Problem ob zagonu WinXP
TheJack ::
Imam hud problem z WindowsXP (sp1).
Včeraj sem se malo igral z Diskeeperjem. Šel sem na ''Boot-time defragmentation'' in označil dve stvari in sicer ''Run CHKDSK before defragmentation'' in ''Defragment the MFT'' (to sem počel že prej, pa ni bilo problemov). Pritisnil sem ''Set'' in restartal kompjuter. Tako chkdsk kot diskeeperjev program sta se izvedla, potem se je sistem še enkrat restartal.
In nato nenadoma, le nekaj sekund po zagonu Windowsev, se je spet sam restartal. Znašel sem se pred tistim ekranom, kjer dobiš na voljo ''safe-boot'', pa ''last configuration that worked'', in tako dalje. Poskusil sem vse napisane variante. Pomagalo ni nič. Takoj po zagonu Windowsev (še ''loading'' zaslon se ni prikazal), je sledil restart sistema.
Poskusil sem z WindowsXP cedejem (boot z njega). Šel sem na ''repair'' (Recovery console) in poskusil najprej s ''fixmbr'' ukazom. Ni pomagalo. Pomagal je šele ''chkdsk'' ukaz v tej konzoli.
Windowsi so se normalno zagnali. Prvo kar sem opazil (v Diskeeperju), da se je ''reserved system space'' premaknil iz začetka na konec diska. Ampak to ni bilo bistveno. V Event Viewer (Application) ob vsakem zagonu dobivam vrsto dveh opozoril:
Event:
Type: Warning
User: NT AUTHORITY\SYSTEM
Computer: POLARIS (ime mojega sistema)
Source: Userenv
Category: None
Event ID: 1517
Description:
Windows saved user POLARIS\Miha registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
Temu opozorilu sledijo trije errorji (kot rečeno, ob vsakem zagonu):
Event:
Type: Error
Computer: POLARIS
Source: Userenv
Category: None
Event ID: 1500
Description:
Windows cannot log you on because your profile cannot be loaded. Check that you are connected to the network, or that your network is functioning correctly. If this problem persists, contact your network administrator.
DETAIL - Access is denied.
Poleg tega dobivam v Event Viewer/System še dodatne errorje:
Event:
Type: Error
User: N/A
Computer: POLARIS
Source: Service Control Manager
Category: None
Event ID: 7005
Description:
The LoadUserProfile call failed with the following error:
Access is denied.
Pa še (spremenita se le description in Event ID, ki je 7000):
The Distributed Transaction Coordinator service failed to start due to the following error:
Access is denied.
Pa še:
The TCP/IP NetBIOS Helper service failed to start due to the following error:
Access is denied.
In:
Access is denied.
In potem še tole:
Event:
Type: Error
Computer: POLARIS
Source: DCOM
Category: None
Event ID: 10000
Description:
Unable to start a DCOM Server: {73E709EA-5D93-4B2E-BBB0-99B7938DA9E4}. The error:
"Access is denied. "
Happened while starting this command:
C:\WINDOWS\System32\wbem\wmiprvse.exe -Embedding
V Task Managerju mi pod Users piše le User: Miha (torej jaz), ID: 0, pod Client Name ne piše nič, pod Session pa piše Console.
Poskusil sem narediti drugega Userja v ''User Accounts'' (drugače je le en, torej jaz, kot Administrator), pa nič ne pomaga. Tudi če se prijavim kot drug uporabnik, še vedno izpiše ista opozorila.
V Control Panel/System/Advanced/User Profiles/Settings, sta navedena dva profila. In sicer ''Account Unknown'', ki je velik le 602 KB in POLARIS\Miha, ki je velik 48 MB. Oba imata pod Type in Status vpisano ''Local''.
Skratka, blage veze nimam, kaj je narobe. Nekako se mi megleno dozdeva, da problem ni v accountih, ampak v samem sistemu, saj se izgleda accounti nimajo kam prijavljati. Ali nekaj podobnega. Ne vem. Tole je namreč vse skupaj že precej nad mojim poznavanjem Windowsev. Ne vem sploh, kje je točno je problem (s čim točno so težave), da bi znal rešitev poiskati z Googlom.
Lepo prosim za pomoč.
TheJack ::
Šele sedajle sem ugotovil... Ne morem več dostopati do fajlov. ki sem jih premaknil!!
Recimo imam nek txt fajl, lahko ga normalno odpiram. Potem ga pa premaknem (ali prekopiram) nekam drugam in tam ga ne morem več odpreti:''Cannot open...'' Make sure a disk is in the drive you specified.''
Enako pri direktoriju, ki ga premaknem (prekopiram): ''...is not accesible. Access is denied.''
Tudi Recycle Bin mi je nehal delovati. Ko nekaj premaknem tja, izgine za vedno.
Kaj za božjo voljo naj naredim?!
  • spremenil: TheJack ()
Yeznick ::
Si probal System restore? Upaj, da imaš še kako Restore poin preden si zagnal Dikeeperja.
Jaz sem mimogrede tudi pognal Diskeeperja na XP SP1, tako kot ti, samo da nise imel problemov.
Sporoči, kako napreduješ. Upam da bomo to nevšečnost rešili :))
Yeznick.
TheJack ::
System Restore sem imel ugasnjen.... Na žalost, čeprav je po mojem malo verjetno, da bi pomagal.
Sicer je pa problem rešen. Uporabil sem univerzalno preizkušeno metodo reševanja problemov v Windows sistemih.
Witboy ::
format c?!?:D
TheJack ::
Pravzaprav fdisk->delete partition...
Yeznick ::
Dejte no folk. Vedno imejte prižgan System restore. Nikoli ne veš, kdaj te bo
lastni računalnik začel zezat. Sej se mate za folk, ki ima gigahertzne mašine in
state of the art diske, grafične....pa da ne naštevma preveč. Sej se vam sploh ne bo poznalo,
če bo to delalo v ozadju. Še meni se ne pozna ki imam durona 1000, ki ni nevem kaj.
Toplo še enkrat priporočam. Meni je system restore že velikokrat rešil dan.
Tudi vam ga bo nekoč in takrat boste videli kako pomemben del windowsov je.
By the way, TheJack praviš, da System restore ne bi mogel pomaagti v tvojem primeru.
Ooooo. pa še kako bi ti pomagal. Verjemi mi. Vklopi, pa boš lažje živel.
Pomoje ti ne preostane drugega kot format c:. No mogoče se pa motim in prepuščam mnenja
ostalim gurujem računalništva.
Yeznick
TheJack ::
System Restore sem uporabil že dostikrat prej, pomagal ni niti enkrat. Podrobnosti se točno ne spomnim, ampak moje izkušnje so take. Tudi je težko vedeti, če bi SR pomagal pri razsuti MFT.
Kot sem že povedal, sem Windowse na novo naložil.
Težava Microsoft-Windows-Kernel-Power (strani: 1 2 )
8610202 (7212) Anney
HP Pavilion dv7 reboot problem
92648 (2581) Yacked2
log in
81464 (1384) wade
Secure strani (https) mi ne delajo
51164 (1151) poga
Win2k keyboard
Oddelek: Programska oprema
201917 (1745) JLP
