Forum » Pomoč in nasveti » nView v Linuxu
nView v Linuxu
DKennedys ::
re ...
Zanima me, ce kdo ve kaj bi moral v XF86Config spremeniti, da bi lahko imev sliko na TV in na Monitorju hkrati ...
Sedaj imam nastavleno tako :
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
VendorName "Videocard vendor"
BoardName "NVIDIA GeForce 2 MX (generic)"
VideoRam 65536
Option "TwinView"
Option "SecondMonitorHorizSync" "30-50"
Option "SecondMonitorVertRefresh" "60"
Option "MetaModes" "1152x864, 1152x864; 1024x768, 1024x768; 800x600, 800x600; 640x480, 640x480"
Option "TwinViewOrientation" "clone"
Option "ConnectedMonitor" "TV"
Option "TVStandard" "PAL-B"
EndSection
ampak zdaj imam sliko samo na TV na monitorju pa ne ... ce kdo ve kaj morem popravit oz. kje sm naredo napako mi naj prosim sporoci :) lep dan.
Section "Device"
Driver "nvidia"
VideoRam 65536
Option "TwinView"
EndSection
roscha ::
Same here. Verjetno bo pa kaj na temle:
copy/paste z nvidia foruma
Some GeForce2 cards support TwinView and some do not support TwinView, depending on how the OEM manufacturer implements the DACs. All GeForce2 class GPUs have two DACs, DAC A and DAC B. Each DAC can drive one analog display. TwinView requires one display on DAC A and one display on DAC B.
A TV port is supported only on DACB for all NVIDIA GPUs. If an OEM puts an SVideo, RCA, or VIVO connector on a card, it is invariably on DAC B.
A VGA port is supported on both DAC A and DAC B. If the manufacturer provides a VGA port on DAC A, then TwinView is available using on DAC A with on DAC B.
If the manufacturer puts a VGA port on DAC B and also a TV connector on DAC B, then output is possible for only one display at a time. This is likely how your hardware is manufactured. No driver can make DAC B drive two displays with different images.
One way to verify whether your card has both TV and VGA ports on DAC B is to check it out on the Windows Display control Panel. If the Advanced control panel for your device has "Device Selection" instead of "TwinView " then both ports are using DAC B.
by!
by!
| » | Fedora-Core2 Problem z graičnim načinomOddelek: Operacijski sistemi | 1304 (1215) | demokedes |
| » | Kje je Twinview?Oddelek: Pomoč in nasveti | 1546 (1381) | gonilnik |
| » | Vprašanje glede Radeon-a 8500Oddelek: Strojna oprema | 1979 (1761) | Senitel |
| » | Matrox vs. nVidiaOddelek: Kaj kupiti | 2517 (2173) | Daishi |
| » | MX Dual-Head ali TV outOddelek: Kaj kupiti | 1532 (1439) | jetam |
