Razlika med Radeon HD7750 DDR3 proti DDR5
Pozdravljeni, ali bi malo lahko kdo povedal, če je velika razlika med Radeonom 7750 DDR3 verzijo in DDR5 verzijo.
Namreč sem spregledal, ko sem naročal kartico in sem naročil/plačal/prejel DDR3 verzijo.
Igram pretežno starejše igre (NFS Most Wanted, GRID, WRC1, Colin McRae Rally 2005, Dirt 1), občasno tudi kakšno novejšo (večina teh uporablja Unreal 3 pogon, recimo Rise of the Argonauts, Hunted: Demons Forge ipd.), najnovejšo, kar bi igral, je Larianov Divinity 2: Ego Dragonis Directors Cut (kupil na GOGu).
Ali bi Radeonka HD7750 z 1 GB DDR3 RAMa lahko poganjala zgoraj naštete igre na 1600 x 1200 ločljivosti in čim višjih nastavitvah? Ali pa bi bilo to smiselno zamenjat (če se sploh da, prej moram vprašat trgovca) za DDR5 verzijo (ki je dražja)? Bi bila ta z DDR3 dovolj za moje potrebe.
Brias ::
par copy pasteov ... da zamenjaj za 1gb ddr5
blazorthon
Graphics card Master
March 18, 2013 5:25:19 PM
GDDR5 can have much higher memory bandwidth. In the case of the two Radeon 7750s that you have in your link, GDDR5 has a huge performance advantage- it can be as much as or even more than about 50% better. The DDR3 version of the Radeon 7750 is not worth buying even if you had to pay $30 more for the GDDR5 version so long as you can afford the extra money. A mere $10 more makes the DDR3 version completely irrelevant, especially since the significantly faster Radeon 7770 is not much more expensive than the Radeon 7750.
Sakkura
26 December 2012 23:08:40
1 GB GDDR5 is going to be better than 2 GB DDR3 95% of the time with that graphics card. The last 5% of the time it's not going to matter either way.
rolli59
Gaming Authority
Windows 7 Expert
26 December 2012 23:11:51
That card is going to run out of processing power before memory with 1GB installed and the DDR5 is going to make it faster as well.
ddr5 > ddr3 anyday...it doubles the bandwidth which will be be very effective in games that are memory bandwidth limited like crysis....
reoparker, Feb 13, 2013
#2
More memory is better, IF the card can take advantage. In this case, it won't, so get the faster memory.
Hvala.
Torej je kar velika razlika. Eh, jaz neumnež. ;((
Nič, zdaj bom pisal prodajalcu, pa da vidimo, če bo šlo zamenjati.
klinker ::
Sej, a ni po zakonu, da pri spletnih nakupih imas nek rok, v katerem izdelek lahko menjas, sploh ce je ta neodprt in neuporabljen?
klinker je izjavil:
Je, maš prav. Sem pogledal zdaj in v pogojih piše 30 dni (kupil preko eBaya pri eni nemški firmi).
Pisal sem jim mail, upam, da se bo izšlo.
Janac ::
Kok te je pa pršla?
filip007 ::
Kaj si pa mislil, da kupuješ Geforce 7600GT, še dobro da nisi končal v starodavnem egiptu.
G nima spredaj...
Zero games, zero talk.
klinker ::
filip007 je izjavil:
G nima spredaj...
Lol kak komentar ;((
Clovek je pac spregledal, wtf!
Janac je izjavil:
Kok te je pa pršla?
84 + 7 € poštnina.
Imam ITX ohišje in sprejme lahko samo single-slot kartico ...
filip007 ::
6EUR prišpatati, neprecenljivo...
http://www.sestavi.si/index.php/item/di...
Ma ok, še 3.5EUR PTT.
  • spremenil: filip007 ()
filip007 ::
Evo brez stroškov dostave, nevem zakaj potem ne vprašaš prej...
http://www.pcplus.si/strojna-oprema/gra...
Ja pa res povsod ne piše zraven, tisti G.
