Primerjava vojaške tehnike
Cervantes ::
Fantje, ne se sekirat zarad F35.
Bojo pač vsak prvi torek v mesecu downlodal tistih 30+ updejtov, problem rešen.
Tezaab ::
Cervantes je izjavil:
Kaj, a misliš, da se bo po vsakem pristanku F35 na HUD-u pojavil vojaski ekvivalent Clippy-ja in dejal "Hi! It looks like you've landed successfully. Would you like to check for updates?" ? :D
sisemen: "Inženirstvo je v nenehni tekmi z vesoljem. Trudi se izdelati
tehnologijo, ki je odporna na idiote, vesolje pa se trudi izdelati vedno
hujše idiote. In vesolje zmaguje."
vostok_1 ::
Tezaab je izjavil:
That would be....amazing
There will be chutes!
It came from the lab.
Cervantes ::
Je hudič, tole se ti zgodi med poletom, imaš na automatic update, in mašina se resetira...
Colt1911 ::
pa SU-27 za ritjo.....:D
Ha-ha-ha, medtem na Red Flag 17-1
https://theaviationist.com/2017/02/28/r...
Indeed, while early reports suggested a 15-1 kill ratio recent Air Force testimony by Lt. Gen. Jerry D. Harris, Vice Commander of Air Combat Command characterized the kill ratio as “20-1” meaning that, for one F-35A “lost” in simulated combat in a high threat environment that the aircraft destroyed 20 simulated enemy aircraft.
The recently revealed reports suggest that large-scale F-35A strikes were conducted in a highly contested/denied aerial environment. Air Force F-35As penetrated denied airspace and directed standoff weapons from B-1B heavy bombers flying outside the denied airspace. Those strikes destroyed simulated surface to air weapons systems.
At Red Flag 17-1 the F-35A also included additional roles previously reserved for air superiority aircraft like the F-15C Eagle and heavy strike capability from large bombers while even performing “light AWACS” duties.
“I flew a mission where our four-ship formation of F-35A’s destroyed five surface-to-air threats in a 15-minute period without being targeted once,” Major James Schmidt, an F-35A pilot for the 388th Fighter Wing from Hill AFB told the Air Force Times.
“After almost every mission, we shake our heads and smile, saying ‘We can’t believe we just did that’ Schmidt told reporters.
V tem je catch, F-35 lahko neopažen kuri strelivo z drugih platform, roba na letalu je bolj za rezervo.
Najboljši F-35 video ever, samo prvih par minut blablaja je potrebno zdržat
vostok_1 ::
Oj. Se komu sanja kaj imajo naši pilatusi od opreme za vizualno daljinsko zaznavanje?
Nikjer ne vidim, da bi imeli kako optiko v "podvozju".
Verjetno se konča pri HUD-u.
ZDA so naredile soliden premik v Evropo.
Bremerhaven:
Poljska:
Riga:
Thessaloniki:
Romunija:
konspirator ::
pakman
Spet Nori Američani Tovorijo Orožje. Ali obramba do zadnjega Nemca/Litovca/Estonca/Poljaka ?
Pred kom točno ? In kdo jih je klical ? Saj ima vsaka Eu država svojo vojsko.
Malo zamujajo.
1.5 milijona Ahmedov je že šlo mimo vseh mej v Eu.
Ko so Rusi na Kubo privlekli 1962 privlekli jedrske konice so imeli kavbojci prste že na sprožilcih nared za ww3, ko se sedaj dogaja obratno pravijo da Rusi provocirajo.
Še dobro da se povprečnemu Janezu ne sanja koliko nukic so kavbojci že navlekli v Eu (in koliko izgubili).
Isotropic ::
Mr.B je izjavil:
Večina tankov itak zazna prihajanje atgm-ja, in se kupola avtomatično obrne v smeri od koder je pričlo, seveda če imaš dovolj časa. Oziroma če nimaš ravno neusposobljene vojske se lahko zgodi da bo to edini strel, ki ga boš naredil, ker bo proti tbi že letela tankovksa granata.
aja, kako pa? :D
fire control od fotone in nekateri ruski tanki so imeli/ imajo laser irradiation detector, zahodni tanki jih pa večinoma nimajo.
pa itak ti večinoma ne pomaga veliko, ker so atgm večinoma optično vodene, brez laserja.
