but the panel wire on the chassis mustsupport HDA to function correctly. Please follow the instructions in our manual andchassis manual to install your system.2. If you use an AC'97 audio panel, please install it to the front panel audio header bythe steps below:A. Connect Mic_IN (MIC) to MIC2_L.B. Connect Audio_R (RIN) to OUT2_R and Audio_L (LIN) to OUT2_L.C. Connect Ground (GND) to Ground (GND).D. MIC_RET and OUT_RET are for the HD audio panel only. You don't need toconnect them for the AC'97 audio panel.E. To activate the front mic, go to the "FrontMic" Tab in the Realtek Control paneland adjust "Recording Volume
Našel. Če še komu pride prav
http://www.manualslib.com/manual/547803...
Priklop pinov
131599 (1178) fruc900
V čem je razlika med AC 97 in HD Audio
143022 (2394) PrihajaNodi
problem pri priključitvi audio front panel-a
72963 (2859) ufek
AGP onemogočen - asrock dual939 (strani: 1 2 )
785872 (4943) Veron
