Slo-Tech 3D Team: Unigine Tropics 1.3
Janac ::
Malo starejši Benchmark iz leta 2010, Unigine Tropics 1.3
System requirements:
Graphics card: ATI Radeon HD 2xxx and higher or NVIDIA GeForce 7xxx and higher.
Nastavitve:
API: Directx11
3D: Disabled
Ambient occlusion: yes
Reflection: yes
shaders: high
anisotropy: 16
AA: 8x
Resolution: 1680x1050
Da zajamete ScreenShot na koncu bencha pritisnite F12, shrani se vam v: (local disk)Users -> Unigine Tropics -> screenshots.
Download: http://www.techspot.com/downloads/5802-...
Priloži ScreenShot ter zraven napiši:
[Username] - [CPU @ Speed in GHz] - [Type of GPU(s) @ Core Speed / Memory Speed] - [Average FPS] - [Score] - (drivers)
[Screenshot of Bench with Settings]
Primer:
Lestvica:
1. [Janac] - [Celeron G465 @ 1.9GHz] - [7870 XT @ 1166Mhz / @ 1500Mhz] - [56.2 FPS] - [1415] - (13.6)
matic492 ::
[Maticbla] - [FX-8320 @ 3.8GHz] - [7870 XT @ 1220Mhz / @ 1690Mhz] - [65.8 FPS] - [1658] - (13.6)
Sem dobil prej boljši rezultat, morem pognati še enkrat
GenZNPC ::
[m0LN4r] - [A10-6800K @ 4.77GHz] - [8670D @ 1169Mhz / @ 2208Mhz] - [10.4 FPS] - [262] - (13.4)
skibidi
theGamer ::
[theGamer] - [3770K @ 4.7GHz] - [2xgtx780 @ stock / @ stock] - [286,8 FPS] - [7224] - (326,58)
i7 3930K@4.8GHz|Hydro H110|Gigabyte GA-X79-UD7
180GB SSD|2x512GB SSD|32GB 2400MHz|2x GTX780
Silver Stone Strider 1500W|Cooler Master HAF X
tok hude grafe pa 1050p ekran :))
freesty ::
Lahko nastavis resolucijo 800x600 tudi na 1440p ekranu.
http://www.youtube.com/watch?v=5hfYJsQAhl0
matic492 ::
iloveboobz je izjavil:
imam 3 zaslone desni ima resolucijo 1366x768 in ubsitvu mi je ta program laufal v večji resolucij na tem zaslonu (ker je glavni-orodna vrstica), ker je program dokaj star in ne morem izbrati kateri zaslon, tako kot naprimer v novem unigine heavenu, druga dva sta pa še 17' in 22' 1680x1050 in 1280x1024, večje resolucije mi pa osebno sploh niso všeč, če bio danes kupoval bi kupil fullhd ja, več pa sigurno ne, kakšen 4k na 30' zaslonu, to bi jaz norel zraven imam raje svoje 3 trenutne na manjših resolucijah, najbolj nevšečni so mi pa full HD 15,6 zasloni, pa saj to komaj kaj vidiš!
Drugače so pa zasloni stari od 8 do nekje 4 let, ker jih pač kar naprej dodajam pokvaril se mi pa še nobeden ni, zdaj sem na 3 pa na mizi ni več placa za 4, mogoče si kupim fullhd ko se mi eden izmed teh pokvari :)
  • spremenilo: matic492 ()
Janac ::
matic492 je izjavil:
Nastav primarni monitor.
matic492 ::
V temu tropicsu negre, saj sem rekel, v unigine heaven 4.0 gre, za en benchmark pa ne bom namizja prestavljal, ker se mi vse ikone potem zmešajo.
miraldi ::
[miraldi] - [i5 2500k stock] - [Gigabyte 7870 1245/ 1375] - [53,9] - [1357] - (13.8)
i7 12700k
RTX 4070ti
32Gb
fr4nc ::
[Fr4nc] - [AMD FX-8320 stock] - [Sapphire 7850 2GB @1253/1475] - [57.4] - [1447] - (13.1)
Ko pridem domov dodam še screenshot...
fr4nc ::
[Fr4nc] - [AMD FX-8320 @4768MHz] - [Sapphire 7850 2GB @1263/1490] - [58.1] - [1463] - (13.1)
http://shrani.najdi.si/?3K/w7/DItAIVy/1...
Lep večer
Slo-Tech 3D Team: Unigine Valley 1.0 (strani: 1 2 3 )
Oddelek: Navijanje
10729686 (17749) dj_uro
Unigine Heaven 4.0 (strani: 1 2 3 )
Oddelek: Navijanje
10650623 (36029) barocco
Heaven - DirectX11 benchmark
Oddelek: Navijanje
132591 (1950) ekseR
