Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
![](https://static.slo-tech.com/stili/avatar_gray.gif)
Jarvice ::
AMD chipset drivers feature special game optimizations for Ryzen 9 7000X3D CPUs
AMD Ryzen 7000X3D processors equipped with 3D V-Cache will automatically optimize performance depending on a workload. The newest chipset driver will be able to dynamically allocate which core is to be used by the Windows operating system. In other words, if the workload is cache-sensitive, the operating system will be modified to prioritize cores with 3D V-Cache. If frequency is more important, cores with higher frequency will be chosen instead.
https://videocardz.com/newz/amd-chipset...
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
scipascapa ::
Nekaj ne razumem
https://rog.asus.com/motherboards/rog-s...
Piše 128GB, a 4x32GB ne dela....Bios zadnji.
Katera osnovna plošča preverjeno dela 100% 4x32GB?
RedDrake ::
Memory controller je v CPU-ju.
Ne vem koliko ima plata veze tu zraven.
Lahko da se motim, a nekako dvomim.
Veliko se je tudi pisalo o silicijevi loteriji pri AM5 CPU-jih - mogoče je to vzrok?
- spremenil: RedDrake ()
_Denny_ ::
128GB s 4x32GB bi naj bilo skoraj nemogoče, če že uspeš spraviti čez post, pa so hitrosti pod 4000MT/s.
Zaradi tega sam odlašam z nabavo 7950x dokler ne bo 2x64GB 6000MT/s kitov...pred kratkim so se sicer pojavili "čudni" 96GB (2x48GB) kiti, ki pa jih zaenkrat žal podpira samo Intel.
RTX 2070S 8GB, 2TB Kingston KC3000, 2TB ADATA SX8200 Pro, 4TB Micron 5200
Seasonic Focus Plus 850W, Corsair Air 540, Logitech Z-2300, Samsung UE65H6400
Pravilno!
Naj porihtajo porodne krče, šele nato glasovanje z denarnico.
Pa si kaj pogledal benchmarke? Praviloma še vedno hitrejši oz. on-pair z i9.
Upoštevati moraš, da afiniteta jeder ne izklaplja drugega CCD-ja, ampak zgolj prioritizira CCD z 3D cachem.
Jedra pri drugem CCD-ju imajo načeloma na voljo več in manj obremenjen memory bandwidth, zadeva pa funkcionira.
mahone ::
Se vedno ima samo 6jeder s 3d vcache v primerjavi z 7950x3d ter 7800x3d. Se ti ne zdi malo cudno zakaj ni nikjer nobenih revieweu za 7900x3d ceprav sta izsla istocasno z 7950x3d? GN ga je celo moral sam kupiti.
mahone ::
Torej prakticno 6 core pri gamingu?
fail
PS: in recimo R5 7600(X), samo 0 jeder za gaming? Ne gre to tako...
Ker tech reviewerje posiljajo sample ce se nisi ugotovil.
Linusi so recimo poslali pokvarjen 7950x3d
Če so to dejstva, ki vplivajo na vrednostno sodbo R9 7900X3D...
Zadeva je pri gamingu primerljivo hitrejša od R9 7900X in pri porabi tam z R7 5800X3D.
Procesor je glede na to, da še lahko popravijo thread scheduling...v skladu s pričakovanji.
_Denny_
https://slo-tech.com/forum/t200222/p785...
Plošča
https://geizhals.de/asus-proart-x670e-c...
Rami
https://geizhals.de/corsair-vengeance-s...
Zadnji (beta) bios tudi ni vedno najboljše.
scipascapa je izjavil:
Nekaj ne razumem
Plošča
Rami
- spremenilo: sbawe64 ()
Dejstvo je da bos placal skoraj 700€ za 6jedrni 3dchip
Na MF so jih prodali že preko 300. Načeloma se vsak sam odloči, če bo kupil.
Dobiš pa R9 7900X MT performans pri nižji porabi in i9 13900K gaming performans.
Torej, ni se dobro preveč sekirat, kaj počnejo in kupujejo drugi.
Sploh pa bo samo za igranje malce kasneje tukaj R7 7800X3D in ni vrag, da bo kdaj tudi cenejši, kot pa ob splovitvi.
Sem se igral z occt 11.0.21 https://www.ocbase.com/download/edition... :
pbo on (-30 curve), cbs (cpb) on , (rame sem dal nazaj na 5600 Mhz 1.25V expo)
ni šel skozi
sem nižal do -25 (all cores), potem je delovalo brez crasha.
Nato spremenil v biosu na posamezno jedro, in poiskal za vsako posebej (trial & error), najprej dal za c0 na -25, če je bil crash spustil na -20, drugače dvignil na -27, za vsa ostala jedra pustil na 0, in tako do konca,
(occt, cpu, threads -> advanced core #0...5),
da je stress test šel skozi brez crasha in napak (ko je bila krivulja za posamezno jedro previsoko postavljena je bil crash sistema zelo hitro, ko sem se bližal sweet spot-u jedra je crash izginil in so se začele pojavljali napake (error in core X).
