Forum » Pomoč in nasveti » Prenosnik do 500€
Prenosnik do 500€
lommmp ::
Pozdrav!
Iščem prenosnik v cenovnem razredu do 500€ in potrebujem za ta denar najmočnejšo grafično kartico kar se da dobit-ne bom uporabljal za gaming ampak ko bom vrgel kakšno igrico hočem da ta deluje najboljše.
Prosim če mi navedete par primerov prenosnikov, ki bi bili v redu glede na moje zahteve. :)
Hvala in LP
Hvala in LP
Brias ::
v ceni in konfigu ,... skoraj brez konkurence ... od 538 eur naprej v 13 trgovinah ...
http://www.ceneje.si/racunalnistvo/pren...
Prenosnik Samsung NP300E5E 2,5 GHz (NP300E5E-S01HR)
Operating System Windows 8 (64-bit)
Processor / Chipset Intel(R) Core™ i3 Processor 3120M (2.50 GHz, 3 MB L3 Cache) Intel HM75
Graphic AMD Radeon™ HD 8750M Graphics with 1GB gDDR3 Graphic Memory (PowerExpress)
Display 15.6" HD LED Display (1366 x 768), Anti-Reflective
Memory 4GB DDR3 System Memory at 1600MHz (4GB x 1) 2 SODIMM
Storage 500GB S-ATAII Hard Drive (5400RPM)
Optical Drive Super Multi Dual Layer
Color Sleek Silver
Multimedia Stereo Speakers ( 1.5 W x 2 ) SoundAlive™ Internal Digital Mic 720p HD Web Camera
Network 802.11 bg/n 1X1 Bluetooth v4.0 Fast Ethernet [10/100]
Ports 1 VGA 1 HDMI 3 USB2.0 3-in-1 (SD, SDHC, SDXC) Multi-media Card Reader 1 Headphone out/Mic-in Combo 1 RJ45 (LAN) 1 DC-in
Input Island-type keyboard with Numeric key Touchpad
Security Security Slot
Power 6 Cell (48Wh) 40 W / 60 W AC Adapter* * Adapter is different depend on system
Dimension 376 x 248 x 25.2 ~ 31.8mm (14.80" x 9.76" x 0.99" ~ 1.25")
Weight 2.2Kg (4.85lbs)
Software
Color Sleek Silver
Software
| » | Performans računalnikov v videoigrah - FPS debata a.k.a benchmark (strani: 1 2 3 4 … 13 14 15 16 )Oddelek: Strojna oprema | 176844 (27110) | Sssaga |
| » | Nakup prenosnika (strani: 1 2 )Oddelek: Pomoč in nasveti | 23649 (22857) | krneki0001 |
| » | Kaj je potrebno za delovanje iger?Oddelek: Kaj kupiti | 2072 (1879) | iloveboobz |
| » | Ali je ta comp dovolj dober za igranje Sims3?Oddelek: Kaj kupiti | 2181 (1856) | AnitaM |
