Win 7 Update KB3033929 fails with error code 80004005
waters ::
Ima še kdo to težavo pri Win 7 64 in kako jo je rešil?
Sicer svetujejo:
1. Open directory where is the file mentioned in the error, in my case: "C:\Windows\WinSxS\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.1.7601.18741_none_b9293c0383618646\winresume.exe"
2. Right Click on the file > Properties > Security > Advanced > Owner > (Set it to your Account) > OK
3. In previous Window: Edit > Add
4. You need to add two accounts
- "SYSTEM"
- "NT SERVICE\TrustedInstaller"
5. Give them both Read, Write, Execute permissions. > OK
6. Now KB3033929 which is one big nightmare should install without any problems and ask you to restart your computer afterwards.
Ampak jaz nimam dualboot z Linuxom.
GTX970 ::
Kaj ima dualboot opraviti s tem ?
edit, našel:
http://windowsitpro.com/patch-tuesday/p...
The issues seems to stem from specific configurations - possibly with systems that dual-boot or that have hard disk partitions that are not enabled. It's still not clear what causes the patch to go haywire or which specific configuration might cause it.
Tudi pri meni stanje ne ustreza zgornjim pogojem (w7 x64).
https://social.technet.microsoft.com/Fo...
Ravno updejtal in je šlo skozi bp, trkam na les.
  • spremenilo: GTX970 ()
dx11 na xp
Oddelek: Igre
234661 (4301) amigo_no1
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485659 (4207) Gray_Warden_
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187286 (7145) ManDriver
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
7110030 (8452) Tilen
nasvet za XP
244282 (3874) [t502]
