Forum » Strojna oprema » Nvidia Pascal
Nvidia Pascal
D3m0r4l1z3d ::
Še pred Vego mogoče 1080ti padejo pod 700eur
https://www.mindfactory.de/Hardware/Gra...
Vegi ne kaze prevec dobro, mislim, da ni panike za nvidio.
GenZNPC ::
Ce bo tale karta ranga 1080 ima da bo po enem letu vsaj cenovno premaknila lestvico proti 390eur kot bi se to spodobilo.
skibidi
Spock83 ::
Ne vem. Kupiš lahko v Gigabyte, Asus škatli itd. Zato sprašujem, ker ne vem točno. Rad bi z neta vzel PCB in uplodal na EKWB. Ne da se mi zdaj odpirat grafične.
FE so vse referencne.
Se nekatere AIB so enake FE.
GenZNPC ::
In the meantime
GeForce Experience 3.6 is here, bringing support for recording and broadcasting games with OpenGL and Vulkan like Minecraft and DOOM.
skibidi
D3m0r4l1z3d ::
a bo tudi kaj glede Volte?
BTW, od kdaj ima Palit Galax oziroma kfa2 v lasti
http://www.anandtech.com/show/11326/pal...
Danes zmontiral kfa2 gtx1070. Kar uredu zadeva, velik pospesek glede na gtx970. FC4 DSR 2560x1600, ultra, smaa, nenavita 70-100fps.
Hvala, za 366e na dom se nisem mogel upret.
D3m0r4l1z3d ::
Amazon.fr ?
Da.
AapocalypseE ::
SK Hynix showcases first GDDR6 wafer at GTC 2017
https://videocardz.com/69304/sk-hynix-s...
NVIDIA Announces Financial Results for First Quarter Fiscal 2018
https://videocardz.com/press-release/nv...
Jensen Huang has no office in new NVIDIA headquarters
https://videocardz.com/69312/jensen-hua...
- spremenil: AapocalypseE ()
AapocalypseE ::
Torej Tesla V100 (Volta) za deep learning, with shit loads of computing. 12nm proizvodnji proces.
Volta za nas consumerje torej z GDDR6 rami in 12nm proces. Tole bo sfinjska štala tam nekje ~aprila 2018, I guess.
Heh over 1M+ Cuda Library downloads, pol pa da je zaprto in problem
Jim kaj drugega preostane?
AapocalypseE ::
NVIDIA announces TESLA V100 with 5120 CUDA cores
https://videocardz.com/69378/nvidia-ann...
NVIDIA announces DGX and HGX Tesla Volta computing stations
https://videocardz.com/69400/nvidia-ann...
GenZNPC ::
opensource alternative
skibidi
Volta novice:
https://www.engadget.com/2017/05/10/nvi...
Off topic, to je pascal tema, volta ima svojo.
D3m0r4l1z3d ::
1000 serija je vsak dan cenejša na mf. A je to Vega efekt.
Ne, to je normalen pojav.
GenZNPC ::
D3m0r4l1z3d je izjavil:
Eh to je praznovanje 1. rojstnega dne 1070 in 1080.
Kdor je tako dolgo cakal, bo pac vzel Vego ali pa pocakal do Volte. Kdor pa je lani vzel 1070/1080 pa ma mir se nekaj casa.
skibidi
klinker ::
Samo Nvidio se splaca prodat po 1 letu, ker se prodajo za kar solidno ceno...dodas 100€ in imas enako serijo nove generacije.
Vsako leto dat 100€ za gamerja pa ni neki waw, ko so spili po 40-60€.
D3m0r4l1z3d ::
Regres je padel, dobrih 900eur budgeta se bliska. Še eno 1070 v sli in 1 teden HR morja ali Zotac Extreme 1080ti? Ali mogoče 3 rx 580 v cf in 1200w leadex gold?
Volte še dolgo časa ne bo, Vega bo z normalnimi cenami jeseni, 1080ti se bo še dobro držala, razen če presenetijo, 700eur za Titan Xp killerja.
- spremenilo: D3m0r4l1z3d ()
Ce bo kaj blizu Xp, ziher ne bo 700e, ampak prej 1100.
D3m0r4l1z3d ::
Aib 108ti za 688eur, dual slot, 3 fans Gigabajtka
https://www.mindfactory.de/product_info...
D3m0r4l1z3d ::
Ja, 1080-ke so bile 30% hitrejše od konkurence, zdaj pa so 1080ti 30% hitrejše od 1080 za podobno ceno. Zanimivo, da edino sebi zbijajo ceno, kar bi morala konkurenca delat. Če ne bo Vega 30% hitrejša od 1080ti, bo AMD spet le podoben performance za mogoče, mogoče nižjo ceno, čeprav bo nvidia lažje spuščala cene že zrelim produktom. To bo še zanimivo.
A ti se kar mokro fantaziras, da bo vega 30% hitrejsa od 1080Ti? Bo, domnevna dual gpu hitrejsa za 30%. Ce bo vsaj nekje v istem rangu, tudi cena ne bo sindikalna.
D3m0r4l1z3d ::
Hehe, sam nekateri res sindikalne cene pričakujejo. 30% sem pa jaz omenil, ker tak je trend pri 1070 napram 1080 napram 1080ti.
Cveto ::
BTW, a ima kdo osebne izkušnje, koliko se splača GTX1070 za 1080p monitor? Gledam teste pa je morda res malo everkill, samo če dam recimo vse na max in pol AA, bi vseeno morala biti neka dodana vrednost glede na recimo GTX1060 6GB? Monitor je sicer 60hz, tako da skoz iz 70 na 90fps zame ni neka velika dodana vrednost.
D3m0r4l1z3d ::
Minimalne fps poglej, tam bo 1070 kar lepo v prednosti tudi na 1080p.
AapocalypseE ::
Mam sam 1070 na 60Hz 1080p monitor in ti lahko s prve roke povem, da ni overkill. Sploh, ko AA vklopiš in vse na max., še kako prav pride.
Jaz bi še 1080 Ti dal na 1080p... bi mel vsaj dolgo časa mir.
D3m0r4l1z3d ::
Ja, bi potem z boljšim cpujem še več pridobil.
D3m0r4l1z3d ::
1080ti so že pod 700eur, me prav zanima kje se bodo ustavile pred in po prihodu Vege.
FE 669eur, aib 689eur
