Grafična kartica
Grafična kartica
110 / 207
Kombustor ima isti problem
davvid ::
Inštaleru sem Windows 10 Pro. Pri Windows Update mi noče namestiti Nvidia - Display, zato mi ne najde grafične kartice (gtx 1060 3gb). Ne morem inštalirat driverjev, kot da je nebi bilo. Kaj lahko naredim?
instaliraj driver z nvidine strani
davvid ::
Sem ze probu ampak nedela.
freesty ::
Updataj windowse.
http://www.youtube.com/watch?v=5hfYJsQAhl0
Alien123 ::
kot je rekel freesty, problem so windowsi. Gor še imaš prastaro verzijo 10ke..
davvid ::
Deluje, hvala. Ampak sedaj, ko hočem v BIOS mi kaže samo črn zaslon? Pred tem updejtom mi je delal normalno. Imam MSI Tomahawk B450.
MostWanted ::
davvid je izjavil:
zdaj vemo kje je problem. AMD >:D:))
  • predlagalo izbris: bfranklin ()
davvid ::
Sem dal baterijo vem in ponovno not. Ko sem prižgal računalnik mi je kazal tisto da kliknes DEL da prides v bios in mi je delal. Ko pa sem resetiral mi tega kako prids v bios ni več kazal. Sem klikal del in je blo spet vse črno.
  • spremenilo: davvid ()
BorutK-73 ::
Probaj Win 7.
Da ni kak problem z hardwareom, mogoče grafična umira. Ponavadi ko inštaliraš driverje in če dobiš black screen po rebootu, je problem grafična.
davvid ::
Windows dela normalno mi pride na namizje in use. Samo v bios nemorm
Furbo ::
I can't get in BIOS by "DEL" or "F11" key, is there anyway I can enter BIOS from OS?
You can access BIOS by Windows 10 option: Click the lower left windows logo -> Settings -> Update & security -> Recovery -> Advanced startup and Restart now -> Troubleshoot -> Advanced options -> UEFI Firmware Settings -> Restart
Morda ima tudi to kaj veze
After updated the BIOS to support Raven Ridge CPU, my GTX 1070 stopped working.
For the Raven Ridge BIOS to have Nvidia graphics card work properly, VGA driver version 391.01 or later version needed to run with Raven Ridge BIOS.
i5-13600K, Noctua NH-D15, STRIX Z790-F, 32GB DDR5, 2TB Samsung 990PRO,
Toughpower GF3 1000W, RTX3070, ALIENWARE AW3423DWF, Dell S2722QC
  • spremenil: Furbo ()
Alien123 ::
a maš mogoče polek monitorja prikloplen TV na računalnik?.. ker ti bios odpre na tvju in ne na monitorju
GenZNPC ::
Z fast boot se dostikrat sploh ne da v bios.
davvid je izjavil:
Ta problem mi je nekam zelo znan, samo se vec ne spomnim v cem je bila finta.
Ko si nalozil windowse, je windows namestil najprej svoj driver in si tako ponovno zagnal racunalnik? To se zgodi po nekaj minutah odvisno od hitrosti interneta.
Vcasih pa pomaga prisilno zagnati windows update, ki potem prisilno nalaga neke gonilnike za graficno.
A mas to kako OEM ali travniski PRO?
skibidi
  • spremenil: GenZNPC ()
Marko84 ::
V praksi naj bi bila grafična kar 20% hitrejša od GTX 1060 za razmeroma enako in ponekod še nižjo ceno.
GTX 1660: https://www.amazon.de/gp/product/B07P76...
Je to best buy kartica s svojem rangu?
Marko84 je izjavil:
aglede na to da za 30 € vec dobis nenavito 1660 ti, bi se vprasal ce nebi zacel raje tu.
Marko84 ::
Sej cene na amazonu so res smešne, stare gtx 1060 dražje od novih 1660. Potem novi procesorji i5 9400 veliko cenejši od starih 8400. Ampak vsaj končno dobro za potrošnike.
