AMD ZEN - nova X86 Jedra
128 gb rama...in shit hitrosti
link iz https://slo-tech.com/forum/t633550/p785... (https://www.overclock.net/...) me je vodil do https://forum.level1techs.com/t/7950x-i...
kjer je nekdo dal link do 24 oz 48 Gb ramov
https://www.gizmochina.com/2023/01/18/m...
Jan 18, 2023
Micron, a leading supplier of memory and storage solutions, recently introduced new DDR5 memory modules in 24GB and 48GB capacities. The modules are compatible with AMD EXPO and Intel XMP 3.0 profiles, making them easy to set up and use with desktop PCs running the AMD Ryzen 7000 series And Intel 12th and 13th Gen Core processors.
Micron's new DDR5 memory modules feature 5200 MT/s and 5600 MT/s data transfer rates and CL46 latency at 1.1V. DDR5-5600 DIMMs come in traditional 8GB, 16GB and 32GB versions, but the new 24GB and 48GB models stand out because they're based on 24Gb memory chips, while traditional Dimensions may use 16Gb DRAM ICs. Meanwhile, DDR5-5200 modules are only available in 8GB, 16GB, and 32GB sizes.
Za veliko premetavanj podatkov raje appla !
  • spremenilo: sbawe64 ()
sbawe64 je izjavil:
FireSnake
Evo, na msi je temperaturna opcija v:
overclocking, advanced CPU configuration, AMD overclocking, Precision Boost Overdrive (advanced) -> platform thermal throttle limit (vpišeš npr. 85).
Najlepša hvala za tole.
Ob priliki pogledam.
In bom primerjal kaj se bolj obnese: manjšanje TDPja, manjšanje MAX temperature ali kombinacija obojega.
sbawe64 je izjavil:
Enota temperature je v celzijih !
Asus plošča
To bo to ;)
Senior Dev je izjavil:
Za kako resno delo pa se bolj uporablja Intel.
Izvoli v intel temo.
Sploh glede na to, da si par let v jami prespal ;)
scipascapa ::
Update:
boota na 4200, 4400 no go.
zdaj testiramo na 4000 ramtest pa to.
samo je preveč nastavitev v biosu, ko bi jih človek 1/2 razumel.
En tip iz level1tech foruma teme (link od prej)
128 GB rama (4*32)
✓ ki mu delajo na 6000 MHz
ampak to še ni vse:
✓ skupaj je uporabil 2 kita različnih proizvajalcev :))
✓ en kit je single, drugi double rank :))
Definitivno Chuck Norris.
Drugače vsi ostali nesrečniki z Am5 poročajo, da je maksimum 4800 MHz, vendar se je potrebno ročno poigrati z latencami in voltažo rama, da tisti ruski 'testmem v5' program dela brez napak.
testmem v5
https://www.overclock.net/threads/memor...
FireSnake
Misliš da trenutni cooler zavira polno delovanje procesorja ?
Sam bi nastavil samo temperaturno omejitev na 85C.
Tudi zato:
Ali izklopi obe oc funkciji (pbo in cpb).
Čeprav na porast temperature dosti bolj vpliva cbp.
Z postavljanjem krivulje pri pbo v minus (negative) nižaš voltažo procesorja in s tem temperature.
Ali izklopi obe oc funkciji (pbo in cpb) ter pbo krivulja v minus.
pbo advanced, cbs (cpb) off
ter še pbo curve -15 all cores (na pamet številka)
(-30 je idealno, koliko v minus greš lahko je odvisno od same kvalitete CPU, silikon loterija).
Ter nato potestiraš stabilnost delovanja z occt.
Ps
Za špase z 128 in več rama ima AMD Threadripper platformo, kamor lahko obesiš do (skoraj) 1Tb rama:
https://forum.level1techs.com/t/5995wx-...
Kjer verjetno tudi niso tako omejeni s memory channels, ki jih pri am5 zapolni že par jeder:
Tako da jih (AMD) (ne)delovanje am5 v robnih primerih ne zanima, niti nočejo sami sebe skakati v zelje (Threadripper platforma).
sbawe64 je izjavil:
Ps
Z790 tudi podpira samo 128GB spomina.
Pa sem preprican da je enaka tezava.... v specifikaciji pise 2Dpc 2R max 4000+. Plus je ?