Isotropic je izjavil:
Mr.B je izjavil:
aja, kako pa? :D
Večina novih ATGM-je avotmatično vodena, problem je le, ko se vključijo pasivne in aktivne začite, takrat mora operater pač biti zelo sposoben in ročno voditi le to do cilja, kar pa pomeni da je velika verjetnost da ga bodo drugi zasledili in tudi poslali v večna lovišča. Turkey shutting kot je bilo videno za turke, je bolj retkost, ker tudi vsi posnetki so bili ponavadi en tank only.
vostok_1 ::
Kaj točno misli Trump delat z temi premiki. Probably spend some public money.
Potem ostane možnost, da kao ščitijo nato zaveznice, Rusiji pa pustijo prosto pot v jugo-vzgodni ukrajini.
Mogoče pa sta se ta dva stara prdca odločila, da bosta imela malo akcije preden gresta v pokoj. For good ol' times sakes.
Jasno je, da večina folka na stara leta hrepeni po tem kar so počeli v 20tih svojega lajfa. In vsi vemo kaj je počel Putko.
sivistol ::
vostok_1 je izjavil:
to še je vse obamovo maslo,
7982884e ::
konspirator je izjavil:
Pred kom točno ?
pred enimi, ki so si pred nedavnim aneksiral del sosednje drzave in ki se vedno ohranjajo zanikano okupacijo dela te drzave
In kdo jih je klical ?.
sosednje drzave od drzave, o kateri je govora
PAK FA deluje tako dobro, da bodo Rusi skupaj z Združenimi Arabskimi Emirati razvijali novo letalo (kao) 5. generacije, osnovano na MiG-29.
http://www.popularmechanics.com/militar...
Letalo je imelo prvi polet manj kot mesec dni za F-35, ki je v omejenem obsegu že operabilen, leti že več kot 200 primerkov. Isto leto kot bodo Rusi - po najbolj optimističnih napovedih - začeli z LRIP (nekaj primerkov letno) bo Lockheed Martin začel s serijsko proizvodnjo po več sto F-35 letno.
Ampak bojda je bil F-35 strašen zamudnik! :))
Smrekar, glej, razvoj PAK FA ima velike težave zaradi pomanjkanja denarja. Ga iščejo pri Indijcih in sedaj kot praviš še pri ZAE.
Poglej si vojaška proračuna USA in Rusije, pa mislim, da ti je vse jasno.
"Ampak bojda je bil F-35 strašen zamudnik!"
To ti pa omenja-jo/mo zato, ker trdiš, da gre razvoj F35 po načrtih in da je letalo popolno in brez napak.
Pri ZAE iščejo denar za popolnoma drugega lovca 5. generacije, osnovanega na drugem letalu. Če bi PAK FA bil kakorkoli blizu proizvodnji bi prodajali tega in ne metali stran denarja za popolnoma novo letalo.
Ameri imajo 2 lovca 5. generacije, F-22, ki je "high" del mešanice v smislu sposobnosti boja proti drugim lovcem in F-35, ki je namenjen za vse ostale naloge. Rusi bi imeli dva lovca, ki bi imela enake naloge.
Ali so rusi tako nesposobni, da ne vidijo, da je to metanje denarja stran, ali je PAK FA nasedel na čereh in potem je prišla oseka.
Prosim, podaj povezavo do te trditve.
Veliko sreče! :D
Smrekar1 je izjavil:
Veliko sreče! :D
Verjetno zato tako panično vlagajo v novo generacijo DSP-ja za ammram.
X-35 first flight -> 24.10.2000
F-35 first flight -> 15.12.2006
PAK-FA first flight -> 29.01.2010
Malo preberi preden pišeš neumnosti...
Bi rekel da je imel F-35 10 let fore pred PAK-FA. No, 9 in par mesecev...
Mr.B je izjavil:
Ameri so tako zaskrbljeni nad inferiornostjo svojih raket, da so leta 2013 ukinili razvoj nadomestne rakete za AIM-120 in AIM-88 in bodo ostali kar pri stari robi, ker je več kot dovolj dobra.
Mr.B je izjavil:
Öe jim je pa obamakcar zmanjšal budget.
Bom dal sem.
Beloruska policija se ne zaje***a. Premakni rit ali pa te splužijo z vodnim topom.
https://twitter.com/Belsat_Eng/status/8...
Morda za podiranje barikad?
  • spremenilo: Pac-Man ()
Scaramouche ::
Pak fa mene spominja na film Blue thunder in helikopter ki je zame točno to kar je pak fa..
