RAID 1 se mi ves čas kvari na disku 2 :-(
jerry2000 ::
Imam ploščo Asus a7n8x Deluxe ter Zoltrix PCI kontroler za RAID (Silicon 680 čip)...
Izdelal sem se RAID 1 mirror z dvema enakima 120Gb 8Mb cache IBM diskoma. Najprej sem sistem inštaliral na enega, potem sem vključil RAID in v Windowsih je lepo 5 ur delalo mirror v ozadju (kar sem videl preko SilGUI programa)... Potem je bil disk narejen, vendar je pri rebootanju sistema napisalo v Windows 2000:
21-April-2003 12:11.31 Warning - SCSI Error - Not Ready
Error ocurred on Secondary Master device on adapter 0. Secondary Master - Key 02 - ASC 00, ASCQ 00 - CDB 28 00 01 96 39 37 00 00 18 00 - INFO 00 00 00 00
Error ocurred on Secondary Master device on adapter 0. Secondary Master - Key 02 - ASC 00, ASCQ 00 - CDB 28 00 01 49 0d 72 00 00 08 00 - INFO 00 00 00 00
Error ocurred on Secondary Master device on adapter 0. Secondary Master - Key 02 - ASC 00, ASCQ 00 - CDB 28 00 01 b8 f7 8d 00 00 08 00 - INFO 00 00 00 00
Error ocurred on Secondary Master device on adapter 0. Secondary Master - Key 02 - ASC 00, ASCQ 00 - CDB 2a 00 06 ed f8 3e 00 00 08 00 - INFO 00 00 00 00
21-April-2003 12:11.31 Warning - Member dropped
Set 0 dropped Secondary Master device on adapter 0 due to a SCSI error. SRB status was Error With Bus Status.
Secondy master sem moral odstraniti in ga ponovno dodati. Zdaj spet rebuilda mirror in to bo delalo še nekaj ur...
Je komu kaj jasno, kaj bi lahko privedlo do errorja in kako naj se mu izognem? Če bom ves čas rebuildal, je brez veze da imam raid :-(
Jernej
Ali bo disk crknil?
282371 (1916) BlackHole
NEC DVD ND-4550
91985 (1821) jernejk90
Težave s pekačem
122375 (2315) boštjan
PLEXTOR BurfProof unicuje cdje - prosim pomagajte!
92163 (1917) krho
Problem Hard disk za strokovnjake za win2k
222110 (1778) Alec999