Marko84 je izjavil:
Noramlno da je .. Intel ima prfektni model. Novo generacija nova plata. plačas pa premijum ceno. recimo imam i5-7600 nadgradim lahko na i7-7600 razlika je zgolj v HT. Cena pa premimjum za cca 20 % nizjo hitrost, kot ce zamenjam plato in proc.
jobers2 ::
GenZNPC je izjavil:
davvid je izjavil:
jst sem isti problem z svojo 2080 ko in sem moral updejtat win. mam pa 10 ko pro varianto
Za 298€ 8GB PowerColor Radeon RX Vega 56 Red Dragon Aktiv PCIe 3.0 x16 (Retail), pa ni blower :))
GenZNPC ::
Bolj koristen bi bil, ce nam das direkt povezavo do tega turda, preden zmanjkajo
skibidi
hotlips ::
matobeli ::
En ne-gejmerski vprašanje:
Katera nvidia je najcenejša in podpira 10bit hevc (HTPC vprašanje)?
Ker skrivajo te informacije kot da so zlate.
Bi 710 že šla? 1030 bi pa res mogla?
gddr85 ::
GenZNPC je izjavil:
mindfactory...https://www.mindfactory.de/product_info...
v cenovnem rangu 1660ti:))
Anney ::
matobeli je izjavil:
Mislim da 1030 nima podpore na netflixu, prva je 1050.
GenZNPC ::
Dobra cena za turda, jaz bi doplacal 50eur in vzel 2060...
skibidi
spet sponzoriran clanek, da je vega 56 pred 2060....https://www.tweaktown.com/articles/8952...
ok razen pri 1080p...:'(
GenZNPC ::
Kaj ko nebi kazal samo eno in iste tri igre vedno :)
in pozabil si dodati, da jo v DX11 rtx 2060 vseeno prehiti xD
skibidi
GenZNPC je izjavil:
Veliko sreče na 2060 za 350€
https://www.picclickimg.com/00/s/NzIwWD...
Poleg prej dodatnih štiri, še sledeče... no predlagam cenejšo kartico, če ti je želja 1080p, ker nobene ni primerna za 144Hz monitor...
https://www.techspot.com/review/1799-ge...
https://www.reddit.com/r/Amd/comments/a...
Vega stock ?
https://www.gpucheck.com/compare/amd-ra...
GenZNPC ::
Lahko se trudis kolko se hoces, RTX 2060 je optimalni GPU za nad 300Eur, 1660Pa pod 300Eur, vmes pa ne rabis nic xD Na V56 pozabis, razen ce si die hard
skibidi
Cveto ::
No, RTX2060 NI 300€ kartica (cene so vseeno dosti bližje 400€ kot 300).
Za 300€ se dobi 1660, ki je hitrostno enaka Vegi 56.
Če nimaš posebnih razlogov, vseeno vzameš Nvidio (pač zaradi porabe), če pa si želiš prav AMD (recimo da ti Freesysnc ne dela dobro na tvojem monitorju), lahko brez slabe vesti vzameš Vego 56.
Zanimivo za kartico, ki ste si ji nekateri že ob startu posmehovali.
GenZNPC je izjavil:
Se strinjam ko bo 2060 dejansko pod 349€ in ko vego56 dejsnko lahko kupiš za 270€ (+ igre) in ko boš lahko teh 33 iger na pod 229€ vredni 1660 igral nad 60 FPS pri 1080p se ti izide vse.
Verjetno bo pa potrebno počakati, na konec junija, če bo Amd bil sposobne pluniti kaj več kot trenutno Vego II. In če imaš interne informacije, in veš da Amd-ni sposoben dati grafične ven, ki bo konkurenca 1660 ali 2060, je danes izjemo dober nakup nekaj 1660 in 2060, ker bodo julija samo še dražje...
GenZNPC je izjavil:
Sedaj pa mi razloži..
Test tistih 33 iger kjer je 2060 grand theft auto V hitrejša od vege 56 za 33%
https://www.techspot.com/review/1781-ge...
Drugi test.... https://i0.wp.com/babeltechreviews.com/...
Kjer je 2060 no ima 80 FPS Vega pa 76 FPS v teh 33% : https://babeltechreviews.com/the-evga-g...
Torej stvar samo potrjuje, to kar sem rekel že na začetku da techspot vzame test ob izidu "verjetno" potem pa kao ker je ista platforma za testiranje vtakne gor novo grafično in driverje, potem pa prilima...
Verodostojno.... da ne bo pomote cena 80€ razlik brez iger, to je tam 22-23% ceneje od NV...
