Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
Pa tebi rami pri 6400 delujejo v razmerju 1:1 z memory controlerjem oziroma infinity fabric? Ker kolk vem je AMD priporočal 6000, češ da v tem primeru ram laufa 1:1 z infinity fabric, ko greš nad 6000 pa se to razmerje samodejno prestavi na 1:2 in izgubiš performance.
Ker če deluje na 1:2, pomeni da se IF frekvenca razpolovi.. V tem primeru bo opazno boljše izbrat 6000 in znižat timinge. Si se kaj igral s tem?
- spremenil: DarwiN ()
Ne še, ker ni bilo časa.
Prvi teden aprila se en projekt (ki se vleče že od oktobra) konča, potem bo pa čas čez poletje.
- spremenilo: FireSnake ()
Senior Dev ::
Nolife bo poleti doma navijal rame. Zdaj mi je jasno zakaj mu pravijo nolife.
Mal je cudno... pocakat bo treba...
AMD Ryzen 9 7900X3D spotted on Ashes of the Singularity
Določene ~200EUR plošče (Asrock, Asus, MSI), pa moraš počakat, da uradno izdajo biose s podporo 6000 ramom. Do takrat pa 5600 max. Nad ~6200 pa tako ali tako niso sposobni 7000 modeli.
Samo še en argument več za počakat na 8000 ryzene, da zadeve dodelajo, pa še cene ramov bodo padle in zna bit DDR8000 končno dostopen.
Pa še boot time bodo do takrat hopefully porihtali:
Izklapljati memory context restore ni tako nedolžno, kot se sliši.
https://www.reddit.com/r/buildapc/comme...
Good timing, I spent this entire past weekend testing and swapping stuff and asking around after my RAM corrupted my OS. Our boards are basically the same with a different layer of paint...Do you have the 5600 or the 6000Mhz set? I sorta have a theory on what may be happening now and everything seems to be stable, but obviously I need to keep watching it for a bit longer...
I got my OS totally corrupted (BSOD loop of memory and driver related failure) twice over the 2 months on the 5600Mhz sticks, first time was because I turned off memory training and the EXPO wasn't stable, kinda my fault. MEMTEST found no errors. Second time was this past weekend. I was running the sticks on JEDEC speeds since the first corruption, and it out of the blue totally corrupted my OS again. I ran MEMTEST immediately this time with CPU and RAM on bone stock settings, and it gave me over 10K errors in the first 3 minutes, but the failure was not reproducible. Both sticks tested good on single sticks, and when I inserted both sticks back, I did not get any errors either. But I could not trust the RAM, or the system in general at this point, and I went ahead and swapped the RAM, the new RAM are the 6000Mhz sticks, same GSKILL brand, also on QVL.
Sam se ga testno izklopil (bil na auto), bootal v winse in dobil v prvi minuti bsod (pc idlal na desktopu) in nato po rebootu še 1x (vsakič drugačen, prvič da je nekaj narobe z %Windir%\System32\ci.dll [code integrity module], drugič irql not less or equal), ko sem zagnal web browser).
Ter v %Windir%\System32\LogFiles\Srt\DISMRepairLogFile.txt en kup napak tipa:
Failed to find a matching version for servicing stack:...tako da moram sedaj zagnati še sfc/scannow, chkdsk ter dism da vidim če je vse v redu https://www.windowscentral.com/how-use-... .
Posledično sem dal nazaj na auto, bios je zadnji (msi b650 tomahawk, rami 2x16gb na 5600 Mhz expo, pbo & cpb na off https://www.pugetsystems.com/labs/artic... ).
- spremenilo: sbawe64 ()
AMD Ryzen 9 7950X3D is 6% faster in gaming than Core i9-13900K according to leaked AMD review guide.
Kot sem predvideval.. Pirova zmaga proti 13900k s 6000 rami.. 13900KS, čigar glavna prednost je menda ravno naprednejši memory controler, sparjen z ~8000 rami zna obstat na vrhu oziroma bo razlika zanemarljiva. Cena sistema in poraba je druga stvar.
Smesko, sedaj moras ze najhijtrejsi RAM, ki ga imas ravno za vzorc tlact v svoje godrnjanje:).
Gre se za zmago z akademskega vidika. Za znanost! Kdo ima za odtenek daljšega. V praksi so itak vsi novejši procesorji isti qrac za veliko večino uporabnikov.
