Debian server problem
Hexx ::
Pozdravljeni,
na mojem Debian strežniku se mi je zgodilo da sem ob ustvarjanju spletne strani pobral zbuggan plugin za CMS, ki je pognal čuden sql klic kar je v trenutku zafilalo disk in ustavilo mysql strežnik.
Df -h /
Filesystem Size Used Avail Use% Mounted on
/dev/vzfs 20G 6.8G 1.1G 87% /
Odstranil sem nekaj logov in backup datotek tako da sem dobil nekaj prostora, da lahko sploh mysql strežnik spet zaženem in vidim da je disk zaseden le 7/20GB piše pa 87% use.
Po tutorialih na netu sem še zagnel tole, kar pomeni da je apache ustvaril veliko neizbrisanih datotek, kaj lahko naredim da dobim nazaj celoten prostor?
lsof | grep "(deleted)"
apache2 645 root mem REG 145,19 2154817209 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817250 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817252 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817196 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817040 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root 20w REG 145,10 0 34088908 (deleted)/var/run/apache2/ssl_mutex
sshd 1141 root mem REG 145,19 2154917967 (deleted)/dev/zero (stat: No such file or directory)
sshd 1141 root mem REG 145,19 2154913890 (deleted)/dev/zero (stat: No such file or directory)
sshd 1143 alec mem REG 145,19 2154917967 (deleted)/dev/zero (stat: No such file or directory)
sshd 1143 alec mem REG 145,19 2154913890 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817209 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817250 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817252 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817196 (deleted)/dev/zero (stat: No such file or directory)
itd...
Hvala!! :D
  • spremenil: Hexx ()
[Linux] Ubuntu serve
Oddelek: Operacijski sistemi
171520 (1332) tx-z
[Debian] Po dveh dneh uporabe sem ga sesul :S
102446 (2193) Ice-Heki
oscommerce v slo (strani: 1 2 )
Oddelek: Izdelava spletišč
709431 (8246) gregy
EZ portal problem!
91782 (1702) roli
Kako inštalirati program v linuxih ??
Oddelek: Programska oprema
91898 (1764) Gandalfar
