Forum » Programiranje » zazeni exe
zazeni exe
losnah ::
A lahko kdo napise, kako v c++ zazenes en program.
npr. tko kot v VB shell funkcija, shell(pathname[,windowstyle])
napsy ::
en način je, da uporabiš funkcijo system(), ki uzvrši naveden ukaz.
Druga možnost je, da ustvariš nov proces. V linuxu uporabiš funkcijo fork() in execl(jih je še veliko). Za windowse pa ne vem.
"If you die, you die. But when you live you live. There is no time to waste."
StratOS ::
Poglej Tole
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Urko ::
Funkcija CreateProcess je sicer, zelo "mocna", vendar ce ne potrebujes nadzor nad programom ki ga bos zagnal je bolje ce uporabis funkcijo WinExec ali ShellExecute, za podrobnosti si poglej MSDN.
d-mon ::
The CreateProcess function is used to run a new program. The WinExec and LoadModule functions are still available, but they are implemented as calls to CreateProcess. (MSDN)
[D-mon]
| » | win, odpiranje novega browserjaOddelek: Programiranje | 1572 (1449) | 64202 |
| » | [C++]Zagon drugega programa in izvajanje ukazaOddelek: Programiranje | 1814 (1659) | 64202 |
| » | Funkcija za zapret programOddelek: Programiranje | 1633 (1389) | StratOS |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3826 (3619) | webblod |
| » | Delphi 5Oddelek: Programiranje | 1461 (1328) | LojzePek |