Ti se raje spomni svojih besed in pričakovanj, češ da bodo ti 3D čipi odpihnili konkurenco. #Intel_Dead
V resnici bodo odpihnili samo denarnice tistih, ki bodo nasedli marketingu in hypu.. ~10% boosta (pa še to le v gamingu) in 30-40% višja cena od non-3D modelov.
Lowink ::
Intel je izvel manever da je bilo 6+6 dovolj za čas prvih ryznov, sedaj AMD z L3 skrbi za učinkvitost.
Reömo 2x bolši 1% low, pri 2x nižji porabi ter no bomo videli pri katerih ramih je i9 13900K/KS testiran ker če je pri 6000 je intel prov nič hitrejši tudi v multicore. Ali drugače, AMd je zacementiral vlogo multicore Nr.1 izbire Za eno jedrna opravila, je pa število kupcev, praktično zanemarljiva, to kažejo tudi prodajne številke.
MSI rant
Džabe novi procesorji x3D, še za stare zen 4 ne znajo spraviti ven biosa brez par kolonij hroščev (5 mesecev po izidu, 22/9 2022).
Da ne omenjam dolgih boot časov.
https://forum-en.msi.com/index.php?thre...
Nekaj testiram različne kombinacije
pbo on/off (oz manual s curve), cbs (cpb) on/off
najbolj hladna kombinacija, testiram v 7zip 22.01 x64 bench [compressing/decompressing resulting], 20 passov, HWMonitor za temperature, zaprto ohišje na mizi, temp 22C:
pbo on (manual, -29 curve, če dam na -30 je preveč - reboot med benchom), cbs (cpb) off
87825, 94331, temp cpu do 68C
nekaj vmes
pbo off, cbs (cpb) off
87657, 94592 (compressing/decompressing resulting), temp cpu do 80C
najbolj hitra (in vroča) kombinacija
pbo on (-29 curve), cbs (cpb) on
91753, 100855, temp cpu do 97C
pbo on, cbs (cpb) off
//ne pride do konca test - reboot med benchom
7600x, rami kingston 5600 expo cl36 38 38 80 118 (prepisano iz cpu-z), msi b650 tomahawk, zadnji stable bios 7D75v11 (tile beta 31/34 so brez komentarja, škoda časa, testiral oba, nestabilno v PM), vodno 360 - 3x 120 mm ventilatorji omejeni do 1200 rpm, win10 pro, power plan ultimate performance https://www.howtogeek.com/368781/how-to... .
V biosu imam "Spread spectrum" na off, memory context restore je na enabled (v tej verziji biosa recimo da dela, v naslednjih beta ne),
drugega iz OC sekcije nisem spreminjal.
nekaj vmes
Moje pricakovanje se je uresnicilo. AMD je prevzel prvo mesto. NIc vec, nic manj.
MSI rant
For example, with 1.0.0.4 it took about 40-45 seconds in POST which is still super slow, but with 1.0.0.5 that time increased to a whole minute, so overall it takes almost 2 minutes to boot into Windows 10.
Leto 1999: Intel(R) Core™2 Duo processor, 128Gb HDD@5400rpm: boot time to windows ~110 sekund
Leto 2023: Ryzen 7900X, 1TB PCI-E 5.0 SSD; boot time to windows ~120 sekund
@tiki, that remains to be seen.
Jarvice ::
Če tukaj ne bo pisalo za nove X3D modele vsaj 290 fps, bo zame veliko razočaranje. Glede na boost 5800X - 5800X3D
AMD Ryzen 7 5800X3D - Gigabyte B450 Aorus Elite - MSI GeForce RTX 4080 SUPRIM X
G.Skill 32GB 3600 - Be quiet! Straight Power 11 850 - Be quiet! Pure Base 500DX
Dell 32 Curved 165Hz S3220DGF - LG OLED55B13LA HDR 120Hz 4K - Sony PlayStation 5
MSI rant
nekaj vmes
No v bistvu, če prodajaš več kot eno leto prepakirana stara jedra res ne moreš imeti problemov, razen če je prodaja le teh tako slaba, da ne veš kam z jedri in jih zapakiraš v next gen hedit proc, ali pa Gen13, kjer jasno veš da je DDR4 tam zgolj kot sticker.
PS: pa naj uganem oba trilčka imata AMD proc.
- predlagal izbris: MrStein ()
Kaj ti bluziš?
Kako je to, kar si napisal, povezano s tem kar si citiral. Res me zanima.
Na HU so komentirali, da je daljši zagonski čas povezan s treniranjem DDR5, ki se zgodi ob določenih spremembah v BIOS-u.
Sicer je primerljivo kratek.