Recimo strix z790 gaming wifi... pa je isto max 2x 32GB oziroma 4x 16Gb v memory compatibility. prvi google zadetek z 128GB ne pride nad 5000.
  • spremenil: Mr.B ()
sbawe64 je izjavil:
FireSnake
Tudi zato:
Za hlajenje: ne, NH-15 je več, kot kos nalogi, ki jo opravlja.
Za zdaj imam nastavljen TDP na 65W -sem gledal koliko moči izgubim in je skorajda zanemarljivo.
PA voltage offset imam tudi nastavljen. A sem pozabil koliko :)
Hvala za tale info. Če so drugi pred mano preizkusili ne bom odkrival tople vode. Bom nastavil in potem samo še fine nastavitve.
Mi bo prihranilo ogromno časa.
Je pa res, da so temperature na 65W tdp že takšne, da trenutno nima smisla omejevati glede na temperaturo. Igrovje krepko pod 70°, kar je milina in (pomembno) tišina.
Kompajlanje kode pa tako ali tako ne obremeni procesorja dovolj dolgo, da bi bilo omembe vredno (MS Visual Studio 2022).
scipascapa je izjavil:
Update:
Drži.
Včasih so bile 3 do 4.
Zdaj jih je toliko, da bi lahko doktorat iz tega naredil.
Obstaja pa Ryzen kalkulator, ki podpira "lenobo" na način, da ti pokaže koliko zadevo zategniti.
Ram oc
Osnove so še vedno enake, začneš pri primary timings, vse podrejene na auto in testiraš.
Nato secondary ...
https://docs.google.com/document/d/1yIZ...
DRAM Calculator for Ryzen
https://www.techpowerup.com/download/ry...
Mr.B je izjavil:
sbawe64 je izjavil:
Ps
Res je, 4600/4800 Mhz je meja hitrosti rama (4x ) pri sedanjih intel/amd desktop sistemih.
Poleg tega imata oba enake memory channel omejitve, samo 2 kanala.
Koliko pa je razlike med default in temi custom nastavitvami? V performansah, moči, temperaturi?
scipascapa ::
računaj 4000 - če imaš 5600....nekaj je....bi pa moral dejansko stestirati 2x32gb kombinaciji in zapisati 4000 vs 5600.
Pri večjih količinah DDR5 že nagaja fizična oz. fizikalna zahtevnost, ne vem, kako bodo zaobšli ta zid.
Po drugi strani zgleda, da 2x16GB 1R še dovoljuje precej visoke frekvence.
Zaradi mene se lahko DDR# tempo malce umiri in se spet začne delat na optimizacijah, kjer je to smiselno.
Mark my words, veliko lažje in hitreje je izpeljat neoptimiziran projekt z memory leaki, kot pa spoliranega. :P
Meni razlagajo, da so 256GB serverski dimmi že stestirani in na voljo za naročit. Še ne vem, če jih bom vzel ...
scipascapa ::
pa bo to za consumer nivo?
Ne.
128 GB rama (4*32)
in Cinebench 23 single/multi je šel skozi (2x cca 12 minut)
I found some crazy cuckoo bird on the AnandTech forums who got 4 sticks of 16gb stable at 6000.
He did this using two different vendors! 2 sticks were Samsung and 2 were Hynix.
https://forums.anandtech.com/threads/ze...
memory benchmark ddr4 vs ddr5
5900x 4x32GB at DDR4-3600 vs 7950x 4x32GB at DDR5-4800
128gb issue, dela na 5400 Mhz
I’ve managed to achieve stable 128G four DIMM DDR5 performance at 5400MHz. I believe bus termination setting tweaks are part of my success.
More information is available in a overclockers com forum thread titled “Four DDR5 DIMM stable settings and performance results (not questions)”.
https://www.overclockers.com/forums/thr...
rami:
Two G.SKILL Trident Z5 Neo 64GB (2 x 32GB) F5-6000J3040G32GX2-TZ5N provide the 128GB.
od taistega avtorja (kc16)
WARNING: Only try using my exact settings if you have VERY similar hardware.
Suggestions:
First test one pair of DIMMs and confirm the pair works at rated (e.g. EXPO) settings. Save settings info (for later reference).
Remove first pair, and do same with second pair.
Go back to defaults and then populate all DIMMS.