GenZNPC ::
Ceneje, ker dobis tocno tolko manj vreden GPU.
skibidi
GenZNPC je izjavil:
glefe na techspot joke 33% bos moral malo bolj poiskati razumsko razlago. Verjetno so zraven dodali se porabo, da so prisli do te vrednosti, kot tudi uno ceno fps-ja, kjer je za nv kartico vzeta maloprodajns cena, za vego pa takratna cena na trgu. ...Ja ja , poizkusi ponovno..
GenZNPC ::
Cveto je izjavil:
Res je, tako kot je tudi glupo rect, zaradi ene Vege in to najslabse, ki je 300 evrov, da so vse 300 evrov, zanimivo verjetno samo za tiste, ki klump kupujejo. Nekak je treba ukrotiti tistih 300W, ki grejo v luft. Tisja pa tudi ne bo od samega sebe. Med tem pa, ko imas za ceno dobre Vege56 malo morje 2060 na izbiro, ki so tudi v cenejsem hlajenju po glasnosti enakovredne, poceni V56, kar je tudi logicno, ce je treba odvajati 30% manj toplote.
Trenutno stanje overall:
1660 up to 250Eur:
oz. jih imas ogromno ze od 200 naprej.
1660Ti up to 300 jih imas na izbiro tudi nekaj:
 Od 250 naprej, pa niti blower niso, kot tist Mr. Bjev turbo jet engine sample
Vega 56, samo ena dvo slotna glasnoba je na voljo za 300eur, vse ostalo so JET Engine izvedbe:
 Za ukrotit tale TDP, se moras skesirati vsaj 350 Eur ali pa si gluh
RTX 2060 od slabih 350Eur naprej:
 Malo morje jih je okoli 350-360
Zdaj pa se v razmislek:
RTX 2060 AIBTwoFan - 36 dB(A) (Strix 34 dB(A) 350Eur
Asus Strix Vega 56 Perf - 37 dB(A) 350Eur
Powercolor Vega 56 - 39-40 dB(A) 300Eur
Radeon Vega Turbo Blower - 47- 50 dB(A) 266Eur
1660 ali 1660Ti pa, ce niso glih ITX izvedbe z enim fanom, so vse tisje od RTX 2060.
Zdaj pa se naj vsak sam odloci, kompromisi pri V56 so jasni. Tinitus, slabse povprecje, ter dodatnih 100W nezne toplote v ohisju, poleti:
Zdaj pa nazaj pod kamen.
Mr.B je izjavil:
GenZNPC je izjavil:
Jaz gledam cene izkljucno na dnevni ravni na geizhals.de in edino kar vidim pod 345Evrov kar se Vege56 tice, je klump. S tisto powercolor vred. Ce nekomu tistih 50 evrov ni vredno dati za vsaj spodobno hlajenje za 300W karto ali pa RTX 2060, ki oddaja od sebe manj toplote, ima RTX podporo in je v veliki vecini iger hitrejsa, naj mu bo, v take fetise se ne vtikam.
skibidi
Jaz ne bi kupil ne Vege ne RTX-a.. AMD tako ali tako kategorično odpade, od RTX-a pa še nekaj časa ne pričakujem nič omembe vrednega. Zaenkrat neko igračkanje in kronično pomanjkanje iger.. Ko bodo pa le-te na voljo, bo pa minila 1 ali 2 GPU generaciji in bodo tile prvi RTXi neuporabni. Tko da investiranje v RTX for the sake of it je IMO metanje denarja proč.
Summa sumarum: danes edini vreden nakup je 1660(Ti).
Upam, da navi izzide še pred novembrom in da sproži neko mini revolucijo.
mahone ::
Mr.B je izjavil:
GenZNPC je izjavil:
Kaj ko bi malo pogledal katere settingse uporablja HUB?
Babeltech pri GTA V uporablja FXAA medtem ko HUB MSAA.
Ojej, takoj ko sem stran, kjer je nv dbest oh i sploh postavil na njeno pravo mesto, so naenkrat vsi poskocili v luft...Sploh je smesno da je sedaj argument opravicila razlike cene poraba, kot da intel kljub to moti...
te stov z 1660 je polno zraven tudi vega testov, stran, ki limq rezultate iz zgodovine je smeh..
scipascapa ::
MSI RX 590 za 220€ ok cena?
