Indikator pri bateriji
diversee ::
Ali mogoče kdo ve, kako deluje indikator za preverjanje kapacitete, kakršnega lahko vidimo
pri duracel turbo max bateriji.
  • spremenil: diversee ()
negotiator ::
The little disposable battery testers that you see on batteries or battery packages are a great example of combined technologies -- several existing technologies have been combined in a completely new way! Battery testers depend on two special types of ink: thermochromic and conductive inks. Thermochromic ink changes color depending on its temperature. Conductive ink can conduct electricity. By applying layers of these special inks along with a layer of normal ink using a fairly normal printing press, it is possible to create an extremely inexpensive printed design that changes depending on the amount of electricity it receives.
več na: http://electronics.howstuffworks.com/ev...
All easy problems have already been solved.
diversee ::
Mogoče veš, kje bi dobil kaj takšnega?
negotiator ::
da bi dobil samo tisti del, ki spremeni barvo, ne vem, je pa verjetno najbolje, če na ebayu poskušaš dobiti čim ceneje te baterije in vzameš dol, kar rabiš.
Parfumi/toaletne vode
286534 (2590) mihecz
Kako deluje kartuša?
111862 (1455) vir
Novi Kindli (strani: 1 2 3 )
11151410 (46161) bojsi
Conductive INK pen
51596 (1399) blblb
conductive ink pen
61372 (1302) SodVina