Before increasing clock rates and while still at conservative (e.g. default) speeds, change the Rtt*, *Ds, *Odt settings. The overlockers forum thread provides two bus configuration sets that worked in my system. I suggest trying the 3/5 bus configuration settings first.
Pick the voltages your willing to apply to your components and apply them.
Assuming system happily boots with adjusted bus configuration, start increasing clock rates but leave timings at conservative (e.g. Auto).
After identifying a clock speed your memory, CPU, motherboard works at stably, start adjusting memory timings. Many on line resources exist for those tweaks. For values specified as clocks, a setting sanity check would be; CurrentClockSpeed/ExpoClkSpeed*ExpoSetting. Start on the conservative/slower side of the sanity check value.
My PC ran Aida64 overnight with CPU, cache, and system memory enabled. I ran slightly slower setti
Wrop ::
Ne. Teoretično bi bilo možno 2R 16x4gb. Kar znese 32 čipov po 4Gb. Torej 128 GB. Ampak tega pri UDIMM ne bo.
Imam en barebone pc in ko ga priklopim mi samo piska in nič slike ne da iz sebe. Kaj naj bi en dolg pisk pomenil?
ECS barebone
2200G
8gb rama
Še not nisem dal diska, ker samo piska.
Senior Dev ::
Tukaj si malo preberi:
Morsejeva abeceda @ Wikipedia
mtosev je izjavil:
ECS barebone
2200G
8gb rama
Ram ali plošča
https://brebru.com/beepcodes.html
A quick look at MSI B650 BIOS features - PBO thermal limt and Config TDP to Reduce Ryzen 7000 Temperature. High Efficiency Mode for better DDR5 performance [MAG B650M MORTAR WIFI]
https://www.reddit.com/r/MSI_Gaming/com...
notri zajeto:
1. PBO Thermal Point 85°C/75°C/65°C to limit the Ryzen 7000 temperature
2. Config TDP - Choose Eco Mode 65W and TDP 170W/125W/105W/95W/45W from MSI BIOS
3. PBO Enhance Mode + Thermal Limit
4. Curve Optimizer - Undervolting Ryzen 7000 Processors
5. High Efficiency Mode for RAM
zelo obetavno kaže
Current state of AM5 motherboards after latest agesa 1.0.0.5C bios update - users opinions
https://www.reddit.com/r/Amd/comments/1...
NOT
Biosi z AGESA 1.0.0.5 , predlagam obvoz, Memory Context Restore issue (asus, msi, Gigabyte X670E Aorus Master, za ostale (asrock) ne vem).
Sem vzel en so dimm ram, da vidim, če je to problem.
Am5 platforma je polna presenečenj:
Uporabniki am5 7xxx serije z X pravijo, da se z uporabo ločene grafične kartice dosega boljše OC.
https://community.amd.com/t5/processors...
Notice I'm using integrated graphics
Also if you run any overclock/undervolt or other tuning, I have noticed IGFX does not like them... When I ran this computer with dedicated GPU, I could lower voltage curve a lot and get more performance. Now that I temporarily use IGFX, I can drop curve only a little bit or there is instability. LevelOneTechs mentioned something similar in some youtube video.
Hehehe, tole bo še zanimivo.
Sem mislil nadgraditi BIOS, bom raje še malo počakal.
Zadeva je tako ali tako stabilna.
Za vse biose z agesa 1.0.0.5 bi jaz naredil obvoz.
Bios z agesa 1.0.0.3 dela ok.
Kako pogledati verzijo agesa ?
https://botflakes.de/asrockwiki/docs/to...
Ryzen SMU Checker [AM5] - Checks your BIOS files and gives you some helpful information (Free)
Šel preverit, 7-zip (benchmark) in Cinebench 23 multithread, uporabljam igpu preko hdmi, 1920*1080 ločljivost monitorja (1x) (dodatne grafične nimam, da bi testiral kako deluje z njo), za referenčne številke sem za 7-zip vzel
https://www.techpowerup.com/review/amd-... , za Cinebench score 14000.
Bios nastavitve:
pbo on (advanced, minus krivulja za vsako jedro posebej, da je stabilno v occt), cbs (cpb) on, Tmax na 85C,
rami na 6000 Mhz 1.35V, cl30 36 36 76 115
Rezultat: dosegam cca 8% nižji score v Cinebench ter pri 7-zip decompress, pri compress je primerljiva številka.
Tudi če odstranim Tmax na 85C ni nič drugače.
