Forum » Pomoč in nasveti » kaj to pomeni?
kaj to pomeni?
MrX ::
tole je iz driver destrojerja:
ATI:
1. Unplug nic card or modem from net or disconnect
2. Remove ATI driver from add/remove programs then remove CP from add/remove programs
3. Reboot into safe mode (F8 during boot up)
4. On reboot into safe mode winXP SP1 will auto detect and install drivers. Just let it do its thing. If you can cancel out of the auto install hardware wizard then skip the rest and run Driver Cleaner! If you can NOT cancel out of auto detect wizard then...
5. Navigate to device mgr->display adapter->uninstall and/or remove ATI display adapter but do not reboot
6. Run Driver Cleaner
7. Empty recycle bin and reboot
8. Install the new drivers and control panel
nVidia:
2. Remove nvidia from add/remove programs
5. Navigate to device mgr->display adapters->highlight nVidia and click uninstall or remove but don't reboot
zdej pa ne zastopim kaj morš nardit pod 1. točko.
pa še neki. ko moreš izbrat med ATI in nVidio, kaj moram izbrat? zamnjal bom pa Geforca z Radeonom.
ATI:
nVidia:
BigHugo ::
Izklopi mrežno povezavo (vzami ven UTP kabel) ali izklopi modemsko povezavo.
Po domače povedano, izklopi se iz iterneta.
LP BigHugo
Matek ::
Ja če maš zdej geforce, izberi nvidia, da odstrani nvidiine driverje.
Pod prvo tocko pa kot previ BigHugo, samo povezavo prekines.
| » | OC GURU bios updateOddelek: Pomoč in nasveti | 2761 (2628) | 4ever |
| » | Wireless kartica ne deluje na win 7Oddelek: Omrežja in internet | 2353 (2195) | kratos |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2443 (2288) | jast |
| » | pohitritev dsl ali kabelskega neta v win xpOddelek: Omrežja in internet | 2183 (1921) | BlueRunner |
| » | Zvočna ne dela na XP-jihOddelek: Pomoč in nasveti | 1537 (1485) | mitja01 |
