Leseno ohišje: Taurean, 22L
freesty ::
Naredi se tipke iz lesa:)
http://www.youtube.com/watch?v=5hfYJsQAhl0
Robi :P ::
3 zgleda top
BorutK-73 ::
3 all the way.
Map ::
Jaz imam računalnik na tleh ob mizi in mi je najbolj všeč tretji način, kdor pa ima računalnik na mizi, pa bi izbral drugi način, Se pravi odvisno od postavitve. Jaz sem za 3.
N4m31355 ::
3 ftw.. jst bi dal kr cel backpanel na top ce bi bil prostor..
Janac ::
Jp, jst sm tut za tretjo. Tnx!
Evo rami :)
Being a successor of Blitz 1 which focusing on heat spreading, Blitz1.1 is based on the original performance with additional gaming spirits making itself a born servant for gamers. Complex process to build best products is always not a problem to AVEXIR. We make the removable heat spreader which overclockers with favor of liquid nitrogen must be happy to play around and unleash their mightiness. Blitz 1.1 is designed to fit products from five major motherboard manufacturers by providing eight perfectly suitable styles which will not fail expectations from gamers with strict standards of visual consistency.
2
3
4
5
6
7
8
9
10
Hvala za ogled.
  • zavaroval slike: bluefish ()
Xserces ::
Kera plata pa grafa? Tle zravn paše samo MSI plata pa Lightning grafa ;);)
  • spremenil: Xserces ()
gddr85 ::
sej je msi m pa xfx7850, če se ne motim
Janac ::
Xserces je izjavil:
O lepo bi blo ja, ampak plata bo(slika na prvi strani) MSi H77MA-G43. Vem, da teli moduli niso najboljša kombinacija, ampak iz Blitz serije so se mi zdeli še nekako najbolj primerni:P
Takrat sem razmišljal, da bi rumen del prebarval na modro barvo, saj bi se potem v tej barvi ujel še sleeving, hladilna rebra na plošči...
Janac ::
sem posnel GIF, da vam lahko prikažem delovanje modulov.
 Avexir Blitz1.1 MPower
Upam, da so vam všeč :P
  • spremenil: Janac ()
gddr85 ::
kuko že gre pesmica
It's beginning to look a lot like Christmas
Everywhere you go...:D
drugač pa lepo zgledajo, dobra roba
Janac ::
gddr85 je izjavil:
kuko že gre pesmica
Jp, tut jst sm mislil, da bo tako kot ti zgoraj opisuješ s pesmico :), vendar ni, prehodi so zelo počasni in zvezni, tako da ne blinka kar na random :)
Mislim da imam edini primerek teh pomnilnikov v Sloveniji.
FX6300B ::
Janac res pohvalno si se lotil te izdelave res je top of the top pa še slikat znaš :D kr tko naprej
Janac ::
Okej, naredu sm tisto ploščico kar sam, ker bi me CNC izrez stal okrog 60Eur(s parimi drugimi stvarmi sicer a nič posebnega). Mislim da mi je kar uspelo, bo pa boljše, ko bo oboje v barvi.
2
3
4
Kakšna ideja kak material je to? Ker s svedrom za kovine sem se kar trudil prevrtat...
5
Naredu sem še poličko za pumpo, vijaki so skriti v lesu...
2
Sem mal gledal kok stanejo nogice za ohišja, tista malo bolj konkretna so blizu 30-40Eur, pa sem raje svoje naredu.
2
3
4
5
6
Polička in nogice bodo v barvi češnje kot stranici...kaj pravte?
FX6300B ::
awesome:D
klinker ::
Nice.
Ampak...dej kupi ene lepe vijake. Ce se ze morajo videt, kljub temu da so kao skriti, naj bodo vsaj lepi za videt.
Janac ::
klinker je izjavil:
Nice.
Inbus niso ok? :)
Aja, misliš za nogice? Bom dal tak še pluto vmes, da se ne bodo prenašale vibracije, pa jih potem ne bo videt :)
Janac ::
update...
Danes sem se napajalniku posvetu...
2
sprva sem mislu da bi šli kabli tkole...ampak na tak način bi bli zeloo prekratki + izjemno vidni bi bli. Torej no go.
3
4
5
6
7
Tu pa vn.
8
Takole bo nekako.
