Blackscreen while playing games every 10-20 min
siimee ::
Hi, i have a problem that is driving me crazy.
For a few months now i cant play games for more than 10-15 min.
Example, im playing cod 2 multiplayer, battlefield 4, assassins creed and suddenly my monitor goes blackscreen, sound goes sometimes zzzzzz, the keyboard si frozen, i can still hear my friends on skype, teamspeak....
Now i have to turn off my power supply and wait a few seconds then i turn it back on and start the pc, if i just reset my computer it wont start the screen will still be black. I have test everything and nothing seems to be wrong but i dont believe that, something must be wrong. The temperatures are all normal. I ve done clean format a few times. Im running on win 7 x64
My specs:
Intel i7 920 - 2.66 GHZ, 1366
ASRock X58 EXTREME6 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Seagate ST31000528AS 1TB hard drive
G.SKILL 2GB DDR3 - 1600, 6 GBPI x 3 RAM
Nvidia GeForce 295 gtx graphic card
Thermaltake Qfan 750 W toughpower power suply
thx
  • zaklenil: bluefish ()
r3dkv1c4 ::
zakaj v angleščini, če je to slovenski forum?
siimee ::
Napisal se post na eni angleški strani in sm dal sam copy paste, upam da ni to problem.
Metulj-1 ::
Il problema ? probabilmente il vostro alimentatore. Sostituire PSU prima.
  • spremenilo: Metulj-1 ()
einstein :P ::
Do you have overclocked CPU or GPU? :P
STAY OUT OF MY TERRITORY!
taz ::
Metulj-1 je izjavil:
Dej nehaj uporabljat google translate. Če ga pa ne, ti gre italijanščina slabo.
bluefish ::
Smo na slovenskem forumu.
siimee ::
 temps
temps
K igram se temperatura grafične dvigne na okrog 60, prav tako procesor oz malenkost manj.
SpaceX reusable rockets (nova tema)
296441 (5621) BigWhale
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820334 (17174) arrigo
Kvantna Teorija ne drži?
52931 (1474) gzibret
CATALYST 3.6
Oddelek: Programska oprema
169016 (8501) freejack