Vse skupaj je kar trajalo, da sem za vseh 6 jeder našel meje krivulje (2 uri ?).
Povprečni (average) odmik vseh jeder znaša 24,67 , mediana znaša 25,5 , najslabše jedro -16, najboljše -30.
ni šel skozi
Dejstvo je da bos placal skoraj 700EUR za 6jedrni 3dchip
Ja, draga zabava za gamerje.
5700x za 187 eur. plata za 150 eur in 2*16 gb dd4 3600 rami za 80 ter spodobna grafična (obakrat ista)
vs
7800X3D za 700, plata za 250, 2*16 gb ddr5 6000 rami za 150 ter spodobna grafična (obakrat ista)
am4 vs am5
suma 417 vs suma 1100
Koliko bo že razlike v fps (min, max, ave, median)
![:P](https://static.slo-tech.com/smeski/icon_razz.gif)
btw, namig za vse, ki ne vedo, katero ploščo izbrati
https://www.ocbase.com/benchmark
izbereš cpu (ali družino), in pogledaš katere so uporabljane pri posameznih uporabnikih.
scipascapa ::
Zakaj proizvajalci osnovnih plošč napišejo tole:
https://b2b.elkotex.si/asumb-rogsx670ee...
4 x DIMM, Max. 128GB, DDR5 6400+(OC)/6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800 ECC andNon-ECC, Un-buffered Memory*
potem pa med listo kompatibilnosti niti duha ne sluha o 4x32GB.
_Denny_ ::
Že od časov Athlona 64 so memory controllerji v procesorju, zato gledaš datasheet le-tega. Pri plošči ti pišejo samo max. velikosti in frekvence, nič več.
https://www.amd.com/en/product/12151
Pusti frekvenco na default 3600 in bo šlo. Če slučajno nisi spremljal zadnjih nekaj strani te teme (oz. novic glede AM5 na splošno) - pripravi se na to, da boš po vklopu kakih 10-15min gledal v prazen ekran preden se pokaže čisto prvi bios screen. To, da se 3s po pritisku na power ne prikaže nič še ne pomeni, da ne dela.
System Memory Type DDR5 Memory Channels 2 Max. Memory 128GB System Memory Subtype UDIMM Max Memory Speed 2x1R DDR5-5200 2x2R DDR5-5200 4x1R DDR5-3600 4x2R DDR5-3600 ECC Support Yes (Requires mobo support)
Jaz imam sicer samo 32GB a šele zdaj vidim kako hudičevo srečo sem imel, da vse čisto lepo laufa na 6400.
Jaz sem samo na brzino pogledal kaj je kompatibilno in kupil.
RAMi so sicer rabljeni in je prejšnji lastnik rekel, da je zelo dober bin, ker jih je navijal (zna biti, da je tudi s tem kaj povezano).
Najprej sem imel RAM. Ker sem, kot omenjeno, dobil rabljenega za pametno ceno na bolhi.
Zanimive statistike kažejo, da se R9 7900X3D prodaja precej dobro, R9 7950X3D pa že zmanjkuje zaloge:
https://wccftech.com/amd-ryzen-9-7900x3...
Sicer ne gre ravno za 4k gaming champa, lol, ampak sta zmogljivost in precej nižja poraba atraktivni zadevi.
LuiIII ::
Ej, jaz imam tako AM4 5950X z 128GB kot AM5 7950X v compih in moram reči, da je real-life AM5 enostavno bolj smooth za delat. 128GB rama mi dela (z 5200 DDR5) na 4400. Sem super zadovoljen. Aja gaming me pa ne zanima.
Pravilno. Ti procesorji so za resno delo pravi blagoslov.
Nabijanje špilov ti zadeve ne povrne.
scipascapa ::
LuiIII ::
dej bolj natančen opis komponent, P/N itd.....
Sem dal sicer že kaka dva meseca nazaj pa vendar:
AMD 7950X
Asus ProArt X670E-CREATOR WIFI
Arctic Liquid Freezer II 420 AIO
4x32GB 5200 mislim, da Crucial (se zdejle res ne spomnim kateri model je, vem samo da so timingi bolj meh)
Nvidia A4500
1TB Crucial MP600 pro NVMe
Broadcom 9450-16i z 4x Micron 7.68TB U.3
En 1000W napajalec AX1000 ali nekaj podobnega
V BIOS-u omejena max. temperatura na 85°C in RAM na 4400TM
Spregledal ?
https://slo-tech.com/forum/t633550/p785...
LuiIII ::
Spregledal ?
