Forum » Pomoč in nasveti » Win 8 / Win 7 ?
Win 8 / Win 7 ?
nareditm test pri 512MB. For shit and giggles :)
evo, 232MB "porabljenega" rama. Nikjer ni videt claimanih 145MB
Gremo na 256MB ?
Gremo na 256MB ?
- spremenil: iloveboobz ()
Evo, na 256MB... Boots just fine. Pustim na mir ene par minut, da mal poswapa. Mogoč nam rata 145MB :)
Evo, imamo zmagovalca. I take it back. tiny7 je res bolj varčen z ramom... Ko ga prisiliš do dna
Spajky, mislim, da imam kanditata za tvojga Tualatin-a
//dost šale, back on topic :)
novejši frameworki nedelajo, pravtako ne service pack 1. Za updejte nwm (najbrž neboš dobil vseh, ker nimaš sp1).
Za igrat pa je :)
PS:
po 10 minutah idla je že na 116MB :)
PS2:
upam, da je dovolj jasno, da gre za ilegalne, doma zvarjene winse.
Za igrat pa je :)
PS:
PS2:
trnvpeti ::
no, celo na 116 si prisel :)
in kako je mozno, da je vse od microsofta gor, spremenjene so samo nastavitve, da se tako hitro boot-ne
in da servici ne pozrejo nic rama in se nic ne pozna pri bootu?
ni res. Porezanih je precej stvari.
REMOVED ITEMS PART 1/3:
DISM
With DISM the following packages were REMOVED:
Hyper V Common Drivers, Hyper V Guest Integration Drivers, Anytime
Upgrade Results, Backup, BLB Client, Business Scanning Feature,
Clips In The Library, Client Wired Network Drivers, Common Modem
Drivers, Printer Drivers, Tuner Drivers, Win Ocr, Gadget Platform,
Group Policy Client Extensions, IIS Web Server Add On, IIS Web
Server Add On 2, Indexing Service, IE Troubleshooters, Links,
LocalPack AU/CA/GB/ZA/US, Mobile PC Client Sensors, Optical Media
Disc, PeerDist Client, Printing XPS Services, RasCMAK, RecDisc SDP,
Sample Content Ringtones, Secure Startup, ShareMedia Control Panel,
Shell HomeGroup, Shell Inbox Games, Sidebar Killbits SDP, Snipping
Tool, Sticky Notes, Terminal Services Command Line Tools, Terminal
Services Misc Redirection, Terminal Services Publishing WMI Provider,
Terminal Services Remote Applications Client, Terminal Services USB
Redirector, Terminal Services WMI Provider, Windows Media Player
Troubleshooters, WMP Network Sharing Service, XPS Foundation Client,
Networking MPSSVC Rules Ultimate Edition.
REMOVED ITEMS PART 2/3:
DELETED DIRECTLY FROM MOUNTED IMAGE:
About 550Mb was removed from:
Windows\System32\DriverStore\FileRepository\
About 585Mb was removed from:
Windows\winsxs\
These items were: Printer Drivers, Modem Drivers and Camera Drivers.
Other miscellaneous items were removed like the contents of the
Recovery folder and certain folders from the Web folder.
REMOVED ITEMS PART 3/3:
vLite
In vLite the following items were REMOVED:
(vLite "Last Session.ini" is included in the sources folder)
REMOVED - [Accessories]
Accessibility, Inbox Games, Premium Inbox Games, Mobility
Center, Speech Support, Windows Sidebar and Gadgets.
REMOVED - [Drivers]
Diva Server, Modems, Scanners, TV Tuners.
REMOVED - [Languages]
Chinese, Japanese, Korean.
REMOVED - [Multimedia]
Media Center, Music and Video samples, Sample Pictures,
Screensavers, SideShow, Sound Recorder, Windows Media
Codecs, Windows Media Player.
REMOVED - [Network]
Connect to a Network Projector, Internet Information
Services (IIS), Remote Desktop and Assistance, Remote
Desktop Client, Simple Network Management Protocol
(SNMP), Simple TCPIP services, Telnet Client, Telnet
Server, TFTP Client, Windows Collaboration, Windows
Mail.
REMOVED - [Services]
Diagnostics, Error Reporting, Offline Files, Remote Registry,
Routing and Remote Access, TPM Base Services, Windows Search.
REMOVED - [System]
BitLocker Drive Encryption, Crash Dump Support, Digital
Rights Management (DRM), Help, IMAPIv2 Burning Support,
Manual Install (Setup.exe), Microsoft Message Queue (MSMQ),
Natural Language, Parental Controls, Performance Counters,
Reliability and Performance Monitor, Remote Differential
Compression, Security Center, Software Quality Management
(SQM), Sync Center, System Restore, Tablet PC, Windows
Defender, Windows Easy Transfer, Windows SAT (Performance
Index).
