Težave s pekačem
Težave s pekačem
Cimetikus ::
Torej. Problem je sledeč. Kupil sem pekača (samsunga) ga vgradil v skladu z navodili (operacijski sistem winXP) in sedaj ko hočem pečt se pojavlja težava. Namreč z postopkom pečenja začne, nato pa javi napako.
Če kak mojster ve, kako naj odpravim to napako se mu za odgovor najlepše zahvaljujem
Poročilo o napaki
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 17.2.2003 19:28:42
Nero Version: 5.5.9.14 (Nero Express)
Recorder: Version: R500 - HA 0 TA 1 - 5.5.9.14
Adapter driver: HA 0
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: Version: 1.00 - HA 1 TA 0 - 5.5.9.14
Adapter driver: HA 1
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 2F040J0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-248B atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST CD-ROM GCR-8520B atapi Port 1 ID 0 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261616kB)
Free physical memory: 127MB (131060kB)
Memory in use : 49 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
21.2.2003
CD-ROM (ISO)
18:08:47 #1 Text 0 File Isodoc.cpp, Line 6887
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:08:47 #2 Phase 88 File dlgbrnst.cpp, Line 1571
ExacLink activated
18:08:47 #3 Text 0 File Reader.cpp, Line 118
Reader running
18:08:47 #4 Text 0 File Writer.cpp, Line 127
Writer SAMSUNG CD-R/RW SW-248B running
18:08:47 #5 ISO9660GEN -11 File geniso.cpp, Line 4484
First writeable address = 0 (0x00000000)
18:08:48 #6 Text 0 File Burncd.cpp, Line 3588
Turn on Track-At-Once, using CD-R/RW media
18:08:48 #7 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 651 (651) = #651/0:8.51
relocatable, CD pos for caching/writing not required/required, no patch infos
18:08:48 #8 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 359846 (79:59.71)
Last address to be written: 650 ( 0:10.50)
18:08:48 #9 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
18:08:48 #10 Text 0 File DlgWaitCD.cpp, Line 1420
Recorder: SAMSUNG CD-R/RW SW-248B;
CDRW code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc.
ATIP Data: ?
18:08:48 #11 Text 0 File ThreadedTransferInterface.cpp, Line 812
Prepare recorder SAMSUNG CD-R/RW SW-248B for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 1640448
18:08:48 #12 Text 0 File ThreadedTransferInterface.cpp, Line 840
Removed 2 run-out blocks from end of track 1.
18:08:48 #13 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 649 blocks [SAMSUNG CD-R/RW SW-248B ]
18:08:48 #14 Phase 24 File dlgbrnst.cpp, Line 1571
Caching of files started
18:08:49 #15 Phase 25 File dlgbrnst.cpp, Line 1571
Caching of files completed
18:08:49 #16 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 48x (7.200 KB/s)
18:08:49 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1948
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
18:08:49 #18 Text 0 File Mmc.cpp, Line 17168
Set BUFE: ExacLink -> ON
18:09:01 #19 SCSI -400 File Cdrdrv.cpp, Line 1381
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02F70000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
18:09:01 #20 CDR -400 File Writer.cpp, Line 335
SCSI Target error
18:09:01 #21 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
18:09:02 #22 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
18:09:02 #23 TRANSFER -18 File WriterStatus.cpp, Line 188
Could not perform EndTrack
18:09:09 #24 SCSI -1064 File Cdrdrv.cpp, Line 1177
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02F1D000
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0xBE 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x19 0xF8 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x21 0x00
18:09:09 #25 SCSI -1064 File N, Line 1177
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0012BE30
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0x28 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x01 0x00 0x00 0x00
18:09:09 #26 SCSI -1064 File , Line 1177
Sense Code: 0x21
Sense Qual: 0x00
18:09:09 #27 SCSI -1064 File , Line 1177
Sense Code: 0x21
Sense Qual: 0x00
18:09:09 #28 SCSI -1064 File s, Line 1177
Sense Code: 0x21
Sense Qual: 0x00
18:09:09 #29 SCSI -1064 File nero, Line 1177
Sense Code: 0x21
Sense Qual: 0x00
18:09:09 #30 SCSI -1064 File R, Line 1177
Sense Code: 0x21
Sense Qual: 0x00
18:09:09 #31 SCSI -1064 File , Line 1177
Sense Code: 0x21
Sense Qual: 0x00
18:09:10 #32 Text 0 File WriterStatus.cpp, Line 236
falling back to disc fixation
18:09:17 #33 Text 0 File Mmc.cpp, Line 12134
Fixation : Second step for unclosed Sessions
18:09:25 #34 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 48x (7.200 KB/s)
18:09:25 #35 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=5.1.1.210, size=23721 bytes, created 17.2.2003 20:57:02
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29.8.2002 13:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
iration ::
Sicer nisem šel vsega tega brat, ampak ali si poskusil peči z manjšo hitrostjo?
Tudi jaz bi imel kakšno pravico rad v življenju. Npr. pravico do tega, da delam
12 ur na dan in sem za to nagrajen s strani delujočega ekonomskega prostora, ne
pa kaznovan s strani Salmoneličevih gremlinov. - NavadniNimda
Cimetikus ::
da, a težava ostane enaka.
boštjan ::
nastavo prav jumpere,daj ga na secondary master,vklopo DMA.peko z več vrstami cd-jev.
Cimetikus ::
DMA imam vkljopljen, jumper pa na slave, kot je pisalo v navodilih. a potem ti meniš da bi prestavitev na secondary master rešila problem????
boštjan ::
probaj,zgubit nimaš kaj.tako ko je HDD kralj na primary kanalu,naj bo cd-rw kralj na secondary kanalu.
če pa še to ne bo pomagalo,pa ga sprobaj pri kolegu in če ne dela;reklamacija
Cimetikus ::
jaz imam povezavo iz cd-rw na disk in potem na plato. cd-rom pa direkt na plato. a ima to kaj veze pri master/slave odnosih
boštjan ::
daj lepo cd-rw na svoj kanal,cd-rom pa naj bo njegov sluga
Cimetikus ::
kako naj pa to uredim s kabli????
oprosti ce sem prevec radoveden, ampak nisem ravno računalniški mojster.
še enkrat hvala za tvojo dozdajšnjo in vnaprejšnjo pomoč.
boštjan ::
na tistem kablu kjer maš zdaj cd-rom vrži gor pekača,s tem da jumper na pekaču daš na master,od cd-roma pa na slave.še katere nejasnosti?keri kanal pa je primary in keri secondary pa si oglej knjigico od matične
Dead_Eye ::
še ena razlaga: na rw dej jumper na master in ga priklopi tam kjer je zdej cdrom.
na cdromu dej jumper na slave in ga priklopi ob disk(tam ki maš zdej cdrw)
pol bi moglo delat...
The one and only
Cimetikus ::
Hvala obema za pomoč. Sedaj dela.
Lep da še naprej.
boštjan ::
me veseli da sem lahko pomago;)
NEC ND-3540A problem...
282784 (2075) dean444
LG GSA-4120B dela probleme pri pečenju DL DVD+Rjev
442195 (2004) mtosev
tezave z virusom
81868 (1717) royal
1GB ram-a in windowsi XP??? Gre to sploh skupaj?
Oddelek: Operacijski sistemi
382741 (1991) R33D3M33R
Problemi s TEAC CD-W540E
212422 (2058) Dami
