problem v startingu
problem v startingu
jasa123434 ::
ko prižgem comp. mi ven vrže tole:
there was a problem starting
C/user/****/AppData/Roaming/newnext.me/nengine.dll
navedenega modula ni bilo mogoče najti
comp. se prižge normalon in deluje normalno le na začetku mi to vrže ven(stalno)
kaj bi bilo to??
Duhec ::
Zdaj pa še povej kaj več, kakšne težave si imel prej, ker samo od sebe se to ne zgodi. :)
Po vsej verjetnosti je to ostanek spyware zajedalca, ki mu manjka dotični .dll, da se nahrani in oživi. Očitno ga je nek antivirus/antispyware program pohabil, ostal pa ti je vnos v registru ali startup mapi.
Z MSsconfig-om poglej, če se kaj nahaja v mapi Zagon (Startup) kar diši po tvojem problemu, označi vrstico, shrani in restartaj komp.
knesz ::
Virus, spyware, malware? Klik
I had the same problem and fixed it running a boot scan with avast, where I spot the problem was the program Mobogenie, so i tried to uninstall it with no success. So I googled the problem and I found a program called "adwcleaner"; i downloaded it, I opened the program and ran a scan, It found the "problem" and some others things.
...and after that I could erase the Mobogenie folder solving my problem, once and for all. I think that Mobogenie is adding a malware from third-party programs.
Hayabusa ::
Checker.exe ?
Oddelek: Operacijski sistemi
302041 (1526) Fukomuko
Trojan.Gpcoder.G (strani: 1 2 )
98203025 (196213) Cold1
Grafična kartica in Windows7 64bit-ni problem
182273 (1774) jizzer
izklapjanje računalnika - moder ekran ?
101705 (1520) bluefish
Diagnostično orodje za WD
Oddelek: Programska oprema
145037 (4897) clovk