Sem morda kaj zamudil ali preslišal?
Kaj ti bluziš?
Ja kaj točno imaš dva trolčka, ki imata konstantno probleme z AMD-jem. Hitro skoči na njun vlak.
In da Adler lake jedra so cca zunaj skoraj leto in pol. Intle nex gen hedit proce ima Adler lake P jedra z omogočenim avx itd..
Intel Gen 13, non K ima Adler lake jedra ne Raptro lake jedra.
Z790 čipset je v bistvu rebrandan Z690 chipset , in na koncu se moraš konkretno vprašat. Kako lahko KATERAKOLI Z790 matična ponuja istočasno PCIGen 5 16X ter hkrati 1x NVME Pci gen5 4x če pride ven iz proca le 16x PCI gen 5 fizičnih povezav.
Pokaži mi reviverja, ki je uspešno hladil Gen 13 i9 proc, brez da nebi thermal hrottlal...
AMD je trenutno best buj z AM4 in AM5. ČE hočeš podirati navijalske rekorde, pa to ni NV, ko nimaš s podnem segmentu nič primerljivega in konkurenca intel gen 13 je dejsako intel gen12.
Mr.b: oprosti, ti si prizadet.
Ti sploh pojma nimaš kaj prebereš in klobasaš vse povprek. Ko človek prebere kaj citiraš in nato tvoje klobasanje uvidi, da to dvoje nima prav nobene povezave.
@Jarno
To nastavitev v BIOSu omogočiš in potem je čas zagona vredu.
Meni se je tudi čudno zdelo. Potem sem pa malo bral.
Na Asuski sem omogočil "Memory Context Restore" in se je zadeva uredila.
Ne vem pa, kako se ta nadtavitev imenuje na drugih matičnih ploščah.
@Jarno
Darvin, kar naprej twika svoj intel proc, da deluje pri optimalnih pogojih, tega pač ne boš delal z AMd procem, ker moraš čakat 120s.
Ali pa sbawe64, ki je tako alergičen na DDR5 da vedno pravi DDR4 je in, za intla minus mr. 10% perfromance. Hkrati pa kupuje DDR5 5600 cl36 38 38 80 118 rame, hkrati pa DDR5 600 CL36-38-38-76 (ki ima celo boljše timinge, stane 5€ več torej 137€ 32 GB kit. Toliko o poznavanju teme, ki jo on ali oba trolčka komentirata.
@Jarno
Ja hvala, z razliko od teme, lahko vsak stavek argumentiram, medtem pa ti s svojimi sinonimi, pač argumentiraš zgolj z žaljenjem.
Torej... kateri del napisane besede je tebi nerazumljiv.
Da fant nima pojma o ram timingih,
da ima probleme s temperaturo pri procu ki jih nima, in hladi s 360 AIO.
Skorej bi rekel, da si alterego sinonim uporabil, ker bi bilo res patetično uporabiti in argumentirati ter dokazovati da nimaš pojma.
- spremenil: Mr.B ()
Lepo, da si vprašal.
Lahko bi dal 10 povezav, pa bom samo eno:
https://slo-tech.com/forum/t633550/p785...
Glede alter se pa malo zbudi in poglej kdaj sem jaz registriran.
In kaj je tisto, o čemer jaz nimam pojma?
Še en rant na msi bios (zadnji stable v11): ko nekaj spremenim in pritisnem F10, pokaže v ang jeziku vmesnika (privzet jezik) prazen dialog box z ok in cancel, če dam v nemščino, francoščino, španščino pokaže katere spremembe sem naredil ter ok in cancel.
@Jarno
Vsaj na MSI ploščah očitno ni stabilno:
The option that helps reducing boot times is Memory Context Restore set to enabled, but it's bugged since agesa 1.0.0.4, the moment you change it from auto to either enabled or disabled, lots of BSOD happens, and MSI couldn't fixt it in this new bios either.
Memory context restore might actually work for me, but I heard people say that it causes stability issues so I prefer not to have that enabled.
Na beta bios v31/34 je zagonski čas skoraj minuta, vsakič.
Na v11 je prazen zaslon cca pol minute.
Edino če grem iz win v bios traja 15 sekund praznega zaslona (potem ko sem enablal memory context restore, drugače je pol minute.
2*16 GB.
Na nobenem od prejšnjih sistemov nisem imel zagonskega časa 2 minuti, od intel 386, intel P120, intel pentium 3 450, Intel Celeron 950, AMD Thunderbird 1000, AMD Athlon 64 3200+, intel Pentium 4 3.2, intel Pentium 1.8 mobile, Intel i5 4th gen (verjetno sem kaj pozabil).
agesa 1.0.0.4
Na v11 bios sem šel med drugim nazaj zaradi tega, tam je še agesa 1.0.0.3.
