Forum » Elektrotehnika in elektronika » Indikator pri bateriji
diversee ::
Ali mogoče kdo ve, kako deluje indikator za preverjanje kapacitete, kakršnega lahko vidimo
pri duracel turbo max bateriji.
- spremenil: diversee ()
negotiator ::
The little disposable battery testers that you see on batteries or battery packages are a great example of combined technologies -- several existing technologies have been combined in a completely new way! Battery testers depend on two special types of ink: thermochromic and conductive inks. Thermochromic ink changes color depending on its temperature. Conductive ink can conduct electricity. By applying layers of these special inks along with a layer of normal ink using a fairly normal printing press, it is possible to create an extremely inexpensive printed design that changes depending on the amount of electricity it receives.
več na: http://electronics.howstuffworks.com/ev...
All easy problems have already been solved.
negotiator ::
da bi dobil samo tisti del, ki spremeni barvo, ne vem, je pa verjetno najbolje, če na ebayu poskušaš dobiti čim ceneje te baterije in vzameš dol, kar rabiš.
| » | Parfumi/toaletne vodeOddelek: Loža | 6534 (2590) | mihecz |
| » | Kako deluje kartuša?Oddelek: Loža | 1862 (1455) | vir |
| » | Novi Kindli (strani: 1 2 3 )Oddelek: Novice / Ostale najave | 51399 (46150) | bojsi |
| » | Conductive INK penOddelek: Elektrotehnika in elektronika | 1596 (1399) | blblb |
| » | conductive ink penOddelek: Elektrotehnika in elektronika | 1372 (1302) | SodVina |
