IPv6
IPv6
8 / 8
Gapi ::
A slo-tech.com ni več na IPv6?
No person is rich enough,to buy back his past.
Maximus ::
Gapi je izjavil:
naj bi bil :)
Addresses: 2001:67c:2730:1::2
91.236.1.130
NoName ::
nekaj je teorija, drugo pa praksa
# traceroute6 -T -p 443 -f 3 -m 10 slo-tech.com
traceroute to slo-tech.com (2001:67c:2730:1::2), 10 hops max, 80 byte packets
 3  2a01-260-1-1--0.core6.t-2.net (2a01:260:1:1::)  7.335 ms  7.274 ms  7.282 ms
 4  2001:7f8:46::19:8524 (2001:7f8:46::19:8524)  11.981 ms  12.065 ms  12.028 ms
 5  * * *
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
# curl -Iv https://slo-tech.com
* About to connect() to slo-tech.com port 443 (#0)
*   Trying 2001:67c:2730:1::2...
* Connection timed out
*   Trying 91.236.1.130...
* Connected to slo-tech.com (91.236.1.130) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
*   CAfile: /etc/pki/tls/certs/ca-bundle.crt
  CApath: none
* SSL connection using TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
* Server certificate:
*       subject: CN=slo-tech.com
*       start date: Sep 26 00:00:00 2021 GMT
*       expire date: Sep 26 23:59:59 2022 GMT
*       common name: slo-tech.com
*       issuer: CN=Sectigo ECC Domain Validation Secure Server CA,O=Sectigo Limited,L=Salford,ST=Greater Manchester,C=GB
> HEAD / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: slo-tech.com
> Accept: */*
I can see dumb people...They're all around us... Look, they're even on this forum!
  • spremenil: NoName ()
Maximus ::
Sem preveril in res naredi timeout na IPv6.
@slotech admini, je to pričakovano?
mujek ::
Informacija z telemacha dne 12.10.2022:
IPv6 protokol je trenutno v testni fazi in ga žal še ni možno uporabljati.
Nažalost tudi nimamo še točno določenega časovnega obdobja kdaj bo, vendar na grobo se predvideva naslednje leto.
Gapi ::
Telemach ima IPv6 v testni fazi že nekaj let. Tako da Telemach uporabniki bodo še nekaj let brez.
Na A1 tudi ni. Mogoče na zahtevo.
Od "zdaj pa je" smo še zelo daleč.
jotunn2 ::
Ce smo realni... neke strasne skode ni, tudi ce home userji tega nimajo. ;)
mujek ::
Nova informacija iz telemacha (10.10.2023):
Po posvetu s tehnično službo vas obveščamo, da IPv6 ne ponujamo preko kabelskega omrežja in tudi nimamo nobenega podatka o tem, ali sploh bomo omogočali to storitev.
SasoS ::
Čudno vse skupaj...jaz sem konfiguriral ipv6 pred desetimi leti na T-2, potem je enkrat kasneje crknilo, nekaj sem jim pošiljal maile pa se ni noben javil. Potem sem vse kar je bilo povezano z ipv6 izklopil in od takrat vse dela bp.
Zadeva sicer raste, ampak ja, počasi: https://www.google.com/intl/en/ipv6/sta...
Bo treba uvest obvezni 50ms penalty na ipv4 povezave da malo pohitri :)
  • spremenil: Lonsarg ()
krho ::
SasoS je izjavil:
Ja, prej so dobil fixen prefix, sedaj gre preko SLAAC, sam to vsaj meni povzroča probleme in na pfSense in sedaj na OPNsense. E.g ko se zamenja ipv6 crkne vse kar je na ipv6 do restarta routerja :(
  • spremenil: krho ()
Dual Stack je sam neka začasna rešitev, to ni mišljeno za dolgoročno rešitev ker je potem vsa konfiguracija dvojna. The way to go je IPv6 only na nivoju ISP povezave in na mrežnih napravah in nato NAT64 na nivoju posameznih klientov (torej da že klienti sami ko vidijo da je IPv6 only enkapsulirajo IPv4 promet v IPv6 promet in se to naknadno dekapsulira na nivoju ISPja ali celo na nivoju internetne hrbtenice). To že dela by dizajn na LTE mobilnem internetu in LTE mobilnih napravah. Je pa lahko problem s kakimi 10+ let starimi klienti, zato je za ISPje za domači internet to mal nevarno uvajat. Bodo kaki stari internetni printerji nehali delati in bodo dobili jezne stranke :)
Morda je rešitev NAT64 na nivoju ISP routerjev, da je firewal ter navzven IPv6 only, znotraj pa oboje. Sam ne vem če kak router to podpira.
Klemen86 ::
T2 podeljuje prefixe in ipv6 naslove preko dhcpv6, ne SLAAC. Jaz sem imel probleme z vzpostavitvijo Wireguarda preko ipv6, ker se mi je ob vsakem restartu routerja ipv6 prefix spremenil. Wireguard server (openwrt router) je na t2 omrežju. Po pogovoru s t2 supportom, smo ugotovili, da ob restartu router vedno pošlje še release ukaz. Nato sem nastavil, da se release ukaz ne izvede. Sedaj imam, podobno kot na ipv4, dinamični ipv6, ki pa se nikoli ne spremeni.
  • spremenil: Klemen86 ()
8 / 8
OŠO Optika IPv6
Oddelek: Omrežja in internet
344909 (3540) Bakunin
Način povezave v internet na optiki
176114 (5406) AndrejO
IPv6 najbolj razširjen v Švici, Slovenija ni slaba
3115608 (12838) Bakunin
Jutri svetovni dan IPv6 (strani: 1 2 )
9922422 (19418) Spock83
par osnovnih vprašanj o IPv6
225889 (4908) x.sci
