Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
![](https://static.slo-tech.com/stili/avatar_gray.gif)
Vetrolov ::
Mi lahko kdo iz izkušenj pove, če res na ryzen 7000 procesorjih ne deluje ddr5 6400 Mhz? Kot berem je max 6000 Mhz, kar je hitrejše pa se sploh ne zažene računalnik.
Dela že, samo beri drobni tekst:
DDR5-6000 Memory is the Sweet Spot For AMD Ryzen 7000 Zen 4 CPUs (update)
https://www.guru3d.com/news-story/ddr5-...
Random post iz oc foruma, glej sliko zentimings
https://www.overclock.net/threads/amd-d...
Intel ima drugačen način delovanja
Intel tema navijanja ramov, nekje na 8800 MHz so
https://www.overclock.net/threads/offic...
DDR5-6000 for AMD Ryzen 7000 "Zen 4" CPUs already sounds amazing for AM5, with a default to DDR5-5600. Higher frequency DIMMs are supported, however, if you exceed the DDR5-6000 limit, you will be forced to use a 1:2 IFC. DDR5-6400 operating at 1:2 is said to offer poor results and is not advised if you want better gaming performance.
Intel has divided the memory ranks with Alder into two categories: a 2:1 mode known as Gear 2 that is the default for DDR5, and a 4:1 variant known as Gear 4. A 1:1 ratio has the advantage of allowing for reduced latencies and a balanced speed. In contrast, a greater ratio allows for better overclocking and quicker data transfer rates but also results in worse latencies.
- spremenilo: sbawe64 ()
Jaz jih gonim na 6400 (na kakšni kombinaciji lahko pogledaš v zgodovino).
Preveri tudi to, kar pravi sbawe64. Ker to drži.
Jarvice ::
AMD Ryzen 9 7950X3D Memory Scaling Benchmark
https://www.techspot.com/review/2635-ry...
7700X zna konkretno pridobit 6000 CL40 vs. CL30
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
Gigabyte je očitno zaenkrat edini uspešno ukrotil boot time.. 23 sekund in si v windowsih. To je super. Moj AM4 sistem rabi ~19 sekund (pravkar izmeril).
Evo, ravno izmeril, cold start sistema, 23s od pritiska power gumba do windows login screena, nato sem cca 7s po prijavi na namizju.
msi mag b650 tomahawk wifi, bios agesa 1003 (7D75v11), memory context restore (enabled), 2*16 gb rama, m2 ssd, win10.
bios agesa 1005 (7D75v13) -> memory context restore ne dela, dolg boot, cca 1 minuta do win login screena.
Senior Dev ::
Lep boot rekord stari. Me prav ma da bi kupil 7950X3D. A je treba zraven dat kak hud ram za 500€ da ti to tako silno boota v winse?
![](https://static.slo-tech.com/stili/bel_non_grata.png)
Senior Dev je izjavil:
Če s z 7950X3D ukvarjaš z boot time, potem zagotovo nisi kupil proca za to kar je 7950X (3D) namenjen.
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
Jarvice ::
Mr.B, si že slišal za sarkazem?
Ne potrebuješ 7950X3D niti rama za 500 eur za takšen boot time.
Senior Dev ::
Kaj pa za compilanje moje kode? Ponavadi mi traja kakih 15 sekund. Z nakupom 7950X3D in kvalitetnih ramov bi lahko pomoje to spravil pod 10 sekund?
Boot time je praktično neodvisem od CPU in RAM.
Kaj pa misliš, da rabi računat kaj na 8 jedrih z 4 GHz?
Na začetku am5 platforme je ASRock celo lepil na MB listke s približnimi boot časi, več rama -> dalj časa...
Za vse: Senior Dev je trol, če še niste skapirali.
Nazaj na čas zagona: to se bo s posodobitvijo BIOSa porihtalo, brez skrbi.
Jarvice ::
Čudi me samo, da sploh izdajo izdelke s takšnimi boot časi. Saj že sami prej potestirajo zadeve in vidijo te katastrofalne boot čase. Kot, da smo leta 1995 v eri Win 95, da bi se morali pogovarjat o hitrosti boota. Shame....
Senior Dev ::
Sam res, đabe ti 2 sekundi hitrejši compile če pri bootu zgubljaš več kot 4 sekunde. Ni me prepričal tale AM5.
Ponekod (Kitajska) so cene R9 7900X že okoli 420$, kar je celo ceneje od R9 7900.
Ko bodo spolirali BIOS-e, bo karavana šla naprej (z vsemi pripadajočimi ceremonijami).
![:)](https://static.slo-tech.com/smeski/icon_smile.gif)
Ko se ti planeti poklopijo:
oz prava kombinacija plošče, biosa in ramov
128GB DDR5 @ 5200MHz success
https://www.reddit.com/r/Amd/comments/1...
I see a lot of issues running 128GB of DDR5 at full speed on AM5. I've been running my Corsair 128GB of DDR5 at a full 5200MHz XMP profile for months now. It's rock solid and fast as hell.
Gigabyte Aorus Master X670E (bios F8c), 7950X, 128GB Corsair "Intel" RAM (CMK64GX5M2B5200C40)
slika
https://preview.redd.it/1ga3deh4d4pa1.j...
slika
Primerjava cen Zda vs Eu
$189.99 (znižano iz 200)
GIGABYTE B650M AORUS ELITE AX AM5
https://www.newegg.com/gigabyte-b650m-a...
od € 247,30
https://geizhals.eu/gigabyte-b650-aorus...
tečaj usd - euro
https://www.xe.com/currencyconverter/co...
