Forum » Pomoč in nasveti » spremenjanje tipk na tipkovnici
dragoneye89 ::
kdo ve če se da spremenit pomen tipk na tipkovnici?recimo da nastaviš namesto 3 neko črko? in ko pritisneš 3 se pojavi x npr.?
Kupi novo tipkovnico ...
Ali pa staro odpri in spucaj. Mogoče bo pomagalo.
Apple ::
Obstaja nek program, samo se ne spomnim imena... Jst bi ga tud rabil :)
S programom si lahko delal rošado tipk...
Men na Appleovi tipkovnici manjkata tipki PrtScreen ter Insert :)
LP, Apple
Cold1 ::
Microsoft Keyboard Layout Creator - MSKLC
Spletna stran:
http://msdn.microsoft.com/en-us/gogloba...
MSKLC 1.4:
http://go.microsoft.com/fwlink/?LinkId=...
Ever wanted to quickly and easily define your own keyboard layout for a language Microsoft doesn't support? Or define your own keyboard layout so you can quickly and easily enter your favorite symbols with a simple keystroke? Have the keyboard work on 64-bit platforms, or make use of custom locales in Windows 7 to provide new language names? Well, want no more: the Microsoft Keyboard Layout Creator is here!
The Microsoft Keyboard Layout Creator (MSKLC) extends the international functionality of Windows 2000, Windows XP, Windows Server 2003, Windows Vista, and Windows 7 systems by allowing users to:
- Create new keyboard layouts from scratch
- Base a new layout on an existing one
- Modify an existing keyboard layout and build a new layout from it
Spletna stran:
MSKLC 1.4:
Engineer_ ::
tipkovnice za prenosnike niso tako blazno drage da se jih ne bi dalo menjat.
v skrajnem primeru naročiš eno na ebayu.
- spremenilo: Engineer_ ()
dragoneye89 ::
| » | Kaj se je zgodilo s slovensko tipkovnico?Oddelek: Znanost in tehnologija | 7502 (5836) | janig |
| » | Ergonomske miške in tipkovniceOddelek: Kaj kupiti | 5094 (4717) | tony1 |
| » | Zamenjava tipk na tipkovniciOddelek: Pomoč in nasveti | 16052 (15916) | IvoJan |
| » | kako narediti prtscr na nemški tipkovniciOddelek: Pomoč in nasveti | 5937 (5655) | Domina |
| » | tikpovnica (razpored tipk) po lastni izbiriOddelek: Pomoč in nasveti | 1490 (1389) | 5er--> |
