AMD R3xx series
AMD R3xx series
PredatorX ::
Laufaš kšne programe? skype,crome?
Epialt ::
Da, vendar sem poskusil oboje ugasniti, nič bolje.
Napajalc ::
Navadi se navijat CPU in ne bo nobenih problamov.
011011100111010101100010
hahaha, kr cpu OC bo pomagal pri sesuvanju GPU driverjov...
C'mon, atleast try.
SuperVeloce ::
PredatorX je izjavil:
Ja, resno!
uporab programček + zbriši čisto vse + ugasneš PC vržeš vn štrom in daš nazaj in restartaš + clean fresh install
"vrzes strom ven"... seriously?! Saj ni upgrejdal biosa.. pa se takrat to ni potrebno.
GenZNPC ::
AMD ima bolj stabilne driverje kot NVIDIA (DX11/DX12)
AMD ima VSE boljše... kar ma doh, to itak vemo
skibidi
  • spremenil: GenZNPC ()
Napajalc ::
To ni dvoma, drgač pa resno, drajver se sesuva tudi če je cpu narobe navit poleg GPU seveda.
Kle ni microsutteringa, AMD pove da neki ni ok.
  • spremenilo: Napajalc ()
PredatorX ::
Epialt, ta problem je AMD only ali R9 390 only. Ta problem je bolj GTA V only.
1. Probaj ugasniti vse programe. Fraps etc.
tole je nedo napisal:
¨([-]QueenOlcadan 1 point 2 months ago
I was having the same issue on my 390. I sent in a Rockstar support ticket and they recommended the myriad of standard things to try and fix the issue. The only thing that did it for me was closing every single thing in my system tray (Origin, Battle.net, Skype, etc. except for Steam). I don't know why this worked, but it did and not it doesn't crash.¨)
2. GTA directory (si že probal tole)?
- d3dcsx_46.dll + d3dcompiler_45.dll
- verify cache na steamu (GTA + desn klik > properties > local files > verify integrity of game cache=
3. Potem je fajn, če bi probal z underclockanjem.
SuperVeloce je izjavil:
Ja, resno!
Ubistvu je včasih fino dat vn štrom iz plate. To pa narediš tako, da klikneš na gumb pri napjalcu ali ga celo izklopiš.
- Fresh GPu install (če menjaš GPU)
dominuspro ::
epialt
Si slučajno probal različne nastavitve v biosu za PEG X - Max Link Speed?
Pa underclockinga nisem mislil kot končno rešitev, pač pa kot troubleshooting... Če grafa z nižjimi clocki dela bp, veš kje je težava ;)
Epialt ::
1.) done
2.) done
3.) down-clocku nisem in šparam za čisti konec! Res smatram to za poraz!
@dominuspro
Nisem.
PredatorX ::
Drgač ta error:
[ERR_GFX_D3D_INIT]
Failed Initialization. Please reboot and restart the game. Try reinstalling the game if this persists.
Probaj že z underclockanjem. Čuden problem z GTA-jem. Mislim, če probaš kakšen drug špil ti bo delal brez problemov.
http://www.overclock.net/t/1551884/gtav...
vsync ti tudi lahka dela probleme.
Epialt ::
ARMA3, DAYZ Standalone delata brez problema.
Načeloma bi imel kaj za povedati čez Rockstar, vendar se AMD zaveda težav in jih odpravlja že 6 mesecev, zato sem nad njihovo podporo razočaran.
P.s. poskusu z reinstall itd.
Vsync tudi poskusil na OFF
PredatorX ::
Napiš v google
GTA V err_gfx_d3d_init
= neskončno threadov.
Napajalc ::
Se pozna vpliv haterju. Sam da pogruntaš, zadeva leti.
Epialt ::
Napiš v google
Tell me about it, 3 dan že berem in poskušam vse mogoče.
NightHawk ::
Napiš v google
Sepravi najprej ga označiš za idiota in razložioš kako je AMD the best, šele potem pa malo pogooglaš kako sploh je s to stvarjo?...
PredatorX ::
NightHawk je izjavil:
Napiš v google
Aja? to ni bili namenjeno za epialta, ampak za vse ostale, ki nonstop mislijo, da je problem samo z AMD GPU-ji.
@Epialt nekdo na forumu je imel iste težave z GTX 980Ti je underclockal memory speed pa so mu težave izginile.
NightHawk ::
Epialt je izjavil:
Kot sveže-pečeni lastnik r9 390 naj samo povem, da sem izredno razočaran nad AMD supportom.
Ogromno ljudi ( sedaj tudi jaz ) ima že od samega release-a GTA 5 težave z driverji zaradi katerih igre ne more igrati.
60 strani samo na AMD forumu, da o redditu, steamu in rockstar forumu ne govorim.
Iste težave se pojavljajo tudi pri drugih igrah, katere sam ne igram, vendar sem zadnje dni prebral precej postov.
Najhuje je to, da tistih 10min GTA 5 dela fantastično na max nastavitvah ravno toliko, da te zrajca, nato pa pop-up driver error in vsega lepega je konec.
Najprej daj pravilno driverje gor.
Vidim ja.
PredatorX ::
O, fak.
@Epialt
očitno večina folka v tej temi pričauje, da pošlješ R9 390 nazaj dodaš nekaj denarja in vzameš GTX 970 ter upaš, da bo problem magično izginil.