If you get the hint? 8-)
konspirator ::
V Belorusiji spet Soroš NGO v akciji ?
PAK-FA so spet prestavili za vsaj 1 leto. Nekaj mesecev nazaj so govorili, da jih bodo dobili po letu 2017, zdaj "bodo razmislili" o začetku prvih dobav enkrat po letu 2018, "ko letalo konča testiranja".
http://mil.today/2017/Weapons45/
  • spremenil: Smrekar1 ()
Loocas ::
Matev - najslabši troll vseh časov
Verjetno danes niso leteli, ker so jih streljali sirjci...
Loocas je izjavil:
Israel may have already used new F35s in January for missile strike in Syria
Očitno se je dolgo in počasno uvajanje izplačalo. Letala so nared za uporabo praktično takoj, plug'n'play varianta.
Loocas je izjavil:
Sej vem da za Slovence, js ploh značilno slogani Baje in naj bi.
http://www.pogo.org/straus/issues/weapo...
En povzetek težav, če se komu ljubi brati...
To je samp prvoaprilska šala.
Še eno zadevo, Američani se zeloo zanašajo na to integrirano varno komunikacijo med različnimi letali AWACS, sateliti, ladjami etc, da dobijo big picture prevlado. To je sicer uspešno, ko vržeš v akcijo orožarjkega stroja ki je večji od BDP-ja države, ki jo napadaš. Takoj ko nastopiš prdti državi, ki to lahko onemogoči, kot je to na primer Rusija ali Kitajska, postane stelth za kar je namenjen neuporaben. Takrat boš vedno začel z takimi in drugačnimi raketiami daleč od dosega česarkoli oni lahko uporabijao. Pa še to se boš moral napratrat, ker GPS bo za tak scenarij neuporaben.
konspirator ::
Članek objavljen 2 dneva nazaj, 30.3.2017 .
Invictus je izjavil:
Stalno eno in isto nabijanje. F-35 je neefektiven kot lovec, ker je kao F-16 bolj okreten, čeprav je nosil dva dodatna rezervoarja za gorivo. Kar ti ne povedo pa je to, da je bil tisti test namenjen ugotavljaju katere programske omejitve maneviranja bi se plačalo ukiniti.
Plus dodatni rezervoarji za gorivo na F-16 niso bili tam da bi bil lovec manj okreten, ampak zato, da so lahko teste opravili v enem poletu.
F-16 ima namreč precej manj dosega kot F-35.
Koliko je F-35 neefektiven kot lovec je pokazala Rdeča zastava. Proti kombinaciji F-15 in F-16 s podporo radarjev na tleh so uspeli sklatiti nekako 1 F-35 na 20 izgubljenih F-15/16. V tem razmerju lahko dve do tri eksadrilje F-35 obračunajo s katerokoli državo. No, edino za Ruse in njihovih 1000 lovcev bi eventuelno rabil 4 eskadrilje, nekje 60 letal.
Trenutno imajo ZDA 71 aktivnih F-35A in še nadaljnih 47 v uvajanju.
Smrekar1,
Smrekar nima ne dosega ne stelth spsosbnosti da bi vodil prvo vlogo napada. Ko ni več SAM namestitev, je pa totalno vseeno kakešn lovec X generacije to je. To se je pokazalo tako v Iraku kot v Siriji, F35 pač ni pripravljen za nobeno vlogo.
Še huje, ko američanom onesposobiš vso to "battlefield awareness", niso sposobni izstreliti niti raket, ker ne vejo kej / ne kam. Vključujoč z GPS in satelitsko komunikacijo, in to ni samo domena Rusov/Kitajcev. S tega razloga, so tudi v uporabi small diameter bomb, ki imajo dosege verjetno tudi do 150 km.
Še huje tako F35 brez F18 growler sploh ne more leteti, in F18 growler bo dobil leta 2020 nove jammerje. PRav tako F22 potrebuje F18 growler podporo.
Še huje, danes leteti z aktivnim Jammingom je tako kot bi narisal tarčo, skoraj vsaka ruska cigara zazna jamming in se samo usmeri na jamming vir, razen če ga le ta zna projecirat recimo 20 m od letala.
Mr.B je izjavil:
Smrekar1,
To je bržkone res, vendar nisem vedel, da sem po novem bojni stroj. Lahko mogoče polinkaš kakšne sposobnosti imam?
