Ubuntu - problemi z ekranom
prenasalec ::
Takole je: leto nazaj sem imel ekran velikosti 1024x768. Ker je to seveda precej malo, sem vzel nekaj večjega 1280x1024. Problem je, da mi Ubuntu pri prižigu računalnika vsake zmanjša resolucijo na 1024x768 in izvrže tole errorsko sporočilce:
Could not apply the stored configuration for monitors
none of the selected modes were compatible with the possible modes:
Trying modes for CRTC 63
CRTC 63: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 1)
Trying modes for CRTC 64
CRTC 64: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 1)
Enako se zgodi, če se ekran čez nekaj časa (neaktivnost in to) sam zaklene. Tudi takrat se resolucija zmanjša, samo sporočila ne javi. Nenavadno: resolucija se ne zmanjša, če računalnik zaklenem ročno.
Ta problem začasno rešim tako, da odprem program Displays, ki očitno avtomatsko zazna, da nisem na največji možni ločljivosti in jo zamenja. Vendar to traja samo, dokler se računalnik zaklene ali znova prižge.
Ali je že kdo imel težave s tem? Jih zna kdo rešiti?
P.S.: Uporabljam Ubuntu 12.10 prek Wina. Naložen imam še Cinnamon, vendar so se problemi pojavljali že preden sem ga naložil. Na Windows 8 je z ekranom čisto vse v redu,
Ang3lo ::
Odstrani datoteko .config/monitors.xml (za vsak slučaj jo še prej nekam varno skopiraj).
Poizvedba: https://www.google.com/search?q=Could+n... .
1. rezultat: http://ubuntuforums.org/showthread.php?... .
prenasalec ::
Okej, sem zbrisal. Upam, da bo delalo.
Ubuntu in Mint = žalost na kvadrat?
Oddelek: Operacijski sistemi
377403 (5797) mihec87
TV mi nagaja :(
Oddelek: Zvok in slika
91563 (1186) delfin
1 nakup lcd monitorja
142162 (2000) raab himself
Ati radeon, Xorg in Xv
101869 (1741) MasterMind
Radeon 9000pro & SuSE 9.0, a komu dela?
121597 (1510) ajagodnik