PS: Si naredil upgrade al clean win10 install?
Epialt ::
Clean install win10.
GenZNPC ::
Kupiš amd pa morš vse to našteto delat pa še clean instal ? zanimivo
Še dobr, da folk ne uporablja drugih zadev... gvr so že zrihtal tko k to mora bit ?
..... to the batmobile
skibidi
Napajalc ::
GenZNPC je izjavil:
Tudi taki primeri so, a ti si flešal gtx 980 ali vedno pred igranjem nastaviš power limit na 250w?
  • predlagal izbris: GenZNPC ()
Berem, problem ni samo pri AMD tudi Nvidi oz. nasploh je problem z IGRO.
Poročam, če kaj zasledim.
  • spremenil: D3m ()
filip007 ::
Ja tri možne rešitve so: (vir Youtube)
Downclock ali starejši driverji ali pa tole.
Če katera dela nevem.
HP prenosnik, Xbox SX in Hisense Qled.
  • spremenil: filip007 ()
D3m0r4l1z3d ::
Win10 bo problem, 290x na win7 dela ok, niti enkrat se še ni sesula
Epialt ::
filip007 je izjavil:
Nobena.
destroyer2k ::
Imaš vkloplen MSAA? Meni je delal to probleme (na 7950).
Epialt ::
nope
GenZNPC ::
Epialt je izjavil:
nope
Imaš možnost poskusiti še na Win7/8 ?
skibidi
Epialt ::
Mmmm ja in ne, lahko bi naložu na isti PC 7,8, ampak samo za GTA 5 tega ne bom.
Sploh zato, ker je precej ljudi že poskusilo s tem in ni obrodilo sadov.
Prej bom downclocku GPU kot pa nalagu drug OS zaradi ene igre tbh.
Včeraj sem nekje prebral, da naj bi do konca oktobra probleme odpravili, ( večino iger, ki podpira dx11 ) izdali nove driverje in upam, da bo.
Me je pa malo strah kaj bodo spacali skupaj za dx12.
fr4nc ::
O kakšem downclocku govorimo(frekvence jedra in frekvence pomnilnika)? Ter o kako drastičnem- par MHz-ov ali par deset MHz-ih ali o par sto MHz-ov?
PredatorX ::
Naj bi pomagal če daš 100mhz downclocka na GPU (Core clock ter memory clock). Ali na AMD-ju ali na NVIDI-ji
fr4nc ::
A tako...torej če prav razumem, najenostavnejši postopek ne želi poizkusiti oz. si ga hrani za na konec?
Kaj pa če overclockaš in povečaš voltažo-bi pomagalo?
Epialt ::
Mal trme pa more met človek lej. Nej zrihtajo ffs. Najboljš, da se najdejo 3 devi, hardware proizvajalci kjer bo vsak svojo stvar hotu.
Da bom manualy vsak Hardware prefukavu zato, da bo ustrezalo vsaki igri posebaj.
Ko bom izčrpu vse ostalo bom pa downclocku, če mi bo tok fejst do špila.
Načeloma nism trmast človek oz. ne živim na principih, ampak nekje je pa treba mejo potegnat.
GenZNPC ::
@Epialt
pošlji mi SS svojih nastavitev v GTA, da še jaz probam na naviti 980 in win10 pa povej točn postopek kako priti do te težave
skibidi
iloveboobz je izjavil:
Čemu to?
PredatorX ::
fr4nc je izjavil:
nevem. GTA V je mel kr velik problemov.
Epialt ::
GenZNPC je izjavil:
@Epialt
Hah, če nimam fixnih nastavitev. Poskusil sem vse kar je internet imel za povedati glede tega.
Takole pa zgleda tale zadeva:
edit: 1:06 = crash
  • spremenilo: Epialt ()
fr4nc ::
Hmmm...sam bolj zaupam temu
in temu:
NVIDIA GEFORCE GTX 970
72/100
Hardware index based on 28.133 submissions (performance relative to fastest system, more info).
AMD RADEON R9 290X (=< R9 390)
77/100
Hardware index based on 9.467 submissions (performance relative to fastest system, more info).
Epialt je izjavil:
To si že probal?
D3m0r4l1z3d ::
kupiš 290x?
Epialt ::
fr4nc je izjavil:
To si že probal?
How could I have been so blind....
But seriously, da.
D3m0r4l1z3d ::
Kaj samo 390 oziroma obratno ima probleme z gta5? Čisto vsaka?
Kateri monitor imaš to. Ful grd light bleed.
Xserces ::
Zaradi kamere... Drugače tega lightbleeda nevids tako. kamera poudari
Epialt ::
Ni moj posnetek btw =)
GenZNPC ::
Aja mimogrede, to se dogaja naključno ali po določenem času?
skibidi
PredatorX ::
http://wccftech.com/star-wars-battlefro...
uff R9 NANO je za single 8 pin conecktor kr TOP kartica.
GenZNPC ::
mhm TOP cena in kvaliteta
skibidi
PredatorX ::
Fury se kr lepo drži z GTX 980Ti. Fury pusti GTX 980 daleč zadaj.
Verjetno ti bo 650-700€ grafična z OC-jem (1500mhz@GTX 980/TI) držala zelo dolgo časa.
Jah to je DX11 verzija.. mislim, da bo battlefront tudi na DX12
GenZNPC ::
Ma če navite radeonke delajo potem že
skibidi
81 / 115
