Blue screen BCCode: 3b in BCCode: 19
Manager ::
Pozdravljeni
Soseda mi je prinesla prenosnik in me prosila naj ji rešim težave. Pojavlja se ji napaka kakšno minuto po zagonu.
Na računalniku je nameščen Windows 7 Home.
Opis notebooka:
- ASUS PRO5DI Series
- ASUS Notebook K40IJ/K50IJ Series
- Pentium Dual-Core CPU T4400 @ 2.20 GHz 2.19 GHz
- RAM: 4,00 GB
- 64-bitni operacijski sistem
1. napaka, ki se mi je pojavila (1 od 2 napak);
Različica operacijskega sistema: 6.1.7601.2.1.0.768.3
Področne nastavitve: 1060
Dodatne informacije o težavi;
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF80002BB4B15
BCP3: FFFFF8800249E700
BCP4: 0000000000000000
OS VERSION: 6_1_7601
SERVICE PACK: 1_0
PRODUCT: 768_1
Datoteke v katerih je opisana težava:
C:\WINDOWS\Minidump\031715-110479-01.dmp
C:\USERS\Maja\AppData\Local\Temp\WER-173036-0.sysdata.xml
Blue screen:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you`ve seen this stop error screen, restart your computer. If this screen appears again,follow these steps:
Disable or uninstall any anti-virus, disk defragmentation or backup utilities. Check your hard drive configuration, and check for any updated drivers. Run CHKDSK /F to Check for hard drive corruption, and then restart your computer.
Technical information:
*** STOP: 0X00000024 (0X00000000001904FB,0XFFFFF88008A0D928,0XFFFFF88008A0D180,0XFFFFF880012FD6C7)
*** Ntfs.sys - Address FFFFF880012FD6C7 base at FFFFF88001255000, DateStamp 52e1be8a
2. napaka, ki se mi je pojavila (2 od 2 napak);
BCCode: 19
BCP1: 00000000000000020
BCP2: FFFFF8A00B229930
BCP3: FFFFF8A00B229D40
BCP4: 0000000005410403
SERVICE PACK: 1_0
PRODUCT: 768_1
C:\WINDOWS\Minidump\031715-98327-01.dmp
C:\USERS\Maja\AppData\Local\Temp\WER-213814-0.sysdata.xml
Potem pa se pojavi Blue screen;
A problem has been detedted and Windows has been shut down to prevent damage to your computer.
BAD_POOL_HEADER
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use your safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then Select Safe Mode.
*** STOP: 0X00000019 (0X000000000000000020,0XFFFFF8A00B229930,0XFFFFF8A00B229D40,0X00000000005410403)
Probal sem System Restore na zgodnejši datum pa mi javi napako:
An unspecified error occurred during System Restore. (0x80070002)
Ko prižgem PC se mi prikaže AI Recovery Remind, če hočem Backup-at.
Hvala za odgovore.
  • spremenil: Manager ()
Manager ::
Čao
Najprej sem ustavil delovanje antivirusnega programa (AVG 2015) in se napaka ni pojavljala. Sedaj sem inštaliral Aviro in do sedaj vredu deluje.
Ali je možno, da je bila na Antivirusnem programu napaka ali pa je kje na kakšnem HardDrivu ali grafični kartici kaj narobe?
Blue screen - zakaj?
112080 (1780) BlackCaiman
SSD intel 330 win7 instalacija
81276 (1155) klemen1972
Sesuvanje računalnika
101712 (1508) Mitch
Blue screen problem / windows crash
101189 (1101) Xserces
win 7 bsod - okvara matične ?
122398 (2227) vander