Mr.B
Na MF je
32GB (2x 16GB) G.Skill Flare EXPO X5 schwarz DDR5-6000 DIMM CL36-36-36-96 Dual Kit
za 139,61
https://www.mindfactory.de/product_info...
Za tega tudi v pdf na kingston.com ne piše zadnje številke
32GB (2x 16GB) Kingston FURY Beast EXPO DDR5-6000 DIMM CL36-38-38 Dual Kit
145,49
https://www.kingston.com/datasheets/KF5...
hkrati pa DDR5 600 CL36-38-38-76 (ki ima celo boljše timinge, stane 5EUR več torej 137EUR 32 GB kit.
Na MF je
za 139,61
145,49
Edit
sem ga našel
32GB Corsair Vengeance schwarz DDR5-6000 DIMM CL36 Dual Kit
SKU: CMK32GX5M2B6000C36
152,24
Latenz (CL): CL36
RAS to CAS Delay (tRCD): 38
Ras Precharge Time (tRP): 38
Row Active Time (tRAS): 76
https://www.corsair.com/eu/en/Categorie...
Opozorilo
samo XMP profil:
iz zgornje Corsair strani
XMP 3.0
sem ga našel
152,24
Latenz (CL): CL36
Opozorilo
samo XMP profil:
XMP 3.0
32GB Corsair Vengeance grau DDR5-6000 DIMM CL36 Dual Kit
SKU: CMK32GX5M2D6000Z36
153,82
Tale ima expo profil.
Tested latency:
36-36-36-76
Filter na MF
https://www.mindfactory.de/Hardware/Arb...
153,82
Tested latency:
36-36-36-76
Filter na MF
Drugače plošča podpira amd expo in intel xmp, čeprav je v navodilih na msi strani omenjen samo expo.
Moji rami imajo oba profila, številke so enake (prve štiri), voltaže isto.
Dalje nisem gledal, vendar je tam še en kup nastavitev:
slika
iz
https://github.com/integralfx/MemTestHe...
Rami delajo tudi brez vklopa profila, izbereš hitrost, vendar so privzete latence nekoliko počasnejše.
Koliko časa potem traja, če bi rad zadevo optimiziral brez profila je dobro vprašanje, kak dan sigurno, dolgi boot časi in testiranje ramov.
slika
iz
@Jarno
Uf, nerodno.
Kje je folk "boot time itak ni pomemben". Oziroma "saj ne bootas vsakih 10 minut"?
Edit
sem ga našel
152,24
Latenz (CL): CL36
Opozorilo
samo XMP profil:
XMP 3.0
To je tvoj ram , s katerim se igraš :
Rami kingston 5600 expo cl36 38 38 80 118
130€ Kingston FURY Beast DIMM Kit 32GB, DDR5-5600, CL36-38-38, on-die ECC
1R (Single Rank)
140€ Corsair Vengeance grau DIMM Kit 32GB, DDR5-6000, CL36-36-36-76, on-die ECC
2R Dual Rank
Oba podpirata AMD EXPO.
Zakaj si izbral singel rank ?
ČE ti cena ni všeč, lahko najdem tudi povprečno ceno kingston rama ki je cca 25€ več.
Edit
sem ga našel
152,24
Latenz (CL): CL36
Opozorilo
samo XMP profil:
XMP 3.0
nadaljevanje iz
enote v A in B so GIPS, v 7zip stolpcu v "Rating" stolpcu
pbo on (-29 curve), cbs (cpb) on, tdp 65W
//ne pride do konca test, temp do 97C, restart pri 22 passu
pbo on (-28 curve), cbs (cpb) on, tdp 65W
91152, 99861, temp do 97C
pbo on (-28 curve), cbs (cpb) on, tdp 45W
89638, 95600, temp do 72C
pbo on (-29 curve), cbs (cpb) off, tdp 65W
86684, 93806, temp do 65C
pbo off, cbs (cpb) off, tdp 65W
88077, 94157, temp do 78C
pbo on, cbs (cpb) on, tdp 65W
89527, 96070, temp do 97C
pbo on, cbs (cpb) off, tdp 65W
88313, 94284, temp do 80C
pbo off, cbs (cpb) on, tdp 65W
89027, 95710, temp do 97C
A, B, temp do 97C
Edit
sem ga našel
152,24
Latenz (CL): CL36
Opozorilo
samo XMP profil:
XMP 3.0
130EUR Kingston FURY Beast DIMM Kit 32GB, DDR5-5600, CL36-38-38, on-die ECC
1R (Single Rank)
140EUR Corsair Vengeance grau DIMM Kit 32GB, DDR5-6000, CL36-36-36-76, on-die ECC
2R Dual Rank
ČE ti cena ni všeč, lahko najdem tudi povprečno ceno kingston rama ki je cca 25EUR več.
