Forum » Pomoč in nasveti » grafa problem! :(
grafa problem! :(
DrSergioDJ ::
pa ne me j...t!
zadnje case sami problemi.
grem dans pect cd-je, pa mi vmes ugasne pc, se prizge in lej, samo 16 barv in 640x480 resolucija.
pogledam v system managerja in mi pri grafi pise:
this device cannot find enouhg free resources that it can use.
if you want to use this device, you will need to disable on of the other devices on the system.
in pol pogledas jezicek "resources" in pise:
prvi memory range je normaln, cez drugega je pa rdeca crta?
wtf?
wtf?
| » | Nezaznavanje driverja (internet) - pomoč prosim!Oddelek: Pomoč in nasveti | 1515 (1423) | TH321 |
| » | Cd in dvd se ne odzivataOddelek: Pomoč in nasveti | 1555 (1495) | Sharkb1te |
| » | Nujno! Pomoc pri zaznavi CD-roma!!!Oddelek: Pomoč in nasveti | 1973 (1792) | pale |
| » | Problem z instalacijo Promise Ultra100 TX2 (tm) IDE Controller-jemOddelek: Pomoč in nasveti | 1896 (1808) | Brane2 |
| » | Mrezna karticaOddelek: Pomoč in nasveti | 1279 (1128) | YouR MaMa |