Seznam odstranjenih zadev.
trnvpeti ::
to lahko naredis na svojem kupljenem win7, in ne bos nic krsil
se enkrat, kako servici nic rama ne pozrejo?
in kako se manj servisov isto hitro boot-a?
testiraj in poročaj, kako se lahko približaš tiny-u po boot času in porabi rama :)
Kakšen podoben setup, vendar posodobljen z sp1 in zadnjimi updejti in jasno brez raznih buildin aktivacij (da lahko sam aktiviraš) bi bli prastari kompi precej veseli. Afterall je out there še dosti kišt, ki niti ne dosegajo minimuma za win8 (sse2, pae, nxbit) :)
Mesar ::
Bo pa dalj časa podprt, če hoče šparat pa naj XPje da gor, ti najmanj vsega porabijo.
w8 bo kmalu zginal(nadomestil ga bo w10), w7 bo se pa nekaj casa ziv
lastnik se pa odloci, katerega bo dlje podpiral
Če z tem "nekaj časa" misliš nekaj mesecev, potem ja... http://windows.microsoft.com/en-us/wind...
Your turn to burn!
trnvpeti ::
po tvojem bo imel ms 3/4 vseh sistemov izven podpore jan 2015?
zanimivo...
treba je priznat, da se win7 ne drži tak status kot winxp, zato je precej nerealistično pričakovat, da bojo kej podaljševal te roke. :)
trnvpeti ::
in za enkrat najbrž tud win 8 ni Vista, da bi šla v pozabo, ko bo 10 zunej
ce bo nadgradnja iz w8 na w10 for free, bo w8 zginal v trenutku
a misliš, da bodo vse tajnice šle nadgrajevat w8 ? :)
trnvpeti ::
iloveboobz je izjavil:
ce so tajnice sedaj nadgradile iz w7 na w8
bodo sigurno sle tudi na w10
kaj če so sedaj nadgradil iz winxp na w8, pa bojo spet 10 let fural isto ? :)
Sj ne pravim, da bo w10 uptake majhen. Ampak da bodo kar _vsi_ prešaltal na w10 je pa mal bosa. Afterall, w10 je vedno lahko flop.
trnvpeti ::
tudi ce so tajnice nadgradile iz xp na w8(ce ze niso sle nazaj na w7), pol komaj cakajo na w10
trnvpeti ::
ms ne bo dopustil prodaje novih racunalnikov z w7 od 31 oktobra
http://news.softpedia.com/news/Dell-Not...
krneki0001 ::
Windows to go (Windows 8 iz usb ključka) preverjeno delajo na 512mb rama v thin clientu od HP-ja (512mb ram, amd 2100mhz procesor in 4gb flash disk).
krneki0001 ::
Počasi.
Hec je v tem da se štarta na toliko rama, čeprav so povsod jamrali, da mora biti minimalno 1Gb.
Slučajno sem sprobal, ker sem hotel enga thin clienta sprobat, če vse deluje, pa sem napačen ključek vstavil in se je osmica štartala. Malo se zatika, ampak če bi dal še 512Mb rama zraven, bi pa najbrž že čisto normalno delovalo.
hmm? ::
https://www.mimovrste.com/programska-op... To je za kupit? kje se dobi najjače in najcenejše windows os?
tomaz88 ::
krneki0001 je izjavil:
Počasi.
no poskusi odpret brskalnik + kakih 10-20 tabov in potem reci da dela :)
solatko ::
tomaz88 - Čemu pa bi normalen uporabnik odpiral 20 tabov, če ve, da ima podhranjeno mašino, ki pa v xp sp3, deluje še počasneje in manj odzivno.
Večina jih rabi 1-3 tabe, ki pa na starih mlinčkih lepo delujejo, če ni na vseh treh video posnetek.
Delo krepa človeka
| » | windows 8.1 (strani: 1 2 )Oddelek: Pomoč in nasveti | 21039 (15143) | solatko |
| » | star Laptop LENOVO T61 - kateri operacijski sistem?Oddelek: Operacijski sistemi | 4981 (4630) | Zvezdica27 |
| » | Kateri OS za prenosnik AMD Turion 64 X2 Mobile TL-60??? (strani: 1 2 )Oddelek: Operacijski sistemi | 15800 (14235) | T_F_7 |
| » | na kaj paziti pri instalaciji win7Oddelek: Pomoč in nasveti | 5067 (4850) | Ikspe |
| » | Windows BlueOddelek: Operacijski sistemi | 4492 (3397) | axee |