Brias ::
funtech ...
osebni prevzem :)
XFX RADEON HD 7750, 800M CORE Edition, 1024 MB DDR5, HDMI, DVI FX-775A-ZNJ4
FX-775A-ZNJ4
Naša cena: 92,30 €
Grafična kartica Club 3D Radeon HD 7750 1GB DDR5
Naša cena: 92,87 €
če je itx, potem more bit skor ziher low profile, kar pa te kartice ko jih vi nakazujete niso.
Pri nas je najcenejša od 106€ naprej (vem, ker tud sam iščem)
@filip007:
Dobro, zmotil sem se. Priznam.
In kaj zdaj? Itak sem nasankal jaz in ne ti.
Pri tem prodajalcu sem sicer že v preteklosti kupil manjšo zadevo in ni bilo problemov.
Kupit sem želel točno tisto kartico od Club 3D, katero si prilinkal iz sestavija. Razlika v ceni med sestavi in tem nemškim prodajalcem je cca. 4 €. Ampak zdaj je, kar je.
@hojnikb:
sicer je ohišje ITX, a sprejme navadno grafično kartico (sicer ne tiste velikanske oz. predolge). Edini pogoj je, da mora biti hladilna rešitev "single slot".
Drugače pa imaš prav, low profile kartice stanejo tam okoli 100 € in naprej:
http://www.ebay.de/itm/CLUB3D-Radeon-HD...
Tukaj pa je ista kartica celo cenejša:
Janac ::
Kaj če bi pa 7770 vzel?
@Janac:
Imam SFX napajalnik (300 W) in ta Radeon 7750 ima majhno porabo v primerjavi z ostalimi karticami. 7770 pa rabi že dodatni priključek za elektriko, skratka ... izven moje lige.
  • spremenil: opeter ()
ja te low profile zadevice malo res zasoljene cene...
FlamE#7 ::
Zdravo,
tudi jaz sem kupil MSI HD7750 2GB DDR3. Sedaj me pa nekaj zanima. imam 4 gb DDR2 rama (delujejo pri 500MHz vsak sodeč po cpuz)in E8500 procesor (nič OC).
Tak sistem ima kar hude težave (oziroma je zame neigralno, ker šteka ko najbolj sekajo eksplozije) poganjati že TF2 na priporočenih nastavitvah (ekran ima 1920X1200 ločljivost). Je to normalno?
3DMark 11 imam na performance testu rezultat P2266 pri čemer je to več kod 10% slabši rezultat od najslabšega na njihovi spletni strani (E8500 in HD7750). Pa jih je mislim da 50 boljših. Če gledam po detajle, pa vidim da me dol vleče graphics test, pri meni poraznih 2221. Pa tudi combined score imam zelo slab- 2091.
Ne vem kaj je lahko narobe, saj imam driverje zadnje.. Pa čudno mi je ko sem pred mater šestimi leti igral hl2 na X1800XT na istih nastavitvah... krnekaj
Hvala
klinker ::
Bos mogu se "malo" znizat razne detajle za tako resolucijo. Ta grafa je dalec od gamerske :|
Brias ::
FlamE#7 je izjavil:
Zdravo,
Hvala
kdaj si kupil kartico? in zakaj ze DDR3?
ze ce bi vzel 7750 z 1gb ddr5 bi bila zadeva kar hitrejsa, da ne recem 20 eur vec za 7770, top pa 135 eur za 7790, ki je energijsko nezahtevna, tiha, in vsaj ... 2* hitrejsa od 7750 z ddr3 ramom ...
SuperVeloce ::
ja z ddr3 verzijo se fino nahecaš :|. V najboljšem primeru si zgubil 15% hitrosti, določene igre pa znajo delati do 50% počasneje (link).
Popolnoma neuporabno, tega sploh nebi smeli prodajati :). TF2 bi moral delovati gladko na 1920x1080 z gddr5 verzijo.
