Snemanje in gledanje v živo
mladič ::
Zdravo.
Zanima me če se da kamero in prenosnik povezati tako da ko snemam se mi sika direktno prikazuje na ekranu prenosnika? Kako?
hvala za odgovore! LP
T-h-o-r ::
- you should have all the required software on the discs that came with the camera and all the leads as well .
- I would have thought having 'Live View' and USB 2 output it should be possible, but I don't have a NIKON, I have a Canon, I plug in my USB 2 cable in the camera and Laptop the software comes up with options and I press live view and away it goes.
Sorry not much help
- Hi, I have the Nikon D5000 and I use some software from Breeze systems called 'NKRemote' all works fine, allows Live View on laptop and you can control all the camera settings from it...
You can also take photo's and save the files directly onto the hard drive..
The only thing I have found I can't do is use the 'bulb' mode
give it a go and see if it works for you
Cheers
Paul
- If all you want to do is view the output of your camera without controlling it, you just need to connect it to a device that accepts an HDMI input. The easiest and most economical solution would be a display only device such as a portable HDMI monitor. Most laptops do not accept HDMI inputs due to copyright constraints on the licensing of the HDMI technology.
Nategavščina ???
265101 (3388) amigo_no1
iPad 2 64GB WiFi + 3G
153368 (2745) Goran's Blog
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820197 (17037) arrigo
A so te hi-fi komponente OK?
242909 (2544) Dami