To velja za vse vojaške sisteme. Razlika je v tem, da ameri aktivno delajo na tem, da to sovragu zanikajo.
Ruski pristop je, da gradijo akrobatska letala. Vsakemu svoje.
Link? :))
Sumim, da nimaš pojma kako jamming deluje.
Tezaab ::
Mr.B je izjavil:
Smrekar1,
Bojni stroj: Smrekar
Država porekla: Slovenija
Bojni radij: slo-tech.com
Hitrost: 150wpm
Odzivni čas: hiter
Oborožitev:
-enciklopedično poznavanje bojne opreme vseh držav našega planeta
-napreden nivo sarkazma
-ostala oborožitev je tajna
:D
  • spremenilo: Tezaab ()
Hvala! :))
Mislim, da ti ne veš, kaj je to "Home on Jam" ;).
Kako pa misliš da HARM deluje?
vostok_1 ::
Kaj še se ukvarjate z arhaičnimi oborožitvenimi sistemi?
Se vam da ej.
Vem kaj je "home on jam".
Pa ti veš kaj je nizka opaznost?
Rusi tudi ne.
Tako, da se usmeri na ciljan radar oz. njegovo zadnjo znano lokacijo. Razlika med to lokacijo in lovcem je, da so lovci precej bolj okretni in mobilni od talnih radarjev.
Saj konstanten jamming non-stop sporoča lokacijo ;).
Kaj ima nizka opaznost veze z jammingom, boš pa ti razložil...
  • spremenil: Invictus ()
Smreki, tis e kar na symantico obešaj. Dejstvo je in desjtzvo ostaja, da F35 ni in še verjetno zelo dolgo ne bo viden v akciji, za kar je kao namenjen.
Veze ima v toliko, da rabiš eno ali drugo in ne obojega. Zdaj pa ti obrazloži zakaj bi imel stalno vklopljeno motenje radarjev. Hvala :D
Mr.B je izjavil:
Dejstvo je in dejstvo ostaja, da je F-35 boljši od vsega, kar pride iz Rusije in Kitajske in da bo tako ostalo še kar nekaj desetletij.
Vanich ::
SimplyMiha ::
Bom dal sem.
Mr.B je izjavil:
Dejstvo je , da F35 še ni bil v nobeni operaciji, kjub slavni superiornosti, proti praktično čemerkoli, kar lahko .......
konspirator ::
Kaj ne veste da ima f-35 jammer obešen na pletenici, ki plapola 500m za njim.Tako AA če kaj zadane, je to jammer :)).
Isotropic ::
Loocas je izjavil:
a maš lahko tako oprane možgane?
f-35 še v ameriki ni dosegel IOC, kje ga bo šele izrael imel že v operativni uporabi? ali trdiš, da ni res?
tisti napad so izvedli z manevrirnimi raketami, izstreljeni z f-16 nad (najbrž) libanonom kot dosedaj. ni to nekaj novega.
Loocas je izjavil:
Napad so naredili z Small diameter bomb Doseg 110 km. Cilj je doseöi 150 km, ker vejo da ko rusi vklopijo svoje EC sistem, je bubble 150 km, se mi ne da iskat...poičite sami. To pomeni, da mnogo Integriranega orožja ne bo funkcionirali. Prav tako Amerji hitijo z novim DSP-jem za Ammram, ker vejo da verjetnost zadetka z eno rakote bore malo, pa še to imajo rusi rakete bistveno daljšega dosega. Potem pa se še vprašajte, koliko časa potrebuje da S400 zadene AWAC na meji dosega S400.
In da Dekoy vabe se uporabljajo, samo da F35 je čal premalo "stelth", in rabi podporo F18.
Isotropic ::
110km jadranja je zelo teoretičen doseg, najbrž pri supersonic hitrosti spusta bombe in zelo zelo visoko (najbrž tudi lob profile).
razen tega jadra dolgo časa in je tačas vidna vsem možnim radarjem (tisti ruski sistem kratkega dosega, ki ga imata iran in sirija, je namenjen ravno temu).
http://warisboring.com/israel-bombed-da...
51 / 100
21865887 (62100) fikus_
Neznani leteči predmet v Zagrebu morda Tu-141 (strani: 1 2 3 4 )
18745331 (37794) D3m
Poletel prvi brezpilotni soborec
3816994 (14892) gus5