Tu imajo naveden celo 15000+ za Cinebench
https://nanoreview.net/en/cpu-compare/a...
Drugače se največji boost čuti, ko dam rame iz 5600 na 6000 MHz.
Fclk = 2000 Mhz
Uclk = memclk
To med 6400 (trenutno) in 6000 moram jaz še preizkusiti.
Čeprav ne verjamem, da bo nižanje prineslo boljše rezultate.
Sporočim, ko probam.
MrStein je izjavil:
Tabela na 5:18
CPU: 7700X
Povezano:
Za katero jedro je bilo premalo voltaže
(Curve optimizer, per core)
18:22
AM5 AGESA 1.0.0.7 is expected to support "non-binary" 24GB/48GB DDR5.🧐🧐🧐
Non-binary DDR5 already supported on Intel 600/700 series motherboards.
https://twitter.com/i/web/status/163380...
there is a new agesa 1.0.0.6
za asus
https://twitter.com/johnnync13/status/1...
https://tweakers.net/nieuws/207404/am5-...
holly shit
https://twitter.com/ghost_motley/status...
I hope MSI update soon, my B650M MORTAR take around 39 seconds.
If I enable memory context restore, BSOD instantly in Windowe.
At least you dont get a corrupted cmos. I know of 2 @ASUS X670E extreme's that sometimes just corrupt the cmos during the memory test. The support was bot able to confirm this, as its not reproduceable. Now i have to reset cmos every couple of weeks xD
Amd in šivilja Klara (podnevi šiva, ponoči para)
https://twitter.com/GassyJr/status/1633...
Have you guys tested this with the B650E PG-ITX? I'm on 1.18 with mine and the only way to achieve fast boot times is running my RAM at stock speeds. Enabling EXPO still gives me about a minute to get into Windows. And I have to disable memory context restore to use EXPO.
scipascapa ::
Tok enih nastavitev, pa kdo bo to znal?
DeeJay ::
Kje so časi, k si rabu v bios it samo 1x, ko si sestavu PC... No mogoče še, če si kej kasnej nadgradil. Boot time je bil pa max 15 sekund.
Zdej morš pa skoz neki prčkat po 1000 nastavitvah, boot time je pa minuto lol. Tole vse skup postaja en slab Android :P
Očitno bom še mal počaku z nakupom nove škatle, tolk da popravjo vse tele alpha verzije izdelkov. Ne mislm dat 3k€, da bom pol porabu ure za troubleshooting in beta testing.
Don't f with me.
Jarvice ::
Saj v bistvu ne rabiš. To kaj delajo tukaj so geek zadeve.
Samo XMP enablaš v biosu in save and quit, to je to.
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
Jarvice je izjavil:
Sure, zen 3/4 je zelo izbirčen glede ram timingov.
In xmp ima podtiminge praviloma nastavljene malo drugače kot expo.
DeeJay je izjavil:
Očitno bom še mal počaku z nakupom nove škatle, tolk da popravjo vse tele alpha verzije izdelkov. Ne mislm dat 3kEUR, da bom pol porabu ure za troubleshooting in beta testing.
Se boš načakal
https://forum-en.msi.com/index.php?thre...
Plošča stane od 509
https://geizhals.de/msi-mpg-x670e-carbo...
Mogoče je na oni za jurja kaj boljše.
AMD bi lahko za Am5 platformo kopiral slogan od ms win 10/11:
Always beta.
Gigabyte je očitno zaenkrat edini uspešno ukrotil boot time.. 23 sekund in si v windowsih. To je super. Moj AM4 sistem rabi ~19 sekund (pravkar izmeril).
Trenutno je situacija taka, da na biosu z
AMD AGESA 1.0.0.5 samo na ASRock ploščah dela spodobno hitro.
Na zgornjem testu so verjetno testirali z
AGESA 1.0.0.3 ali 1.0.0.4
, vsaj če gledam datume izdaje biosa za prvo ploščo
https://www.gigabyte.com/Motherboard/B6...
F4 ... 2023/01/19 ... AMD AGESA 1.0.0.4
F4c ... 2022/11/14 ... AGESA 1.0.0.3 Patch D
Pred časom je tekla debata o zen4 APU-jih. Bila so celo mnenja, da je AMD zaključil debato s svojim skromnim gpu-jčkom na I/O čipletu.
