Forum » Izdelava spletišč » EZ portal problem!
EZ portal problem!
roli ::
http://www.rolihandrej.myfxh.com/ezPortal%20Install/phpbb_root/portal.php Zakaj ko odprem
ta lnk mi javi to:
Warning: main(./extension.inc): failed to open stream: No such file or directory in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 54
Warning: main(): Failed opening './extension.inc' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 54
Warning: main(./common.): failed to open stream: No such file or directory in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 55
Warning: main(): Failed opening './common.' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 55
Warning: main(./fetchposts.): failed to open stream: No such file or directory in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 56
Warning: main(): Failed opening './fetchposts.' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 56
Fatal error: Call to undefined function: session_pagestart() in /home/arolih/public_html/ezPortal Install/phpbb_root/portal.php on line 61
Kaj sem naredil narobe?
Sledil sem navodilom za namestitev.
Edino kar je je to,da sem namesto lang_english uporabil lang_slovenian
in namesto subsilver aqa.
Pa datoteko portal_body.tpl sem kopiral in jo vstavil v mapo aqa.
ta lnk mi javi to:
http://www.r00li.com
pitagora ::
namesti tako kot pise, in uporabi jezik ki je zraven
probaj najprej tako da nic ne spreminjas.
potem pa postopoma spreminjaj in bos videl kje je napaka.
sicer pa to kar napise, kot da ni te datoteke? ali direktorija?
lp pitagora
roli ::
OK bom probal to!
Ne razumem
OK bom probal to!
Ne razumem
roli ::
Spet problemček:
Instaliral sem Knowledge base tako kot piše.
Vse sem delal točno po navodilih.
In ko hočem do nje dostopati dobim:
Splošna napaka. Ojoj.
Couldnt Query Custom field
DEBUG MODE
SQL Error : 1146 Table 'arolih_xxx.phpbb_kb_custom' doesn't exist
SELECT * FROM phpbb_kb_custom ORDER BY field_order ASC
Line : 50
File : functions_kb_field.php
Kaj je narobe?
DEBUG MODE
Line : 50
Kaj je narobe?
Tody ::
veš če se boš tako globoko potapljal v spletne strani je dobro znati kaj angleščine !
ker nekako ti vse piše
Tabela 'arolih_xxx.phpbb_kb_custom' ne obstaja
| » | zen-cart: slovenski prevod / monetaOddelek: Izdelava spletišč | 4407 (3857) | mrezna |
| » | Web control panelOddelek: Izdelava spletišč | 1897 (1610) | DC- |
| » | vstaviti phpbb na statično straniOddelek: Izdelava spletišč | 1995 (1850) | Tody |
| » | oscommerce v slo (strani: 1 2 )Oddelek: Izdelava spletišč | 9425 (8240) | gregy |
| » | Vote script(php)-problem?Oddelek: Izdelava spletišč | 1333 (1289) | AlexUS |