Jah itak! THX!
scipascapa ::
zakaj to ne dela, luigiju pa?
isto 7950x.
AMD 7950X
Nvidia A4500
Ti lahko v BIOSu nastaviš omejitev procesorja glede na stopinje?
Jaz lahko nastavim samo glede na porabo. Od 170W navzdol po 1W korak.
Matična plošča Asus strix B650 gaming WiFi E-F
- spremenilo: FireSnake ()
Spregledal ?
Jah itak! THX!
Am5 7950x in 128 gb rama
https://www.overclock.net/threads/am5-z...
FireSnake
Jaz lahko tudi nastavim na 85...
Malo bolj poglej po oc meniju, ponavadi je tam nekje.
![](https://static.slo-tech.com/stili/bel_non_grata.png)
jao kok enih kolobocij no....
Trnutno pač počakaš na nov BIOS, no do jeseni... ko bodo porihtali BIOS. Trenutno je Zen4 stanje kot je bilo z Zen1. In n intlu ni kaj drugače... Z790 DARK DDR5 overclocking progress update: 7800CL34 STABLE at last., ko nekaj jamra da je cl kup nastavitev in voltaž, ki jih je potrebno nastaviti, in ni kot pri ddr4.
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
Pri R9 7900X in R9 7950X je izbira matične pomembna, ker so opcije za omejitve temperatur in omejitve TDP-ja zelo smiselne.
Če vzameš 65W varianto ali 3D procesor, potem je načeloma OK out-of-the-box.
Spregledal ?
Jah itak! THX!
FireSnake
Ok, bom še malo pošnofal naokoli. Hvala.
Senior Dev ::
Ali se da kje kupiti 7950X3D?
7900X3D imajo vse trgovine, 7950X3D pa?
Mislim, da ne dohajajo povpraševanja. Dandanes bi vsak imel 7950X3D doma. Poglej bolho koliko ljudi menjava iz 5950X na 7950X3D.
Spregledal ?
Jah itak! THX!
FireSnake
Pri meni je v oc delu, bolj natančno v Precision Boost Overdrive (pbo) delu.
Tam moraš dati iz 'auto' oz 'enabled' na 'advanced', da dobiš vse kar je možno nastavljati.
Na začetku oc dela je pri MSI tudi izbira 'normal' oz. 'expert', mogoče so pri asusu bolj skrili, na msi se zgornja temperaturna opcija prikaže tudi pri 'normal' nastavitvi.
V oc, Core Performance Boost (CPB) ni nič pametnega za nastavljati, cpb enabled ali disabled.
Senior Dev je izjavil:
Eden (1) !
https://www.bolha.com/?ctl=search_ads&k...
Ter sedem (7) 5900x gaming sistemov
Senior Dev ::
Mah, ni več pravih PC entuziastov toliko, ki bi med generacijami lovili 6% boosta. Škoda. Ljudje so začeli bolj pametno uporabljat prosti čas.
Meh, na delu je čudna PNP krivulja, sploh glede matičnih in pomnilniških modulov.
Najprej je bilo "Plug'n Pray".
Potem, v zlati dobi, "Plug'n Play".
Sedej smo pri zen4 spet v "Plug'n Pray" obdobju.
OK, ni tako hudo, ampak povprečnemu uporabniku pri dragi cpu konfiguraciji za dosego namena manjka še 800€+ grafična kartica.
Nekdo, ki je pred leti dal 1500€ za sistem, bi sedaj moral izkašljati tisočaka več, kar pa spet ni tako affordable, čeprav denar imaš.
Ne govorim za tiste, ki se jim amortizira, da ne bo kdo užaljen.
FireSnake
Evo, na msi je temperaturna opcija v:
overclocking, advanced CPU configuration, AMD overclocking, Precision Boost Overdrive (advanced) -> platform thermal throttle limit (vpišeš npr. 85).
Še ena zadeva, v temi nisem zasledil omembe, vpliva na: core performanse boste (cbs)
https://skatterbencher.com/2022/10/26/u...
Gledal po biosu:
overclocking, advanced CPU configuration, AMD cbs -> Global C-state Control (auto, disabled, enabled).
Hiter bench pokaže, da na 'auto' še najhitreje deluje.
AGESA 1003 re-introduces Precision Boost C-State Boost Limiter which prevents boosting to over 5.5 GHz when more than 4 cores are active
Gledal po biosu:
Senior Dev ::
Meh sej za 3500€ se dobi že top sistem z RTX 4090. Ta denar pa je v bražni približno ena povprečna plača. Ni to problem. Nobenemu se ne da s temi biosi zajebavat, ker enostavno ni časa. Če nimaš RTX 4090 je itak grafa ozko grlo pri večini špilov. Za kako resno delo pa se bolj uporablja Intel.