Izcurljali so prvi primerjalni testi in AMD-jev igpu je na ravni GTX 1650, kar sploh ni tako slabo.
https://wccftech.com/amd-radeon-780m-rd...
Zaenkrat zgleda samo za prenosnike, kot zanimivost, 'cpu' bi naj podpiral celo LPDDR5X-7500...
mahone ::
Ni namen R9 7950X3D, da bi bil 100% optimiziran za igrice, ampak bolj zato, da ne rabiš dveh konfiguracij, ene za igrice in ene za produkcijo.
Jarvice ::
AMD Ryzen 7 7800X3D is up to 24% faster than Core i9-13900K in gaming
https://videocardz.com/newz/amd-claims-...
mahone ::
Zdaj vsaj vemo zakaj je launch 1 mesec pozneje :))
Malo sem iskal primerjave 6000 RAMov in 6400 na seriji 7000, pa na prvo žogo nisem našel dobrega testa.
Tole:
https://www.techiesmag.com/best-picks/b...
je samo kup besed brez konkretnih testov in številk.
Bom še iskal (na telefonu ne gre najbolje).
Mimogrede, tole je pomemben graf:
Vsaj zame.
Jarno je izjavil:
Pocasi iGPU postaja realna opcija za gaming z znizanimi nastavitvami.
FireSnake je izjavil:
Vsaj zame.
Koliko % ti je padel čas za kompilacijo od prejšnjega 5900x ?
Senior Dev ::
Pomoje prihrani okoli 4 sekunde tedensko. Čas je denar pravijo.
Potem pa porabi dnevno 4 ure na forumu in je vsa optimizacija brezpredmetna.
sbawe64 je izjavil:
Vsaj zame.
5900X sem prodal takoj po tem, ko sem prodal 3090 - v času največje kripto norije.
V vmesnem času nisem imel projektov zato sem komot shajal s 5700G (bi se pa tudi s tem dalo shajati).
In na tej platformi sem čakal 7000 serijo, za katero sem vedel, da bo imela vgrajen grafični čip. Denar od prodaje sem imel pa na kupu - na koncu se je izkazalo, da skupaj z grafično in novo AM5 + DDR5 platformo ne rabim zapraviti vsega denarja od prodaje 3090. S tem, da "star" hardver še vedno imam.
Roko na srce časa kompajliranja nikoli nisem meril. Ko delam, delam. Potem grem pa stran. Za dejavnosti, ki jih počnem zraven službe, bi rad pokuril čim manj časa in končal čim prej.
@Senior Trol:
če bi jaz bil ti, bi se bolj pametno pogovarjal:
https://slo-tech.com/novice/t812475/p78...
ker droge so začele dodobra kurit tvoje možgane:
https://slo-tech.com/forum/t812562/p785...
  • spremenilo: FireSnake ()
dolenc ::
Časa ne meriš, ker ni problem pri tem kar delaš.
So taski, kjer greš v trgovino vmes ali spat. Neko kompajlanje to ni, nikol ni blo in nikol ne bo.
In kaj želiš povedati?
Da compile time ni pomemben, ali kako?
Rendanje traja dolgo (hkrati je to druge vrste delo), a se naredi enkrat.
Kodo se pa poganja praktično vseskozi.
Zdaj, če to ne traja tako dolgo, da bi vmes šel v trgovino je pa nepomembno?
Saj ne vem, če sem te čisto prav razumel. Glede na napisano ne verjamem, da si kdaj koli programiral.
dolenc ::
Kača, a si 13 letna deklica, ki se proba na forumu, kjer je itak 80% uporabnikov programerjev, pohvalit s tem da programira?
Kompile je hitra operacija, če že mal potraja je prvič, potem je to pač praktično stvar sekund.
V primerjavi z urami, ki jih skuriš ko delaš ponovem prepis svoje kode, ker si v prvo naredil bolognese.
Še odzipavanje špila, ki si ga snel s partisa traja dlje. Še clo boot time, če imaš am5. Praktično vse čakaš dle kot compile.
Drži, da je stvar sekund. A zame je pomembno koliko sekund. Čim bolj mora letet.
A boota se 1x na dan (ali pa še to ne).
Tukaj je vse prej kot 80% programerjev. Nasprotno, niti 20% jih ni. Ampak to je že druga zgodba, ki ne spada sem.
599 / 625