9
10
11
Kaj bi rekl?
Kako bi ''polepšal'' tisto škatlo od napajalnika? Razmišljal sem o lesenem okvirju alpa kakšni krom barvi...?
Tnx
BorutK-73 ::
Furnir?
A boš odrezal vijake nad napajalnikom, tisti višek do matic?
Janac ::
BorutK-73 je izjavil:
Furnir?
hočeš reči naj uporabim krajše vijake?
BorutK-73 ::
Če imaš krajše, menjaj. Če pa ne, pa odrežeš te ki jih imaš sedaj. Lahko kar tako kot so ali pa vsakega posebej odstraniš in odrežeš. Če boš delal drugo opcijo, navij matico do konca preden odrežeš.
ps
Pa da ne bo pomote, v mislih imam vijake na alu ploščici z narisanim črnim križom.
Janac ::
krajših nimam, potem raje kupim krajše, ker nimam tage žagce za odrezat+ nerodno se mi zdi to nasploh...
še kaki pomisleki nasploh?
FX6300B ::
ja ja napajalc ki ful hud zgledu u krom barvi al pa sticker bomb :D ne sj ne krom bi pomoje kr pasu
Janac ::
Sem pripravil par fotk, da si lažje predstavljate v katero smer gre razmišljanje...
2
3
4
5
A bi vi na mojem mestu prebarval rumen del ramov v modro?
BorutK-73 ::
Mogoce bela barva za rame.
Janac ::
bela? s čim bi se pa ujela bela?
hvala za predlog
Robi :P ::
Janac je izjavil:
hvala za predlog
najbolj simpl bi bil edgis hehe :D al pa kak lak za nohte mogoče? drgač pa plastidip, barve v sprejih sam morš fajn zadekat. drgač pa topshit tale projekt
  • spremenilo: Robi :P ()
ajfon ::
A sem mogoče jas edini, ki mi je tale projekt videt pač brezveze :).. Sej pohvalno si naredu vse pa Super bo zgledalo na koncu, sam a ni škoda časa pa dnara za neki, kar dobiš novo (ohišje) za 100€ define r5 pa zgleda ene 3x bolš... :D
Pač sam moje mnenje.. se sam nebi nikoli spuščal v tak projekt.. Nevem zakaj bi si kompliciral življenje :)
dj_uro ::
ma lej, pusti fanta, naj uživa...
vw-klub.si
Janac ::
Nevem kako bi se počutil z enakim ohišjem kot ga ima druga polovica ljudi na svetu :)
Itak pa takega kot želim sploh ni na prodaj...
recimo:
(zamenjaš avto s kompi)
hvala za mnenje seveda
SimplTech ::
Komplimenti iz moje strani. Všeč mi je da se kdo še trudi in dobro dokumentira cel proces.
To ker je napisal ajfon, je sicer res če gledaš samo na denar in porabljen čas, a zadovoljstvo da narediš nekaj sam je čisto nekaj drugega. Pa tudi naučiš se veliko stvari ob izvedbi takšnega projekta.
GenZNPC ::
Jst bi ga skamufliral v les, furnir. Tako kot je Borut predlagal. Gre ze za veliko stvar, ki ne rabi izstopat.
skibidi
lovro535 ::
Lepo napreduje tale projekt.
Raspberry Pi 512MB 32GB Raspbian/Asus P7P55D Intel core i5 2,66ghz
LGA 1156 8GB Kingston DDR3 WD Black 1TB Gigabyte GT430 W7/
Nexus 7 2013 32GB/Oneplus one 64GB Sandstone black.
Janac ::
še kak komentar glede ohišja napajalnika? in nasploh?
Mogoče pozna koga, ki izreže pločevino z laserjem ter ga zanima tut manjša naročila?
Tisti ki mi je prej rezal ne želi več, sem pa poslal generičen e-mail vsaj 10 podjetjim in dobil le en odgovor, da so zasuti z večjimi naročili...