Res je, tega imam (KF556C36BBEK2-32).
Preprosto, gledal sem samo 5200 in 5600 rame, saj so 3 tedne nazaj bili spodobni 6000 rami po ceni od 160 eur naprej.
Kje si našel podatek, da je corsair 2R Dual Rank (CMK32GX5M2D6000Z36 oz. CMK32GX5M2B6000C36 expo vs xmp) ?
Za kingstona vidim da piše v geizhals info, drugače tega ni nikjer eksplicitno navedeno.
vem da se lahko recimo vneseš SKU ramov:
https://www.asrock.com/mb/AMD/X670E%20T...
https://rog.asus.com/motherboards/rog-s...
https://www.gigabyte.com/Motherboard/X6...
https://www.msi.com/Motherboard/MAG-X67...
in če imaš srečo so jih že testirali.
Na asrock/asus strani najdem moje, corsair nikjer.
btw, na MF https://www.mindfactory.de/product_info...
piše da gre pri corsair-ju za single rank (ECC Single Rank).
Za kingstona piše "Speichertyp: unbuffered"
Samo tu piše podatek le, če so single ali double side, vendar to ni zagotovilo, da gre za 2 oz 1R rame...
https://www.igorslab.de/en/performance-...
There are already various articles and videos circulating on the net on this subject, often with abbreviated or incorrect conclusions. One of those myths is that you can equate sticks with ranks. This is simply wrong, because even if a stick or a module often has one rank, there are also a lot of modules with two, four or even eight ranks per stick. Another misconception is that all 16GB sticks must automatically be dual-rank, due to the assumption that it must simply be a double-sided single-rank module. But that’s wrong too, because for one thing, two-sided doesn’t always mean two ranks. And on the other hand, there are also memory chips with a 16 Gbit capacity, so that single-sided and single-ranked modules with 16 GB capacity are also becoming more and more common.
edit2
Za kingstona piše v pdfju zelo neopazno
DESCRIPTION
Kingston FURY KF556C36BBEK2-32 is a kit of two 2G x 64-bit
(16GB) DDR5-5600 CL36 SDRAM (Synchronous DRAM) 1Rx8.
Vsi rami na kupu:
Ddr5, 6000 MHz in 2R
https://geizhals.de/?cat=ramddr3&xf=439...
corsair ramov tu ni navedenih.
Wuuuuhuuuu:
https://www.anandtech.com/print/18747/t...
sem misli, da je tole šele v sredo.
Na srečo danes popoldne nimam nobenih obveznosti in se lahko zakopljem v branje.
https://www.phoronix.com/review/amd-ryz... ... tu so lepši grafki. Predvsem "frames per second per watt" so ... zanimivi :D
Tpu iz 7950X3D 'naredil' dober približek 7800X3D
https://www.techpowerup.com/review/ryze...
Vsi rami na kupu:
Sem popravil.in odstranil 1R.
Kolikor sem gledal so vsi 16GB moduli 1R.
Za igre bo 7800X3D ?
Za MT ?
Blender ima kar nekaj prednosti...
Pegasus bo tudi lahko dal en AI model na CCD kjer je 3D cash in drugi AI model, or del modela ki rabi CPU hitrost.
7900X3D ? DOA
Ostalo mora AMD z driverji porihtat, ali pa mora programje/OS znati ločiti kje je benefit.
Linux lahko nastaviš kateri CCD naj OS preferira.
pegasus bo dal AI model na CCD, kjer je 3D denar? Kako se to naredi? Lahko razložiš?
Zakaj uporabljaš angleško spakedrajščino, če ti še osnove niso jasne?
Senior Dev ::
Kako dolgo te bo še držal tale hype? Upam, da te hitro mine.
Oprosti memory cache. Sedaj je razumljivo. Bolje, baje.
Po pricakovanjih so novi AMDjevi CPUji odlicni, edina ovira za priporocilo vsem je seveda cena. Poraba je impresivna. Nabrcajo INTEL ponudbo pri manj k polovicni porabi:).
