Unbrickanje routerja problem
denisek123 ::
Pozdravljeni
Po tem navodilu sem želel unbrickati router TP-Link wr941nd.
http://thomasheinz.net/tp-link-router-d...
Skoraj do konca vse gre, ko pa v program PuTTY vpišem ukaz reset, takrat se zače neskončno resetirati in napiše mi to napako:
too big uncompressed stream lzma error 1 must reset to recover board
Kaj naj storim, oz. kaj delam narobe ?
Intel Core i3 3217u/GeForce 720M/WIN 10
s6c-gEL ::
https://forum.openwrt.org/viewtopic.php...
Lahko da brišeš, zapisuješ v napačne naslove:
tftp 0x80800000 openwrt.bin
erase.b 0xbf020000 +0x3c0000
cp.b 0x80800000 0xbf020000 0x3c0000
O tem je govora
ar7100> setenv serverip 192.168.1.254; setenv ipaddr 192.168.1.1
ar7100> tftp 0x80800000 openwrt-ar71xx-tl-wr941ndv2-squashfs.sysupgrade.bin
ar7100> erase.b 0xbf020000 +0x3c0000
ar7100> cp.b 0x80800000 0xbf020000 0x3c0000
ar7100> reset
Note #1: 0x3c0000 is the size of the firmware, be aware that you may have a different size thus bricking your router.
Note #2: 0xbf020000 is the from addr, for your device version you can get it by issuing the command: "printenv bootcmd", not doing so will turn your router into a brick.
Katero verzijo imaš (ker pri tplinku so zmeraj vsaj 2) ?
6 jih je
http://wiki.openwrt.org/toh/tp-link/tl-...
  • spremenilo: s6c-gEL ()
denisek123 ::
Verzija 5.1
OpenWrt ip naslov?
Oddelek: Omrežja in internet
254639 (4158) lebang1
Router brickan?
175153 (2476) AštiriL
Zabrickan - zafleširan router TP-LINK TL-WR741ND
385076 (3356) markk1
"unbrick" routerja
142685 (1990) granci
xserver-xree86
Oddelek: Operacijski sistemi
61876 (1788) Skrat