1 USD = 0.922051 EUR
190.00 US Dollars = 175.25881 Euros ($200 = 184.55591 eur)
od € 247,30
tečaj usd - euro
Cena v usa je brez sales tax.
Po GIGABYTE B650M DS3H https://geizhals.de/gigabyte-b650m-ds3h...
nova najcenejša plošča ASRock B650M-HDV/M.2
https://geizhals.de/asrock-b650m-hdv-m-...
Še ena zadeva
Če vam 'Memory context restore' (enabled) še vedno povzroča bsod-je (agesa 1005tm), v biosu najdite
DRAM TIMING CONTROL > DRAM POWER DOWN (enabled).
Vir
Vir
Kje je bilo to rečeno?
Predvsem pa: boš kupil? Ali samo najedaš s svojimi enovrstičnicami, kot ponavadi?
- spremenilo: FireSnake ()
Se nismo na 125 USD. V vsakem primeru je tudi to 2-3x drazje od poceni maticnih plosce prejsnjih generacij.
mahone ::
Precej govoric je bilo o A620 matičnih ploščah z omejenim TDP-jem.
https://www.techpowerup.com/304210/amd-...
Eden izmed korakov k poceni sistemom je bil storjen tudi z RX 6300 karticami za 60$.
Kot kaže so zen3 procesorji več kot zadostni za pisarniške OEM sisteme in ne hitijo z A620, ker še ni realne potrebe.
mahone ::
bedarija ::
itak plate so bile 40€ za prejšno generacijo ne? ene so pa kar zastonj zraven mleka talal.
Ze osnovna matematika ti dela tezave, uporabna iskalcev cen pa je ocitno znanstvena fantastika.
Wrop ::
MB Asus Prime B350-Plus AMD B350 za 86,17 € konec maja 2017 (pol leta po izidu). Če upoštevamo inflacijo je to 100 € danes. Dobro, novejše ponujajo nekaj več. 60 % več za oskubljeno matično? To je pa že nateg.
Kdo ima najcenejše matične LGA1700 ali AM5?
mahone ::
mahone ::
Matične B350 ao bile leta 2017 cca 110-120$ + inflacija je 130-150$
Link 1
Link 2
6. Maj 2017 - Asus Prime B350M-A 82€
V zacetku Julija 2017 so se entry level X370 plate prodajale po 100-150€
Septembra 2017 ppravi computerbase le 230€ https://www.computerbase.de/2017-09/msi...
juli 2017 asus prime 350 120$ https://www.trustedreviews.com/reviews/...
Tako da 230€ + inflacija ...
120$ + inflacija ...
mahone ::
@meho7 mislim, da si nekaj zamešal. Iste firme delajo plošče za Intel in AMD procesorje, featureseti in kompleksnost dizajna pa jih lahko podražijo.
Trenutno je pač tako, da PCIe 5.0 in DDR5 še nista mainstream temveč eksotika, kar ustrezno podraži matične.
Senior Dev ::
Trenutno je tako da se vse preplačuje. Kot vemo je bilo natisnjenega preveč denarja in vsak ima v žepu viške. Zato se nihče ne zgraža nad ploščami po 500€.
Noh ne vem..
Najbolj prodajani procesor je na amaoun še vedno 5600X. Z eno poceni plato za 80€ in rami za 80€ imaš več ali manj rešen problem, razen če ti je fetiš 720p z RTX 4090.
mahone ::
2019 je bil pa pcie 4.0 ter chipset fani
![:D](https://static.slo-tech.com/smeski/icon_biggrin.gif)
In so zaradi tega potem nabili cene platam za 30-40% vec kot je bila prejsna generacija.
Pri zen1 je amd vedel kaksen srot so ti cpuji zato tudi poceni plate. Pri zen 2 so koncno vsaj izenacili performance intela - cene gredo gor.
- spremenil: mahone ()
Senior Dev ::
AMD Ryzen 5 5600X za 140€ in plata za 80€ je še vedno zlati standard za gaming. Zraven pa dodaš kakšno malo rabljeno RTX 3080 za 500€. Komplet sigurno pod 1000€.
Nova 6800XT je pod 600€, tako da nakup rabljene RTX 3080 ? 6700XT je pa pod 400€.
Kakorkoli, biosi za A620 chipset bi naj že obstajali.
https://videocardz.com/newz/asus-a620m-...
A620 bi naj bil malce bolje opremljen z bombončki kot B550, torej tudi 2xPCIe 4.0 NVMe reži.
Če bo TDP omejitev ne piše, če bi bila 125W bi to bilo skoraj optimalno za vse trenutne zen4 procesorje.
Pri 65W bi to bilo neugodno za 3D cache procesorje, kvasigamoreš, tudi takšne kombinacije drag cpu + poceni MB si nekateri privoščijo.
Senior Dev ::
Tudi Radeon RX 6950 XT AMD Edition je 600€ na mindfactory, tako da tudi z novimi komponentami lahko sestaviš kar dobro zverino za 1000€. Govorim seveda za prave gamerje, ki so povečini stari med 15 in 25 let in niso še stari prdci s preveč danarja, ki bi lahko devali 5000€ za škatlo.
Gigabyte Says A New Generation of AMD Ryzen Desktop CPUs Will Be Released Later This Year
https://wccftech.com/gigabyte-says-a-ne...
scipascapa ::
689 + ptt....ampak ja ugodno.
