grafa problem! :(
grafa problem! :(
DrSergioDJ ::
pa ne me j...t!
zadnje case sami problemi.
grem dans pect cd-je, pa mi vmes ugasne pc, se prizge in lej, samo 16 barv in 640x480 resolucija.
pogledam v system managerja in mi pri grafi pise:
this device cannot find enouhg free resources that it can use.
if you want to use this device, you will need to disable on of the other devices on the system.
in pol pogledas jezicek "resources" in pise:
prvi memory range je normaln, cez drugega je pa rdeca crta?
wtf?
Sh4D0w ::
Mas ksn screen shot. Pol bi si bl predstavlu-pa se ksnmu bi loh pokazov.:D
Nezaznavanje driverja (internet) - pomoč prosim!
81515 (1423) TH321
Cd in dvd se ne odzivata
51553 (1493) Sharkb1te
Nujno! Pomoc pri zaznavi CD-roma!!!
81972 (1791) pale
Problem z instalacijo Promise Ultra100 TX2 (tm) IDE Controller-jem
61896 (1808) Brane2
Mrezna kartica
71279 (1128) YouR MaMa