Map ::
Lahko poizkusiš poslati mail tudi kam, kjer pločevino prebijajo. Bi znalo biti ceneje.
d4vid ::
ajfon je izjavil:
Če se ti nebi spuščal v tak projekt, pa sedi za PCjem in tako zapravljaj svoj dragocen čas. Nekateri se pač odločijo naredit kaj svojega in pač zmečejo v to kolikor hočejo. Meni izgleda lesen PC res nekaj lepega in če bo čas in veselje, se bom tudi jaz spravil izdelat enega. Les mi izgleda naravno, poleg vsega pa paše v prostor skupaj z laminatom, mizo, posteljo, omaro itd...
Janac, pohvale! Meni izgleda čudovit :)
dj_uro ::
d4vid je izjavil:
malce kontradiktorno tole, mar ne??? za koga boga laminat?? parket, to je tapravo, če si že ''ljubitelj'' lesa... ;)
vw-klub.si
Janac ::
Map je izjavil:
Lahk kak konkreten predlog podjetja prosim, mogoče takega s katerim imaš izkušnje? Bi bil presenčen kok močno podjetja zanima izdelava par ploščic. :P
Map ::
Googlaj prebijanje pločevine. Izkušenj s takimi podjetji nimam, jih imam bolj s takimi, ki režejo. Je pa glede na velikost teh dveh ploščic cena občutno previsoka, ker jih lahko naredijo tudi iz odpada. In pa kolikor se spoznam na izdelovanje programov za prebijalke, vem, da ti ti dve ploščici naredijo med pavzo za en six pack, ampak verjetno težko brez vsaj malo vez.
Lahko pa na plocevine.si naročiš pločevino željene velikosti in samo luknje zvrtaš ali pelješ kam drugam, če nimaš primernega stroja in svedrov.
Projekt lahko pa pohvalim, lepo napreduje. Sem mnenja, da za kar te veseli in v čemer uživaš ni škoda denarja. Največ pa je vredno zadovoljstvo ko je projekt končan.
Janac ::
Hvala Map, še bolje bi bilo, da bi bil plačan za take projekte :) Si ne predstavljam boljše službe, ampak sem se že nekako sprjaznu, da to ni realno, niti ni servis kišt :)
Janac ::
Kaj zej!! Noben s stja ne pozna ljudi k rezejo pleh z laserjem??
Janac ::
mal sem barvu. Prozoren lak za bukev, češnja pa za stranice, poličko in nogice. Najprej sem barvo nanesu s čopičem potem pa le-to enakomerno po celi površini razporedil z gobico, tako da ni kakšnih sledi čopiča.
2
3
4
5
Pred mojim potegom s gobico:
5
ter s:
6
7
Sej kr gre počas......:P
še vedno iščem nekoga, ki lasersko reže pleh? Pišem maile, potem ko ne dobim odgovora jih pokličem, povedo, da bo odgovor v parih dneh, ampak seveda nič. J*** sej jim za mini naročila zgleda :(
BorutK-73 ::
2 nanosa obvezno da pride lak do izraza, lahko tudi 3.
Janac ::
jap, imam 3 sloje v namenu. Bo pa vzelo kar nekaj časa, ker načeloma dveh strani na 1x nemorem :)
a lahko kak predlog za podjetje ki izrezuje? Eni ku''' so mi do danes obljubili odgovor, ampak seveda le-tega ni nikjer :8)
mihec87 ::
Probi še pocukat firme z vodnim razrezom...
Map ::
Mogoče plazma?
korenje3 ::
janac, podjetja ki imajo laserski razrez imajo serije v tisoč kosih. mi redno dajamo nerjaveče jeklo rezat na laser, pa se lahko kej za privat naredi.
aja pa za razrez jim moraš dat .dwg datoteko s konturo, in te podatle: material, debelina, količina
  • spremenil: korenje3 ()
Janac ::
korenje3 je izjavil:
a .dxf datoteka načeloma ni dovolj?
hvala
korenje3 ::
ja lahko je tudi .dxf ker je isti format. samo da dxf ni kompresiran se mi zdi.
Janac ::
hvala lepa. Eno vprašanje, bo rezultat isti, če grem čez s sprejem za tiste železne dele ali naj dam prašno barvat? S sprejem mislim kar brez primerja...predvsem pred rjo bi se rad zaščitil.
Moj načrt za bodoče ohišje iz ostankov
223826 (3028) huelz
CM 690 II Watercooling (strani: 1 2 3 )
12932532 (22631) Janac
Prototip ohišja (strani: 1 2 )
9250954 (40824) ingeniero
