Kako naredit BOOT meni
YiMMi ::
Imel sem gor Win2k...in Me...ko sem prizgal masino se mi je vedno naredil meni in sem izbral kateri
OS naj zazene...zdaj sem Me formatiral in nevem kak bi naredil ta boot
ki sem ga mel prej Win2k so se vedno gori..CD-ja pa vec nimam da bi jih se enkrat gor instaliral..
Se da to kak naret....:'(:'(:'(;);)
rookie ::
A si me Me na isti particiji kot win2k ?
Boste vidl kaj vm bomo naredil v Braziliji.Ferrari in Schumacher zakon !!!!! 1
YiMMi ::
Ne..ne Vsakega na svoji particiji.....8-O
kar so drugace tako ali tako tezave ce sta oba na isti..!!!
andrej ::
daj w2k CD not, rebootni, pa izberi repair, pa ti bo zadevo popravil...
drugace pa si najdi program kot je bootpart, ki ti zma sam to porithat. mislim, da ga dobis nekje na www.winimage.com.
Andrej
rookie ::
Pa sej glih pred 2 dnem je biu gor thread a bootanju win2k no pa sej je se zmer gor !!!!!!!!!
Ampak usen na kle mas !!!
To install the Recovery Console as a startup option
With Windows running, insert the Windows 2000 Professional CD into your CD-ROM drive.
Click No when prompted to upgrade to Windows 2000.
At the command prompt, switch to your CD-ROM drive, and then type the following:
\i386\winnt32.exe /cmdcons
Follow the instructions on the screen.
Notes
To run the Recovery Console, you must restart your computer and select the Recovery Console option from the list of available operating systems.
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
To see the commands available on the Recovery Console, type help at the command prompt.
You can allow a user to run the Recovery Console without logging on by enabling the Automatic administrative logon when using recovery console attribute in the Group Policy snap-in. This attribute is located in the console tree under Local Computer Policy/Computer Configuration/Windows Settings/Security Settings/Local Policies/Security Options.
If your computer will not start, you can run the Recovery Console from the Windows 2000 Professional CD (if you have a bootable CD-ROM drive) or the Setup disks. See Related Topics for information on running the Recovery Console when your computer will not start.
Če pa ne pa probi s setup diski ki jih prav tako narediš iz win 2000 cd-ja:
To create setup disks
Insert a blank, formatted, 3.5-inch, 1.44-MB disk into the floppy disk drive.
Insert the Windows 2000 CD-ROM into the CD-ROM drive.
Click Start, and then click Run.
In the Open box, type d:\bootdisk\makeboot a: (where d: is the drive letter assigned to your CD-ROM drive), and then click OK.
Follow the screen prompts.
Important
You will need four blank, formatted, 3.5-inch, 1.44-MB floppy disks. Label them Setup Disk One, Setup Disk Two, Setup Disk Three, and Setup Disk Four.
Note
You can create the setup disks from a computer running any version of Windows or MS-DOS.
Win. could not start...... wtf. \windows\system32\config\system
Oddelek: Operacijski sistemi
82809 (2722) Tovaris Stalin
Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikon
52690 (2646) riba43
Windows XP - težave z zagonom
63163 (3005) SebaR
WinXP: boot s CDja
91972 (1843) freejack
WIN 2000 BOOT ?
Oddelek: Programska oprema
131844 (1709) rookie
