Forum » Operacijski sistemi » Ubuntu - problemi z ekranom
prenasalec ::
Takole je: leto nazaj sem imel ekran velikosti 1024x768. Ker je to seveda precej malo, sem vzel nekaj večjega 1280x1024. Problem je, da mi Ubuntu pri prižigu računalnika vsake zmanjša resolucijo na 1024x768 in izvrže tole errorsko sporočilce:
Enako se zgodi, če se ekran čez nekaj časa (neaktivnost in to) sam zaklene. Tudi takrat se resolucija zmanjša, samo sporočila ne javi. Nenavadno: resolucija se ne zmanjša, če računalnik zaklenem ročno.
Ta problem začasno rešim tako, da odprem program Displays, ki očitno avtomatsko zazna, da nisem na največji možni ločljivosti in jo zamenja. Vendar to traja samo, dokler se računalnik zaklene ali znova prižge.
Ali je že kdo imel težave s tem? Jih zna kdo rešiti?
P.S.: Uporabljam Ubuntu 12.10 prek Wina. Naložen imam še Cinnamon, vendar so se problemi pojavljali že preden sem ga naložil. Na Windows 8 je z ekranom čisto vse v redu,
Could not apply the stored configuration for monitors
none of the selected modes were compatible with the possible modes:
Trying modes for CRTC 63
CRTC 63: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 63: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 63: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 1)
Trying modes for CRTC 64
CRTC 64: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 0)
CRTC 64: trying mode 1024x768@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 800x600@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 800x600@56Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 848x480@60Hz with output at 1280x1024@60Hz (pass 1)
CRTC 64: trying mode 640x480@60Hz with output at 1280x1024@60Hz (pass 1)
Ang3lo ::
Odstrani datoteko .config/monitors.xml (za vsak slučaj jo še prej nekam varno skopiraj).
Poizvedba: https://www.google.com/search?q=Could+n... .
1. rezultat: http://ubuntuforums.org/showthread.php?... .
| » | Ubuntu in Mint = žalost na kvadrat?Oddelek: Operacijski sistemi | 7322 (5716) | mihec87 |
| » | TV mi nagaja :(Oddelek: Zvok in slika | 1549 (1172) | delfin |
| » | 1 nakup lcd monitorjaOddelek: Kaj kupiti | 2154 (1992) | raab himself |
| » | Ati radeon, Xorg in XvOddelek: Operacijski sistemi | 1855 (1727) | MasterMind |
| » | Radeon 9000pro & SuSE 9.0, a komu dela?Oddelek: Operacijski sistemi | 1588 (1501) | ajagodnik |