GenZNPC je izjavil:
Cveto je izjavil:
1660 up to 250Eur:
Mr.B je izjavil:
GenZNPC je izjavil:
lol vega 64 je 388€ verjetno se ceneje https://www.mindfactory.de/product_info...
sedaj si pa nalimaj gta V kot igro ki jo nabijas zato da opravicis nakup 1660.
GenZNPC ::
Med Vego, ki ne zari od vrocine in ne tuli od muk in 1660 je 150evrov razlike. Ni treba nic upravicevati tukaj. Se napajalnik bo avtomaticno hvalezen in globalno segrevanje manjse.
Zdej ko si dobil stevilke, ne samo ene in razloge zakaj ne kupiti krs od Vege, si naspicen? Tipicno amdjevsko.
skibidi
GenZNPC je izjavil:
Ok sej vem da si užaljen, ker če Blower ni uporaben kot argument, pač greš na porabo...
Kupovanje grafične tipa 1660 je nesmiselno, če imaš doma grafično, s katero lahko igraš na 1080p na medium detailih in dosegaš enake FPs-je kot z 1660 na Ultra, mrazen če si se spreobernil v Zelenega, zgolj pri porabi energije, ker če kupuješ intel CPU na LGA1151v2 podožju te to itak ne sme motiti, al misliš da so extra pini na v2 zgolj estecke narave.
GenZNPC ::
Edina uzaljena oseba si tu ti, dejstva so bla navedena, ce ti ne razumes, da je hlajenje odvisno od oddane toplote, sem napisal da rade volje kupi krs. Pri avtih je tudi tako, nekateri so povsem zadovoljni s standardom dacie.
Bos se kak bolj irelevanten primer privlekel v debato? Torej nekomu, ki igra na medium ne privoscis nove graficne lol, razen ce kupi Vego seveda. Dvolicnez.
skibidi
Alien123 ::
DarwiN je izjavil:
Vsi ste zalepljeni na tale rtx. Kaj pa prej ko tega ni blo?
Folk ne kupuje izključno novih grafičnih zaradi rtx-a. Performens je konkreten v primerjavi z 1080ti. In vsi ne igrajo na fullhd, tako da 1660ti odpade pri 1440,4k..
scipascapa je izjavil:
Imaš možnost znižati ceno na ene 200?
GenZNPC je izjavil:
No kot sem rekel, edini argument proti, ki ti je ostal je poraba.
Še 1x. če imaš doma grafično, ki ti pri Srednjih nastavitvah in resoluciji 1080p plune enako FPS-jev kot 1660 na Max, je nakup 1660 izjemno pod vprašanjem, razen če imaš HPC, kjer ti je vsak W porabe pomemben. 1660 ne izplune 60FPs-jev v večini iger pri 1080p in max nastavitvh. Če je potem zate to smiselen prehod veliko sreče... Dejstvo je da dobiš 1660Ti ki ti izplune pri 1080p nad 60FPS. Za kaj več boš pa rabil iti ali na 2060, kjer si na meji z porabo spomina pri 1440p. Za kaj več imaš pa Vego 64 za 388€ razen seveda če je bistvo igranja GTA V, ker tam je še vedno 2060 hitrejša.. Lahko pa namesto Vege 64 investiraš v 2070, da se ne bomo vrnili v zanko o ......hlajenje odvisno od oddane toplote......
Alien123 je izjavil:
DarwiN je izjavil:
Doplačilo za povsem neuporaben RTX me moti, pa čeprav sicer pozdravljam napredek tehnologije. 2060 je zanemarljivih ~15% hitrejša od 1660Ti, cena pa ~30% višja že zdaj, ko se cene teh non-rtx kartic še niso ustalile in še padajo.. Ja, vem, da cena tudi sicer ne narašča povsem linearno s performancom, pa vendar.
Skratka, tole prvo rtg generacijo bi jaz preskočil. Če pa si hardcore gamer na visoki resoluciji, potem pa jasno kupiš in si ne beliš glave.
GenZNPC ::
To nam je jasno, da se prodaja RTX zraven nonRTX performanca in je treba doplacat. Mene osebno 2080Ti tudi ni prepricala s svojim nonRTX performancom napram 1080Ti na 4K. Zdaj pa cakam na 3080 oz. bolj 3080Ti od zelenih, ker na rdece bi pa moral cakati 10 let, da bi bilo smiselno nadgraditi 1080Ti.
skibidi
110 / 207
