Forum » Programiranje » Android libGdx problem(Error)
Xpie ::
Imam problem, ko hočem svojo kodo zagnat mi eclipse vrže napako. Možno je da je v kodi1 ali pa v koda2 kej narobe. Problem zgleda takole:
Exception in thread "main" java.lang.NoClassDefFoundError: com/badlogic/gdx/jnigen/NativeCodeGenerator
at com.badlogic.gdx.utils.GdxBuild.main(GdxBuild.java:34)
Caused by: java.lang.ClassNotFoundException: com.badlogic.gdx.jnigen.NativeCodeGenerator
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 1 more
... 1 more
package com.me.mygdxgame;
import java.io.IOException;
import com.badlogic.gdx.ApplicationListener;
import com.badlogic.gdx.Gdx;
import com.badlogic.gdx.InputProcessor;
import com.badlogic.gdx.graphics.GL10;
import com.badlogic.gdx.graphics.Texture;
import com.badlogic.gdx.graphics.g2d.SpriteBatch;
import com.badlogic.gdx.math.Vector2;
public class MyGdxGame implements ApplicationListener {
SpriteBatch batch; //Uporablal bomo da bomo lahko prikazal na backgroundu
Texture mario; //Uporaba texture
Player player;
Vector2 postion;// spreminjanje textur torej resolucij
InputProcessor inputProcessor;
@Override
public void create() {
batch = new SpriteBatch();
mario = new Texture(Gdx.files.internal("mario.png")); //povemo kje se nahaja naša textura
postion = new Vector2(Gdx.graphics.getWidth() / 2,Gdx.graphics.getHeight() / 2); // za spreminjanje vrednosti x in y
if(Gdx.files.local("player.dat").exists()){ // to je to
try {
player = Player.readPlayer();
} catch (ClassNotFoundException e) {
e.printStackTrace();
} catch (IOException ex) {
ex.printStackTrace();
System.out.println("Player Exsists, Reading file");
else{
player = new Player( new Vector2( Gdx.graphics.getWidth() / 2,Gdx.graphics.getHeight() / 2),"mario.png");
try {
Player.SavePlayer(player);
System.out.println("Player Does not Exsists, Creating Player and Saving Player");
inputProcessor = new InputProcessor(){
@Override
public boolean keyDown(int keycode) {
// TODO Auto-generated method stub
return false;
@Override
public boolean keyUp(int keycode) {
return false;
@Override
public boolean keyTyped(char character) {
return false;
@Override
public boolean touchDown(int screenX, int screenY, int pointer,
int button) {
return false;
@Override
public boolean touchUp(int screenX, int screenY, int pointer,
int button) {
return false;
@Override
public boolean touchDragged(int screenX, int screenY, int pointer) {
return false;
@Override
public boolean mouseMoved(int screenX, int screenY) {
return false;
@Override
public boolean scrolled(int amount) {
return false;
@Override
public void dispose() {
@Override
public void render() { //metoda za prikazovanje na zaslonu
Gdx.gl.glClearColor(1, 1, 1, 1); // spreminjanje barve
Gdx.gl.glClear(GL10.GL_COLOR_BUFFER_BIT);
player.update();
if(Gdx.input.isTouched()){ //Preverimo če je smo se je dotaknili
System.out.println("Applicatoin clicked"); // izpišemo če smo se je dotaknili
// if(Gdx.input.getAccelerometerX()){
System.out.println("Mouse x:" + Gdx.input.getX() + " Mouse y:" + Gdx.input.getY());
batch.begin();
batch.draw(player.getTexture(), player.getPosition().x, player.getPosition().y);
batch.end();
@Override
public void resize(int width, int height) {
@Override
public void pause() {
@Override
public void resume() {
spletne-novice.si
- spremenil: Xpie ()
nightrage ::
Kaj ti pove ta napaka: java.lang.NoClassDefFoundError: com/badlogic/gdx/jnigen/NativeCodeGenerator
V knjižnicah, ki jih imaš includane v projekt, class NativeCodeGenerator ne obstaja.
| » | Android zamenjava pogledovOddelek: Programiranje | 1546 (1367) | c00L3r |
| » | android črtaOddelek: Programiranje | 2947 (2218) | g333kk |
| » | [android] vstavljanje slikeOddelek: Programiranje | 1641 (1538) | messi |
| » | [android] crashOddelek: Programiranje | 1792 (1601) | messi |
| ⊘ | Pomoč pri Domači nalogiOddelek: Programiranje | 5589 (4437) | Gandalfar |