Za občutek, na moji antični hd3870 je brat igral na high 1680x1050 2xAA, je bilo ravno dovolj za vsync.
FlamE#7 ::
Hm... Kakšne nej potem probam nastavitve.
Je pa res sekret tole. Ja ubistvu je bilo tko, da sem jo dobil za darilo, in pač niso vedeli točno kaj kupujejo pa da za 20 evrov dost hitrejšo kartico dobijo...
Ma nima veze. Seprav kaj, sem lahko že vesel če mi sploh dela na vse na low (ker na priporočenih ne dela dobro če je na serverju 32 ljudi) 1920X1200 ta prastara igra? Grozno..
prodaj in kupi gddr5 varjanto oz bolšo grafiko..
SuperVeloce ::
Ali je dejansko kriva grafična kartica, bi težko rekel. Če bi ti lahko nekdo posodil gddr5 verzijo za preizkus, bi bilo idealno. Ampak samo grafično jedro je igro zagotovo sposobno poganjati na high, koliko pa imajo rami vpliva pri tej igri pa ne vem.
SuperVeloce ::
Lahko pa sam preizkusiš eno zadevo, naloži gpu-z, zaženi, potem pa med igro minimiraj na kakšnem zahtevnejšem delu in takoj naredi screenshot pod zavihkom 'sensors'. Pa tudi prvi zavihek naredi screenshot, da vidimo če pci-e deluje na 16x itd...
FlamE#7 ::
Super ideja SuperVeloce, bom to naredil še ta teden, pa postam.
Žal ne poznam nobenega s gddr5 verzijo. Saj jaz tudi mislim da ga nekaj nazaj ovira... Mogoče so pa res tako blesavo naredli s temi rami.. Bomo vidli
ddr3 je sigurno bottleneck pri tej grafi, ker že pri slabših grafikah je ddr3 huda omejitev (amd apu recimo).
navijaj ram na grafiki in opazuj pohitritev 8-)
FlamE#7 ::
Zdravo,
Evo sem gledal pri gpu testu GPU processor obremenitev in je bil skor ves čas na 96-99% kar je pomoje kul?
Pa kaj a je to možno da še pri tako starem osnovnem računalniku (kot sem napisal- 4 gb DDR2 rama (delujejo pri 500MHz vsak sodeč po cpuz)in E8500 procesor (nič OC) in pa matična plošča ASUS P5KPL-AM.)bottleneck ta grafična? Računalnik je 5 let star grafična je bla pa lansko leto izdana mater... Bolano
Aja za gpu test sem mislil da sem igral TF2 pa sem mel gpuz prižgan :)
  • spremenilo: FlamE#7 ()
bdoxx ::
to pomeni da je grafa bottleneck
FlamE#7 je izjavil:
Zdravo,
tole ni glih high end grafika, tak da nwm kaj si pričakoval od nje..
Brias ::
FlamE#7 je izjavil:
Zdravo,
star onsnoven racunalnik ....?
jaz bi na tak komp obesu 7870XT za 220 eur ....
pa bi gpu-z lepo pokazal od 80-90% ,,,,
core2 bi kr konkretnu bottlenecku 7870xt, sploh v igrah, ki nimajo rade samo 2 jeder..
FlamE#7 ::
To je že res da ni high end zadeva pa pač bla je 100€ ampak sem vseeno mislil da bo ta novejša serija za 100€ boljša kot 5 let stara grafa za 400 :D, pa očitno ni tko... Usaj na mojmu računalniku ne...
No ja, sej to je pol to, grafa bottleneck. Hvala fantje!
Grafična kartica- katero priporočate ? (strani: 1 2 )
5212716 (11048) AapocalypseE
Nakup nova/rabljene grafične kartice
455275 (4325) GenZNPC
LC 550W psu in GF GTS 450
393758 (2939) Aljaz3
Abit IP35-E matična in GeForce GT 640 grafična
132409 (2293) opeter
ali imam dovolj močen napajalnik? (strani: 1 2 )
7610710 (10067) Janac
